Replacing RAMPS 1.4 with MKS Gen 1.4 September 26, 2017 09:55PM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 26, 2017 10:15PM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 27, 2017 02:48AM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 27, 2017 03:05AM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 27, 2017 03:16AM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 27, 2017 07:46AM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 27, 2017 07:40PM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 28, 2017 04:46AM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 September 28, 2017 06:02AM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 October 04, 2017 03:00AM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 April 08, 2018 05:21PM |
Re: Replacing RAMPS 1.4 with MKS Gen 1.4 April 08, 2018 05:26PM |
Dust
yes on ramp you have 2 steppers off of the 1 stepper driver.
You will have to wire them together. Ramps Z is wired in parallel, but there are some benefits to wiring in series
Left image is parallel, Right image is series
NB this image shows wiring for a push/pull system... where each stepper move the opposite direction to the other.
You need to match the stepper wire colors, black to black, blue to blue etc...
If you wish you can use E1 as second Z and use one stepper driver per stepper motor (its just a setting in marlin)
#define Z_DUAL_STEPPER_DRIVERS in Configuration_adv.h
This does need a stepper driver in the E1 position but it would mean you don't have to join stepper cables.
