Re: My Replikeo Prusa i3 Rework Build August 10, 2014 04:30PM |
Thanks Allnei! It it sill possible to attach fan duct with this mount? It's not show on pictures...Quote
Allnei
It was me, who talked about auto bed leveling. What you linked is mount for vanila i3, not Rework that we have.
Use this mount [www.thingiverse.com] and hot glue servo in it. I am not home, so I can´t post you picture of mine. Also you must use it with Marlin FW, because Repetier don´t have good auto bed leveling code.
Re: My Replikeo Prusa i3 Rework Build August 10, 2014 04:49PM |
Re: My Replikeo Prusa i3 Rework Build August 10, 2014 05:13PM |
Re: My Replikeo Prusa i3 Rework Build August 10, 2014 09:04PM |
Re: My Replikeo Prusa i3 Rework Build August 11, 2014 11:59AM |
flyrobot
Anyone has tried to measure the Q3 temperature? What is normal operating temperature? Mine is very hot approx 140 C. According to Q3 mosfet datasheet, it can handled the heat upto 170 degree celcius and Current upto 55 Amp. But why the mosfet is very hot and i measured the current on the heat bed is only approx. 10Amp.
I still searching the strongest mosfet and coldest for heatbed.
Any idea?
Re: My Replikeo Prusa i3 Rework Build August 11, 2014 03:07PM |
Check your X and Y belt tension and friction, I had similar problem when I was doing something on X carriage and put some force on it.Quote
Bratan
Guys two more question.
First, I noticed when I printed my big gear, that every level shifts slightly to the right (in X direction). What could be causing this?
Second, I've been having this annoying issue with Repetier since day 1. When I'm doing second print, it will stop heating up HotEnd. It says it's own, and I think even LED light is on but Hotend is cooling down. If I reset the board and reconnect, it starts working again. Anyone seen this issue?
Yes, you can mount fan duct with mount that I linked.Quote
Bratan
It depend on which axis is moving backward. Y can be little confusing, because if you have home position in right rear corner and you hit Y- then Y is supposed to move from you.Quote
sult4n
hi guys my printer moving backward is that normal ?
Re: My Replikeo Prusa i3 Rework Build August 14, 2014 07:37PM |
Re: My Replikeo Prusa i3 Rework Build August 14, 2014 09:43PM |
Re: My Replikeo Prusa i3 Rework Build August 14, 2014 11:11PM |
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 08:25PM |
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 08:48PM |
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 09:09PM |
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 09:12PM |
gadget_greg
Welcome to the club Mike!
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 09:15PM |
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 09:16PM |
gadget_greg
The thing is that they're plastic (3d printed . They electrically isolate your Mega/RAMPS from shorting on the metal frame. You can rig up any damn thing to do it. Or once you get printing, print those first!
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 10:19PM |
Re: My Replikeo Prusa i3 Rework Build August 15, 2014 10:21PM |
underthetire
Mine didn't have them either. Since my frame was plexi, I just used some stand offs I had laying around.
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 12:05AM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 12:25AM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 12:27AM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 12:30AM |
gadget_greg
Buy the sunday paper, there's usually at least one harbor freight flier and almost always a 20% off your entire purchase coupon! (except items that you have other better coupons for)
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 12:56AM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 01:05AM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 12:57PM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 02:28PM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 02:39PM |
gadget_greg
BTW, if you don't already have one, get yourself a digital caliper. $9.99 at HF with the current email coupon!
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 03:53PM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 07:50PM |
underthetire
Check the caliper at the store. We bought 10 of them for rough measurements at work. 3 out of 10 were bent and didn't actuate smoothly. The others worked OK, just needed a good cleaning. I have a couple sets at home as well.
Re: My Replikeo Prusa i3 Rework Build August 16, 2014 09:07PM |
