Re: My Replikeo Prusa i3 Rework Build August 16, 2014 10:38PM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:15AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:28AM |
underthetire
Should have told you, pick up a pair of flush cut cutters while your there. Worth every cent clipping supports off and the end of the filament to feed it.
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:29AM |
I've printed a new idler with a x-belt tensioner but I've yet to install it. I had all sorts of odd print quality issues that turned out to be almost entirely due to a too-loose x-belt.
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:33AM |
gadget_greg
My M5 nuts that drive the Z-axis were loose and the idler-size slips once in a while when I'm dropping Z- from a height down to home. Fortunately there's no visible effect on printing because it builds from the bottom up.I've printed a new idler with a x-belt tensioner but I've yet to install it. I had all sorts of odd print quality issues that turned out to be almost entirely due to a too-loose x-belt.
I'll be buying some spare endstops soon and they WON'T be this stoopid design.
Oh, and in a few spots you're probably have to cut some of the M3-14 bolts down to about 12mm. Do yourself a favor and put a nut on first, then cut, and use the nut to help clean the threads.
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:40AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:43AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:45AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:55AM |
gadget_greg
Oh, and if you haven't figured it out yet just (carefully) bend up the connector on the endstop to get the screw heads in there, then bend it back down.
Then I ran into the problem where I didn't know what the hell size bolts were what because nothing is labeled
Trial and error, and comparing sizes against the BOM helped with that. Then I got to the problem with the M5 nuts in the idler and motor and just heated them up and press fit them - that worked. Finally ran into the problem with the endstop. It seems *okay* but I'm not crazy about how it looks. It's fairly tight. It has a little wiggle room, but you need to put pressure on it to really shift it at all.|
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 12:56AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 01:06AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 01:10AM |
gadget_greg
Our last kid leaves for college on Wednesday, had to hit BestBuy for a couple laptops (her sister needs one for med school too), so I figured while I was in town (Albany)...
All of our endstops look like that. It IS a poor design. When I buy spare endstops they will definitely be a better design.
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 01:54AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:00AM |
gadget_greg
I'm not even employed right now.Hopefully the $$ doesn't run out. :/
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:06AM |
For me I just adjust it till it matches the holes on the z motor mount (where the z smooth rods are supposed to be).Quote
LittleMike
I'm assembling the x-carriage. That digital caliper I got only goes to 6 inches. What's the best way to measure that I have the motor and idler precisely 362mm apart? Also, it doesn't matter which end I shove in deeper, correct? Um... that sounds wrong. I mean it looks like both parts will accommodate the rods. Does it matter which side has the rods going deeper into it provided it makes 362mm?
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:09AM |
alvinhochun
LittleMike
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:10AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:11AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:12AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:18AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:21AM |
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 02:23AM |
alvinhochun
The ultimate goal is get it to run smoothly on the z-axis rods so you may still need to adjust it a bit before inserting it into the z-axis rods. Don't waste too much time on this without the z-axis.
Re: My Replikeo Prusa i3 Rework Build August 17, 2014 11:18AM |
Re: My Replikeo Prusa i3 Rework Build August 19, 2014 05:01PM |
Allnei
Check your X and Y belt tension and friction, I had similar problem when I was doing something on X carriage and put some force on it.Quote
Bratan
Guys two more question.
First, I noticed when I printed my big gear, that every level shifts slightly to the right (in X direction). What could be causing this?
Second, I've been having this annoying issue with Repetier since day 1. When I'm doing second print, it will stop heating up HotEnd. It says it's own, and I think even LED light is on but Hotend is cooling down. If I reset the board and reconnect, it starts working again. Anyone seen this issue?
Re: My Replikeo Prusa i3 Rework Build August 19, 2014 06:01PM |
Re: My Replikeo Prusa i3 Rework Build August 19, 2014 06:42PM |
Re: My Replikeo Prusa i3 Rework Build August 19, 2014 10:49PM |
I guess it makes sense, but printing process usually takes much longer than HB heating.Quote
Allnei
It is not stupid, if you heat HB (15-20min) in same time as HE (1-5min) then filament in HE will be destroyed due to high temperature for long time without extruding.
For your problem with shift, try to to send more power to motors.
Thanks, I'll try adjusting those POTs to give it more ampsQuote
underthetire
I agree with more power, also make sure your slides move freely. Without belts they should take almost no effort to move them. Make sure your hot end is tight in the extruder body as well.
Re: My Replikeo Prusa i3 Rework Build August 19, 2014 10:59PM |
Bratan
Allnei
Re: My Replikeo Prusa i3 Rework Build August 20, 2014 10:43PM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 12:40AM |
