Please help XYZ only moving forward and won't home
Posted by nukes88
November 21, 2017 11:27PM
I had my printer out of commission for about 3months last time I used it it worked fine. I decided to update the firmware install a bltouch sensor and made sure the steps match the old firmware. Now when I try to move the axis it moves forward fine but not in reverse. And I tried homing it using repetier and the smart controller and all axis move one step forward except the z axis it goes all the way down and won't accept the command from the sensor. All and stops works and not sure what else to tweak on the firmware.
Thanks in advance
Re: Please help XYZ only moving forward and won't home
November 22, 2017 03:48AM
check endstops with M119 (Show endstop status)
You have to use this as any leds on endstops dont mean much
November 22, 2017 07:24AM
you probably need to invert( configuration setting ) your end stop.
P3steel DXL, with Due/RADDS/Raps128 dual Wade's extruder
