Direct mounting E3D V5 hot end onto wade extruder
Posted by robotix83
July 15, 2018 01:37AM
I would like to direct mount a E3D V5 hot end that was originally a bowden type with the removable push to connect air line fitting to a wade extruder. Now when I remove the push to connect fitting will I need to do anything with the threaded hole left in the hot end or will it be ok to use as is?
Thanks
Re: Direct mounting E3D V5 hot end onto wade extruder
July 16, 2018 03:20AM
So it is the one on the left that I have that I would like to direct mount, what should I put in the threaded hole or is it ok to leave as it is?
July 16, 2018 04:49AM
I have mistakenly ordered e3d v6 clone bowden tipe instead of a direct drive for my prısa i3
I removed the tap and cut the tube from the top and leave it inside. Top of the tube is matching the filament hole in the wade extruder.
It is working there is no problem
Edited 1 time(s). Last edit at 07/16/2018 04:54AM by serdar415.
