Prusa I3 Auto Bed leveling issues - Z probe offset
Posted by UltiFix
March 11, 2016 11:51PM
Changing the Z probe offset has no effect on my bed leveling! So let's say I need to lower my hotend .6mm closer to the bed then what my capactive proximity sensor thinks is z homed to get good adhesion. Simple, change Z probe offset from extruder to -0.6 in configuration.h, then flash that firmware to the arduino mega. Simple right? After I finish flashing I run G29 to verify that it goes down 0.6mm lower than it did before. Nope. Nothing. No difference whatsoever.
I have tried enabling and disabling EEPROM, no difference. so im not getting bad numbers from there.
Marlin file zipped below, containing configuration.h etc.
ANY help is appreciated!
EDIT:
Problem solved
[github.com]
Also I had to change my Z max something and z min, thank you people on the foglertech guide!
Edited 4 time(s). Last edit at 03/12/2016 08:03PM by UltiFix.
Folger Tech 2020 i3 Wiki
Custom google search for the Folger Tech 2020 i3 forum topic by Animoose
open | download - Marlin.zip (376.7 KB)
Re: Prusa I3 Bed leveling issues - Z probe offset
March 12, 2016 10:40AM
Bump..
Edited 1 time(s). Last edit at 03/12/2016 12:37PM by UltiFix.
