Re: My Replikeo Prusa i3 Rework Build August 24, 2014 11:26PM |
It happens occasionally, and I'm not the only person who this happened to (see Graig's reply above). Certainly not something that happens during actual printing, but during my manual calibration. In one instance I connected endstop incorrectly, and when homing z-axes didn't stop when it hit the glass, and by the time I pressed Emergency stop nuts were outQuote
alvinhochun
If your hotend pushes into the bed, then that's something you really should worry about instead, because it can damage the hotend or the print surface, or both.
In my opinion, it's good that the nuts actually come off, since it can reduce the chance of the hotend pushing into the print surface too hard and damaging them.
Re: My Replikeo Prusa i3 Rework Build August 25, 2014 10:31AM |
Re: My Replikeo Prusa i3 Rework Build August 25, 2014 07:42PM |
Bratan
this is quite obviously a flaw in the design...
Re: My Replikeo Prusa i3 Rework Build August 25, 2014 08:59PM |
Re: My Replikeo Prusa i3 Rework Build August 25, 2014 10:55PM |
ksb24
Hey guys! Im looking to get into 3d printing and I cant decide whether to get a replikeo prusa i3 or a printrbot simple? Both are the same price. And if you say the replikeo, what vendor is the best to buy from?
Thanks
Re: My Replikeo Prusa i3 Rework Build August 26, 2014 04:50PM |
Thanks I was wrong about it, now I see it makes senseQuote
AbuMaia
Actually it's a failsafe design. If the nuts were as secure as you think they should be, when the hotend hits the bed, it'll keep getting pulled into the bed, damaging the printer. That the nuts pop out when the hotend hits the bed keeps too much pressure from being applied to the bed, and prevents damage. Don't glue the nuts in!
I'd say go for prusa i3Quote
ksb24
Thanks
Re: My Replikeo Prusa i3 Rework Build August 26, 2014 06:14PM |
Re: My Replikeo Prusa i3 Rework Build August 26, 2014 08:34PM |
Yeah, there should be power block where you screw 4 wires from PSU and then you just plug that block into RAMPS board. Like on this picture.Quote
Repelsteler
Hi guys ,
I received my replikeo today. It was shipped via DHL (3 days from China -> Hong Kong -> Belgium) and all the parts were very well packed.
I have just a quick question about the RAMPS board. The power supply connection is a green terminal with 4 pins.
Should the other end of the terminal be included in the package or is this something missing in my box?
If not clear I can post a picture tomorrow.
Regards
Bert
Re: My Replikeo Prusa i3 Rework Build August 26, 2014 10:24PM |
Re: My Replikeo Prusa i3 Rework Build August 27, 2014 03:56AM |
Re: My Replikeo Prusa i3 Rework Build August 27, 2014 05:28AM |
Re: My Replikeo Prusa i3 Rework Build August 27, 2014 10:00PM |
Re: My Replikeo Prusa i3 Rework Build August 27, 2014 10:59PM |
Bratan
I'm trying to print with ABS that came from Replikeo with kit, but so far having strange issue. First layer sometimes prints in wavy lines. I searched for similar issue and didn't find anyone mentioning it. I tried various temperatures from 235C to 220C, best seems to be at 225C, but still fist layer is totally busted.
I suspect it could be problem with ABS material... Any suggestions? Also what temp do you use with Replikeo's black ABS?
Re: My Replikeo Prusa i3 Rework Build August 27, 2014 11:15PM |
Hmm interesting, I didn't think it could be mechanical issue... It actually happens on both axes, and seems only after I switched to ABS, but that could be coincidence (I did install Z axes stabilizer system at about the same time...)Quote
alvinhochun
Seeing that wavy line is only on one axis, I suggest you check that axis.
Re: My Replikeo Prusa i3 Rework Build August 28, 2014 09:02PM |
Re: My Replikeo Prusa i3 Rework Build August 28, 2014 11:06PM |
Blue Ice
Hello everyone...
I just purchased the aluminum Replikeo kit!
So far I have ordered a glass bed plate from McMaster-Carr, PTFE Lubricant from Amazon, Aluminum stepper driver heatsinks from Ebay, and the Intelligent Controller from Banggood.
Any other things I should get that are important?
Also, what are some cool objects to print (or ones I should use to add on to my printer)? I'm looking for something to keep my mind busy while the printer ships
Hopefully it will arrive soon!
Blue Ice
Re: My Replikeo Prusa i3 Rework Build August 28, 2014 11:43PM |
Bratan
And speaking of heated bed, get a piece of cork to insulate it from metal frame and speed up heating. Mine heats up to 60C in less than 2 minutes.
