220mm Heatbed support
Posted by JoeK1973
June 02, 2019 01:57PM
I'm running an i3 clone (Sgraber frame and bed support with i3 Rework plastic parts) and I'm looking to upgrade the heated bed to 220mm x 220mm.
Are there any bed support frames out there that will fit 220mmm x 220mm heatbeds?
Cheers
Joe
JK3D Blog - [jk3d.wordpress.com]
Re: 220mm Heatbed support
June 02, 2019 08:35PM
Not to sure on the answer here, I upgraded to a 300 X 300 and could find nothing out there, so I bought an aluminium sheet of that size, only to discover that the actual heat bed turned out to be 330 X 330 so I had to do the conversion myself by fitting tabs to suit. Hope that helps. Ernie
Edited 1 time(s). Last edit at 06/02/2019 08:37PM by erniehatt.
June 03, 2019 01:51PM
JoeK1973
If what you're looking for is the Y carriage, Gulfcoast Robotics makes several - the one they sell for the Anet A8 is a 220x220 one.
June 03, 2019 05:38PM
Thanks, yeah I’m looking for the frame that supports the heated bed. To be honest I think I can just print some parts to extend the frame, or perhaps find a heated bed with the right hole spacing.
June 04, 2019 09:30AM
Prussa I3 frame is for a 220x220 bed with 209mm hole spacing
heres one [vi.raptor.ebaydesc.com]
