Pronterface gcode 28 and 29 not recognized
Posted by giandiosos
February 05, 2020 05:34AM
I use Pronterface and repetierhost to print.
With pronterface the gcode 28 (homing) and g29 (leveling) no longer work.
The carriage remains stationary and after a moment of at least 1 minute it begins to print as if the temperature had been reached.
There may be a track because for a test I launched the code M320 which allows cold printing.
But since and after having left and relaunched pronterface several times nothing helps.
Re: Pronterface gcode 28 and 29 not recognized
February 05, 2020 06:53AM
Manually check that no endstop is being triggered and send the machine a M119
It should tell you all endstops are open
now choose an endstop and manually trigger it (for eg hold down switch with a finger) now send another M119
The printer should now tell you that endstop is triggered.
Check all endstops
February 06, 2020 03:56AM
Thank you for answering.
Sorry G28 and G29 work well. It is the heating that does not work. I am creating a new post.
