ok, i've updated my firmware and changed every setting under the sun but I cant seem to find a way to use autolevel to level my bed properly.
I use RAMPS 1.4 and an inductive sensor as an autolevel probe.
In repetier I can only seem to find the option to check 3 points on the bed, which are set as Front left corner, Front right corner and then Back left corner.
When printing, the left side of the bed is printing considerably closer to the bed than the right side. resulting in the right side not sticking properly and the left side being flattened.
Does anyone know how to increase the points for my square bed or a better configuration to get even printing?
*EDIT* infact, after watching my printer print an object, the Z axis' arent making any compensation movements.
Arent the Z motors supposed to be constantly moving to compensate for the bed level?
Thanks
Chris
Edited 1 time(s). Last edit at 02/03/2016 07:53AM by muntahunta.
