Problem with Z Axes January 28, 2016 05:22PM |
M109 S200.000000 ;Sliced at: Thu 28-01-2016 08:02:21 ;Basic settings: Layer height: 0.1 Walls: 0.6 Fill: 20 ;Print time: 4 hours 40 minutes ;Filament used: 8.981m 26.0g ;Filament cost: None ;M190 S0 ;Uncomment to add your own bed temperature line ;M109 S200 ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z15.0 F9000 ;move the platform down 15mm G92 E0 ;zero the extruded length G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F9000 ;Put printing message on LCD screen M117 Printing...
Re: Problem with Z Axes January 28, 2016 11:29PM |
Re: Problem with Z Axes January 29, 2016 02:02PM |
Re: Problem with Z Axes February 03, 2016 03:59AM |
Re: Problem with Z Axes February 03, 2016 07:02AM |
Orlasgrandad
Hi Stevo,
Did you get this sorted ?
I've got the same issue
Cheers
Paul
Re: Problem with Z Axes February 03, 2016 07:12AM |
