Extruder don't work
Posted by norby
Extruder don't work
August 06, 2015 03:13PM
Hi I have prusa i3 ramp 1.4 board Marlin firmware, A4988 driver. My extruder don't work when I change the extruder motor and stepper driver whit x or y the motor work,but when I put x or y stepper driver in extruder slot the motor don't rotate whit Pronterface.Need to buy new boards?
open | download - Configuration.h (35 KB)
Re: Extruder don't work
August 06, 2015 03:48PM
The Extruder motor will not turn unless the hotend is heated up to at least 180C I believe. Make sure it is heated up to at least that temperature. There is a Gcode command to disable this but I dont remember what it is, look at the reprap gcode page for more info.
Edited 1 time(s). Last edit at 08/06/2015 03:48PM by gmckee.
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
August 06, 2015 04:08PM
It is one of the safety features in marlin that will not turn unless the minimum temp are reached inside config.h. It is not recommended to turn extruder unless you're doing calibration (extruder not attached to the hot end) with m302 [reprap.org]
August 07, 2015 10:52AM
I heated up the hotend at 240 and nothing happen the motor don't rotate.
Edited 1 time(s). Last edit at 08/07/2015 01:45PM by norby.
August 08, 2015 03:37AM
I find the problem my stepper driver is broken. Thanks
