Machine: Anycubic Kossel Linear Plus
I have finally managed to get the motherboard to talk to Pronterface, and I can send G-codes to interact with the printer. All good so far.
Repetier-Host and Cura can both send G-code to the printer and print them properly, so there's no fundamental problem with either the printer or its communications.
Pronterface insists on placing newly loaded G-code files in the bottom-left corner, well off the circular bed. When I try to print the effector goes to the top-right corner (approximately) and continues there.
I have used both slic3r and cura to generate G-code files, and Pronterface treats them exactly the same way.
It seems that Pronterface isn't behaving as though the bed is circular, even though I have set it and the central window also shows a circular bed.
It is quite possible - almost certain - that I have missed a parameter in the Pronterface settings, or set something incorrectly. However I've been staring at it for the past hour or two and I can't see anything wrong...
Any help or guidance would be appreciated!
Edited 1 time(s). Last edit at 12/02/2019 06:12AM by David J.
