Re: My Replikeo Prusa i3 Rework Build August 21, 2014 01:00AM |
gadget_greg
The excess is not a problem, the whole idea is that the smooth rods are parallel, at the same width on both ends, and the same width as the linear bearings attached to the heated bed mount. You can keep them slightly loose until you get the bed moving smoothly then tighten them up.
I ended up replacing my upper threaded rod on the back end with a 5/16" (or was it 3/8"?) rod that was a couple inches longer so I could install the z-stabilizer that Tech2C posted earlier in this thread. It works great! [forums.reprap.org]
Thanks!|
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 01:07AM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 01:39AM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 04:11AM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 04:13AM |
LittleMike
Looks like I've run into a roadblock. Apparently Replikeo decided to send me only 1 m3x8 grub screw. At least I think that's all they sent me. There are a total of 2 headless screws in the plastic baggies (that's them, right? Also called 'set screws?') One is tiny and dark and the other is much fatter and about 4x the length of the small one. I'm guessing one is the m3 and the other is the m8, but only one m3 instead of the 5 the BOM lists. How am I supposed to secure the couplers without them? Just for giggles, I did try and fit the tiny one into one of the holes on one of the couplers and it didn't even fit. I know that the local Home Depot sells set screws, so maybe I can try over there. The build instructions have zero pictures for that section and don't even list the grub screw's size. *sigh* I am halfway there. So close! *shakes fist*
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 04:20AM |
alvinhochun
LittleMike
For me, the couplers already have grub screws in them. I only need one m3x8 grub screw for the extruder small gear.
There are also 4 much smaller grub screws in the bag with the belts, used to secure the pulleys.
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 05:23AM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:36AM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 12:23PM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 01:12PM |
gadget_greg
Hey Bratan, sorry to hear that, that sucks. I wish I could help. I've replaced my Mega/RAMPS once already myself.
Mike, that z-endstop holder is a really poor design, which is only compounded by the poor design of the endstop itself. The only suggestion I have is to figure out a way to rig it up to work for a while (like I did) then as soon as you can print yourself one of these... [www.thingiverse.com]
Greg
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 10:47PM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:06PM |
underthetire
My z end stop fit perfectly on the stepper motor mount. Y axis never was correct. Would be nice if it was easier to adjust though.
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:12PM |
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:16PM |
alvinhochun
Easy, plug in the cable and bend the connector pins. Now you can screw the screws.
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:17PM |
Bend more. Try harder.Quote
LittleMike
alvinhochun
Yea, but you have to have the nuts on that side, not the head of the screw. The nut alone is too wide and the screws are too long. How did you get around that? I was able to do that for the X-axis, but not the Z
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:21PM |
alvinhochun
LittleMike
alvinhochun
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:23PM |
LittleMike
alvinhochun
LittleMike
alvinhochun
The endstops are cheap. I didn't want to risk snapping the connector off.
Re: My Replikeo Prusa i3 Rework Build August 21, 2014 11:29PM |
alvinhochun
LittleMike
alvinhochun
LittleMike
alvinhochun
Well if you really snap the connector off, then solder a straight connector which makes your life much easier. Or you can just keep using the zipties before you print another z endstop holder.
With the holder that Greg linked earlier, it solves that problem, though. So I'll probably just stick with the zip ties for now and just replace the holder with a better designed one.
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 12:22AM |
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 01:11AM |
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 02:10AM |
underthetire
Ya, a butter knife under it, they bend pretty well.
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 09:46AM |
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 09:49AM |
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 11:34AM |
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 11:59AM |
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 01:04PM |
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 01:34PM |
gadget_greg
I see your z-axis smooth rods are too long as are your y-axis threaded rods. Perhaps your smooth rods should be switched? I probably wouldn't do it now, but sometime in the future you'll likely do a rebuild (I'm about to) and you might want to switch them around. Until then your y-axis will be a little smaller (not really a big deal unless you plan some big prints right out of the gate).
Re: My Replikeo Prusa i3 Rework Build August 22, 2014 02:16PM |
gadget_greg
Greg
M8= 5/16", M10=3/8". Here's useful conversion chart. Made me realize that I can probably build whole thing with imperial rodsQuote
gadget_greg
I also plan to build Z-stabilizer, it could be what's causing my bad print shifts... Is Tech2C's stabilizer same as this one?|
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:23AM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:32AM |