Re: My Replikeo Prusa i3 Rework Build August 29, 2014 12:03AM |
Bratan
I suggest you buy heatsinks for MOSFETs (one for HB and one for HE). I got these from eBay, they fit nicely but you can only fit two, not enough space for 3.
Bratan
And order some PLA too. PLA is nice for quick prints because you don't have to heat up bed and hot end too long.
Re: My Replikeo Prusa i3 Rework Build August 29, 2014 10:25AM |
Sheet of cork, about same size as glass. 1/4" thick or less.Quote
Blue Ice
I got a roll of PLA already- but I will order those heatsinks too. Thanks for letting me know about that.
What type of form should the cork be in? Can I use wine corks, or should I get a sheet of cork?
Re: My Replikeo Prusa i3 Rework Build August 29, 2014 05:04PM |
Bratan
Bratan
You ordered 2 sets of heatsinks? There are 10 pieces in each confused smiley I guess you'll have plenty of spares for future projects smiling smiley
Bratan
Just be careful when you put them on, make sure none of the other MOSFET's heatsinks touch each other.
Re: My Replikeo Prusa i3 Rework Build September 01, 2014 10:21PM |
Re: My Replikeo Prusa i3 Rework Build September 01, 2014 11:21PM |
Re: My Replikeo Prusa i3 Rework Build September 02, 2014 12:00AM |
Re: My Replikeo Prusa i3 Rework Build September 02, 2014 12:47AM |
LittleMike
I think I figured out my problem. Or at least one of them. Someone please clarify for me, if looking at the printer from the front, which way is the y-carriage oriented? Is the side with the two bearings on the left or the right? Also, which side is the motor mounted to, the left or right? I think I have my y-carriage flipped 180 and the y-holder is hitting up against the motor.
LittleMike
Also, is the y motor mounted in the front or the back? Or can you put it in either place?
AbuMaia
LittleMike
Should I move the zipties closer? I can't figure out why I don't have enough room. Pics attached.
Yes. Either use one zip tie on each side, or put them side by side, and trim off the excess belt.
Re: My Replikeo Prusa i3 Rework Build September 02, 2014 12:52AM |
alvinhochun
LittleMike
Doesn't really matter, it should be mostly symmetrical.
Though I see that in your photo the y-belt is aligned at the bottom of the belt holder, you may want to make it align to the top.
Also, make sure that the y-axis smooth rods has snapped into the y-corners. I needed to apply some force for it to snap in place.
LittleMike
Technically, either will work, but you might want all the wires to go through the rear end so you may prefer it being in the rear.
AbuMaia
It's not symmetrical. The "bumps" that hold the y-belt will stop at the motor if it's on the wrong side. Well, I guess you could put the carriage either direction, but the motor would have to go on the other, so in a way symmetrical, in a way not. Haha.
Any particular reason why I should align them to the top? You mean the way the loop goes, correct? I was just following the images in the build manual. Which seems to have gotten me into almost all the trouble I've had in this build with things being backwards.
Yea, I'm moving it to the rear. It seems to make more sense that way. I also have to flip the endstop then, I think, no?
LittleMike
Using two zip ties feels more secure, in case one of them fails. But try to keep them as close as possible.
Re: My Replikeo Prusa i3 Rework Build September 02, 2014 02:47AM |
LittleMike
LittleMike
LittleMike
Okay, I will trim them down. I have them off now to adjust the motor and everything, but they seemed to catch. They would go smooth in one direction, but when I tried the other direction, they would "skip" so to speak. Same with x-carriage belt. Why is that?
Re: My Replikeo Prusa i3 Rework Build September 04, 2014 06:43AM |
Re: My Replikeo Prusa i3 Rework Build September 04, 2014 06:07PM |
Repelsteler
Hi ,
Can anyone point me in a direction for auto bed levelling for the replikeo?
Thanks
Bert
Re: My Replikeo Prusa i3 Rework Build September 04, 2014 06:11PM |
Blue Ice
Repelsteler
Hi ,
Thanks
Bert
Never worked with a 3D printer before, but I've seen that this design is popular: http://www.thingiverse.com/thing:182889
And a video for installation is here: https://www.youtube.com/watch?v=awsI9bMndJA
I might try it sometime, so I think it is a good idea.
Re: My Replikeo Prusa i3 Rework Build September 04, 2014 06:59PM |
LittleMike
Blue Ice
Repelsteler
Hi ,
Thanks
Bert
That page says there is a new better way here:
[www.thingiverse.com]
Please note, I have not tried either method. Just pointing that out.
