Errortongue sticking out smileyrinter halted. kill() called! [ERROR] Errortongue sticking out smileyrinter halted. kill() called!
September 30, 2020 01:00PM
hi all
need help here- Pronterface keeps shutting down my " prints" after 3 cycles, motors move normally- with the KILL message
Print started at: 19:08:14
echo:busy: processing
application is CNC
have dummy thermocouple 998/999 on tried various settings
commented out various temp controls:
MARLIN:
#define TEMP_SENSOR_0 999
//#define TEMP_SENSOR_1 0
//#define TEMP_SENSOR_2 0
//#define TEMP_SENSOR_3 0
//#define TEMP_SENSOR_4 0
//#define TEMP_SENSOR_BED 0
//#define TEMP_SENSOR_CHAMBER 0
// Dummy thermistor constant temperature readings, for use with 998 and 999
#define DUMMY_THERMISTOR_998_VALUE 0
#define DUMMY_THERMISTOR_999_VALUE 0
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
// from the two sensors differ too much the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
//#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Extruder temperature must be close to target for this long before M109 returns success
//#define TEMP_RESIDENCY_TIME 10 // (seconds)
//#define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one
//#define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
//#define TEMP_BED_RESIDENCY_TIME 10 // (seconds)
//#define TEMP_BED_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one
//#define TEMP_BED_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
//#define HEATER_0_MINTEMP 5
//#define HEATER_1_MINTEMP 5
//#define HEATER_2_MINTEMP 5
//#define HEATER_3_MINTEMP 5
//#define HEATER_4_MINTEMP 5
//#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
//#define HEATER_0_MAXTEMP 275
//#define HEATER_1_MAXTEMP 275
//#define HEATER_2_MAXTEMP 275
//#define HEATER_3_MAXTEMP 275
//#define HEATER_4_MAXTEMP 275
//#define BED_MAXTEMP 150
also:
//#define PREVENT_COLD_EXTRUSION
//#define EXTRUDE_MINTEMP 170
* Prevent a single extrusion longer than EXTRUDE_MAXLENGTH.
* Note: For Bowden Extruders make this large enough to allow load/unload.
//#define PREVENT_LENGTHY_EXTRUDE
//#define EXTRUDE_MAXLENGTH 200
//#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
//#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed
endstops are ok
keep getting the ^*^*TT*&!!! error message!
help very much appreciated
thx!
C
Edited 6 time(s). Last edit at 09/30/2020 01:11PM by Coolerooney.
