Zero is normally a break in your wires to your thermistor
Unplug the thermistor cable from the board. Take a ohm reading on the plug threw the thermistor, should be around 100k at 25c..
If its not. find the break and fix it.
It could be a dead thermistor.. you wont know till you start testing the cable...
Edited 1 time(s). Last edit at 01/29/2016 02:18AM by Dust.
