Print runs to end of y axis - then ejects filament (solved)
October 22, 2022 03:45PM
Hello there,
Running marlin 2.1.1 on an Anycubic mega pro, Printrun 1.6.0
Will include the config files for marlin in case it helps but here is the command I'm seeing when trying to start a print in Pronterface.
TFT Serial Debug: OnUserConfirmRequired triggered... Please wait...
//action:paused
TFT Serial Debug: OnUserConfirmRequired triggered... Heating...
TFT Serial Debug: OnUserConfirmRequired triggered... Ejecting...
Then the printer extrudes about 15mm of filament, pauses for a few seconds and then completely ejects out the filament. Unsure what would cause the ejection? Seems clear it is doing what it is told to do.
Operator error:
**Just in case anyone else runs into this issue I'll leave it up. My problem was that my filament sensor was triggered, which Marlin is setup to eject the filament, and then insert new. I'm not used to that with the default anycubic program. Simply reversed the trigger for the filament runout and solved that issue.
Edited 2 time(s). Last edit at 10/23/2022 01:41PM by Candidquality.
open | download - Configuration_eject_filament.zip (94.3 KB)
