Hello every one,
My first post here !
I have got a problems. When I use Pronterface, I can change the extrusion lenght, but if I close and open again Pronterface, the new lenght is not save. I say that because one time I had to put 50mm in lenght, and now each time I open Pronterface, it is 50mm save in the extrusion lenght option, I do not know why it was this time. Usually I put 5mm... The problem is that sometimes, I forgot the 50mm and I start manual extrusion and 50mm are extruding ! It is embarassing.
I don't know if it is in the new version of Pronterface, but in the past, the knew extrusion lenght was save each time we changed it. I don't find any pronterface source files where I can change this value, and in pronterface setting's too.
Does someone know about this parameter ?
CBB.
