Pronterface scaling prints when loading files
Posted by Neosolon
March 06, 2015 12:04PM
When I load the attached STL file to slicer to get the g-code and then load the resulting Gcode to Pronterface I get the following message:
the print goes from 228.110000 mm to 271.880000 mm in X
and is 43.770000 mm wide
the print goes from 78.130000 mm to 121.860000 mm in Y
and is 43.730000 mm wide
However the print is only 10mm wide.
Anyone know why pronterface is causing this error?
open | download - Circle_Test.stl (32.3 KB)
Re: Pronterface scaling prints when loading files
March 16, 2015 05:57AM
My...
Slic3r clains the object is 30x29.98x6
It looks about 30mm in meshmixer
Pronterface claims 43.3x43.29 - that includes a printed brim 6mm away from it.
Do you want it to be 10mm dia? or your print comes out at 10mm?
a
March 30, 2015 07:15PM
I fixed the issue but I don't know what caused the error. I reset the settings for the print bed and it seemed to work.
The problem was that pronterface was giving these large bounds of where the part was expected to print
