Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 29, 2014 02:24PM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 29, 2014 02:56PM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 29, 2014 04:00PM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 30, 2014 10:07PM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 30, 2014 10:26PM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 31, 2014 02:22AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 31, 2014 08:29AM |
mac hacker
Hey all, in March, I bought an i3x, took me about 2 months to assemble it in my free time, and now not a whole lot works. The print head does get up to temperature, not sure about the bed (disconnected it and never reconnected it due to the main issue I'm having) but my big problem is that the motors only move 1 step at a time no matter how far I tell them to move. I've tried messing around with different steps/mm settings and nothing. When I try to print a 25mm cube, it heats up, whirs a little bit, moving a step at a time, then the X axis just shoots across to the other side without stopping before it reaches the end of the X axis assembly. Once it reaches the end, the motor doesn't turn off for another second (ish) the belt slipping all the while. After that, the printer tries to move, but the axes only move one step at a time. The extruder does not move and I am pretty sure it does not even lock. Does anyone have any insight? I think my RAMPS board might be the issue, but I'm not sure. I know the arduino works because I ran a blink program on it before installing it to the printer. Thanks for any help you can give me!
Re: DIY Tech Shop: "i3xl - prusa i3" reviews July 31, 2014 09:02AM |
ciutateivissa
mac hacker,
I had a similar problem with my printer as well. Finally I found out that I had to change some settings in the "configuration h" file to correct the issue with the wrong direction of the motor. Another way to correct this is to turn the connector of the motor on RAMPS board at 180 degree.
If one motor doesn´t move at all, try to connect the motor on a different connector (e.g. if Z don´t move try to connect it on the x connector to test). This will show you if the RAMPS or a stepper driver is faulty. If the motor then still does´t move you will need to replace it. I had one faulty motor in my kit as well...
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
Re: DIY Tech Shop: "i3xl - prusa i3" reviews August 04, 2014 10:11AM |
NevynPA
ciutateivissa
mac hacker,
I actually just did this with my Z axis (just now got my own i3xl up and running). I had to adjust the print area, nozzle temp, and change
to true for mine (even though it says set false for Mendel, I had to use true).
This page is a good walkthrough of the Configuration.h file:
[blog.think3dprint3d.com]
Adjust it for your preferred temps, printable size, direction, speed, etc and then re-upload to your Arduino. I'm a fan of changing one variable at a time, uploading, testing, and then changing the next one. That way if something doesn't work, it's easier to track down where the failure is at.
Re: DIY Tech Shop: "i3xl - prusa i3" reviews October 30, 2014 10:23AM |
thatsme
My advice, buy somewhere else. DIY Techshop is far from professional when it comes to emails and calls. I know I orderred the Prusa i3 Xl and received the small Prusa i3. they sent parts to make it an XL but they are not as shown on the pictures. If I had to do it again. I'd go Makerfarm.
Re: DIY Tech Shop: "i3xl - prusa i3" reviews October 30, 2014 11:53AM |
akonkol
thatsme
I'm currently having communication issues with DIY Techshop right now. I purchased a 3xl 14 business days ago and still don't have a tracking number. The phone number associated with their paypal account is wrong, when you call their "real" number you get a smug "we aren't taking calls - email us" and then you email and you get no response. I've been more than fair and now I'm angry.
Re: DIY Tech Shop: "i3xl - prusa i3" reviews December 22, 2014 11:08AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews January 02, 2015 09:00PM |
akonkol
thatsme
Re: DIY Tech Shop: "i3xl - prusa i3" reviews January 06, 2015 01:19AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews January 20, 2015 04:43PM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews January 23, 2015 12:55PM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews January 24, 2015 12:31AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews February 02, 2015 01:39AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews February 02, 2015 11:31AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews February 03, 2015 12:55AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews March 11, 2015 04:47AM |
Re: DIY Tech Shop: "i3xl - prusa i3" reviews March 23, 2015 09:12PM |
