Re: My Replikeo Prusa i3 Rework Build September 05, 2014 06:53AM |
Re: My Replikeo Prusa i3 Rework Build September 05, 2014 05:42PM |
Blue Ice
Repelsteler
Hi ,
Can anyone point me in a direction for auto bed levelling for the replikeo?
Thanks
Bert
Never worked with a 3D printer before, but I've seen that this design is popular: http://www.thingiverse.com/thing:182889
And a video for installation is here: https://www.youtube.com/watch?v=awsI9bMndJA
I might try it sometime, so I think it is a good idea.
Re: My Replikeo Prusa i3 Rework Build September 06, 2014 11:48PM |
Allnei
Blue Ice
Repelsteler
Hi ,
Thanks
Bert
These links are for Prusa i3, but we have Prusa i3 rework with different extruder. Right auto bed leveling mount is this [www.thingiverse.com] or similar. I am using this design without problems.
Re: My Replikeo Prusa i3 Rework Build September 07, 2014 02:34AM |
Re: My Replikeo Prusa i3 Rework Build September 07, 2014 05:35AM |
Re: My Replikeo Prusa i3 Rework Build September 08, 2014 03:11AM |
Re: My Replikeo Prusa i3 Rework Build September 08, 2014 04:58AM |
Re: My Replikeo Prusa i3 Rework Build September 08, 2014 12:23PM |
Re: My Replikeo Prusa i3 Rework Build September 10, 2014 01:48AM |
Re: My Replikeo Prusa i3 Rework Build September 10, 2014 05:10AM |
Re: My Replikeo Prusa i3 Rework Build September 10, 2014 09:35AM |
Re: My Replikeo Prusa i3 Rework Build September 11, 2014 05:20PM |
Re: My Replikeo Prusa i3 Rework Build September 11, 2014 07:31PM |
Re: My Replikeo Prusa i3 Rework Build September 11, 2014 07:54PM |
Joe2014
Just got a text from DHL. My kit shall arrive tomorrow! Just in time for the weekend. I'll probably post my thoughts during the build, possible some video logs. I'm excited! Hopefully nothing was damaged in shipping...
Re: My Replikeo Prusa i3 Rework Build September 11, 2014 09:12PM |
Orion
Hi
I have a problem about endstop.
I homing y axis by Printrun heated bed move to endstop but it doesn't stop !!!
I check that endstop by using volt meter. but it's OK (sending signal correctly)
What's the problem ?
ps. x axis endstop work fine
z axis endstop I didn't check yet. I worried that if it didn't work hotend would hit heatd bed.
Re: My Replikeo Prusa i3 Rework Build September 12, 2014 04:10AM |
SteveRoy
Orion
Hi
Is it defind in Marlin as a MIN or MAX endstop?
Is it on the correct pins on the RAMPS?
Steve
Re: My Replikeo Prusa i3 Rework Build September 12, 2014 12:18PM |
Re: My Replikeo Prusa i3 Rework Build September 12, 2014 07:04PM |
Re: My Replikeo Prusa i3 Rework Build September 12, 2014 07:12PM |
Re: My Replikeo Prusa i3 Rework Build September 12, 2014 07:21PM |
Re: My Replikeo Prusa i3 Rework Build September 12, 2014 10:42PM |
jakeanderson91
Hey Guys,
Basically the problem i am having now is that when i home the Z axis it just continues going up, even after it hits the smooth rod supports at the top, and it actually broke one and i had to super glue it back together.
then after it stops i cant go back down I either have to turn the motors off and manually turn the threaded rods to move it down, or switch the Z direction and move it down by clicking the the Z up direction in pronterface.
any help would be greatly appreciated.
Re: My Replikeo Prusa i3 Rework Build September 13, 2014 11:36AM |
Re: My Replikeo Prusa i3 Rework Build September 13, 2014 02:27PM |
Re: My Replikeo Prusa i3 Rework Build September 13, 2014 08:19PM |
Re: My Replikeo Prusa i3 Rework Build September 14, 2014 12:57AM |
Re: My Replikeo Prusa i3 Rework Build September 14, 2014 05:16PM |
Re: My Replikeo Prusa i3 Rework Build September 14, 2014 07:23PM |
Re: My Replikeo Prusa i3 Rework Build September 14, 2014 07:27PM |
Re: My Replikeo Prusa i3 Rework Build September 14, 2014 11:56PM |
LittleMike
Oh, and my y-belt holder keeps hitting into the motor. It's kind of hard to see in the picture
KidAircrash
Hey guys, I've run into some more trouble. I was just getting to the electronics and wiring stage and I realized that my x axis shouldn't be resting at the bottom. I'm probably overlooking something, but I think that the holes that the threaded rods that go through on the x end idler and x end motor might be too loose. Can you recommend a solution?
Thanks,
Alex
[www.youtube.com]
Re: My Replikeo Prusa i3 Rework Build September 15, 2014 12:08AM |
