Re: My Replikeo Prusa i3 Rework Build March 07, 2015 09:49PM |
Ano
Oh nice, thanks for that link!
I tried some more settings for my bowden setup, but I think I'll change back to the direct method. But I will replace the wade extruder for a direct drive one, just for the looks of it ^^
Thinking about letting the PTFE tube in place to guide my filament from the spool to the extruder, though.
Re: My Replikeo Prusa i3 Rework Build March 08, 2015 07:42AM |
Re: My Replikeo Prusa i3 Rework Build March 08, 2015 08:25PM |
psneddon
Blue Ice
Thanks again. I'll check mine over once I receive it in the mail.
I received my MK2B heated bed and hooked up the wires to it and measured the resistance and I'm getting 2.6 ohms. Most of the information I've read about this heated bed states that the resistance should be 1.2 to 1.3 ohms. Is this correct?
I have the negative lead hooked to pad #1 and the positive lead hooked to pad #2 for a 12 volt supply - as stenciled on the heated bed.
I haven't hooked it up to any power yet and definitely not to my Ramps board until I test it. I have a DC power supply that can put out 3 amps of power at 12 volts, but I think the bed can take a higher current - is that so?
Re: My Replikeo Prusa i3 Rework Build March 09, 2015 09:43AM |
mr.sneezy
psneddon
Blue Ice
Did you short out pads two and three to change the two heater loops from series for 24V to parallel for 12V, if not it would explain why your bed is at half power ?
I have the MK2B as well, and the diagram on mine shows pad one is positive, and two and three negative for 12V (hence 2 &3 are shorted together with a wire link). Polarity would only matter for the LED's, or they wont light up.
Martin
Re: My Replikeo Prusa i3 Rework Build March 09, 2015 10:56AM |
I'm gonna give it a try. I decided to skip this and go straight to bowden drive, and failed... It won't push filament for some reason, so I'm going to try direct driveQuote
Ano
@Bratan: I have mounted a MK8 direct drive right now and even when the rest of my setup is far from great, the MK8 never failed. And that, after several people in this forum told me, that my MK8 version sucks XD (german thread: link)
My hobbed bolt worked, too, but I wanted to try a direct drive one =)
Some issues, but I wanted to lighten up weight and bulk, and maybe even gain some speedQuote
Blue Ice
I don't know. My extruder is working great with the hobbed bolt and the gears, ever since I put in spacers instead of springsAre you having issues with yours?
Re: My Replikeo Prusa i3 Rework Build April 01, 2015 03:38AM |
Re: My Replikeo Prusa i3 Rework Build April 05, 2015 06:30AM |
Re: My Replikeo Prusa i3 Rework Build May 03, 2015 11:03PM |
Re: My Replikeo Prusa i3 Rework Build May 04, 2015 04:16PM |
Re: My Replikeo Prusa i3 Rework Build May 04, 2015 11:41PM |
Re: My Replikeo Prusa i3 Rework Build May 05, 2015 04:14PM |
Re: My Replikeo Prusa i3 Rework Build May 06, 2015 04:24PM |
Re: My Replikeo Prusa i3 Rework Build May 08, 2015 12:22PM |
Re: My Replikeo Prusa i3 Rework Build May 09, 2015 06:14PM |
Re: My Replikeo Prusa i3 Rework Build May 10, 2015 01:08AM |
Re: My Replikeo Prusa i3 Rework Build May 10, 2015 07:52AM |
Re: My Replikeo Prusa i3 Rework Build May 11, 2015 08:39AM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2015 10:06PM |
Re: My Replikeo Prusa i3 Rework Build May 26, 2015 03:50AM |
Re: My Replikeo Prusa i3 Rework Build May 26, 2015 08:11AM |
Re: My Replikeo Prusa i3 Rework Build May 27, 2015 05:36AM |
Re: My Replikeo Prusa i3 Rework Build May 27, 2015 02:44PM |
Re: My Replikeo Prusa i3 Rework Build May 28, 2015 03:29AM |
Re: My Replikeo Prusa i3 Rework Build May 28, 2015 05:23PM |
Trike
I just got my Replikeo Aluminum i3 kit. Not bad. SAL shipping took two weeks to get to Washington state. The package looked it went through hell and back. I started taking inventory to see if anything got damaged. Admittedly I was a little apprehensive from ordering, because there are no reviews of this vendor. Since the design is based off the BOM listed on reprap and not a modified i3 design, I felt I could get support through here with the large user base. My first initial impressions of the kit are very good. There were only 4 parts damaged. The glass bed, X end idler, y idler, and fan duct. I have already contacted Replikeo about the received package condition and damaged parts. They responded right away and will be sending me replacement parts today. They also said they're going to beef up the packaging for future orders. Instead of a glass bed, they're going to send me a 1mm carbon plate. They said they're having good luck with it. So far, after sales support has been excellent. It'll probably take another two weeks to get it. Once I get some time, I'll start the build. I already purchased a E3D hotend as a first upgrade and I'll use the J-head as a backup or use it as a second head later on.
This is my first 3D printer, and I researched the reworked i3 with alum. frame and priced parts by myself. Even after the shipping cost, I just couldn't beat Replikeo's price. I waffled between this and the i3xl from diytechshop. I ended preferring this.
Since this is my first printer, I'm not sure what a "good" print looks like. I noticed some slight separation on some parts, but nothing a little CA can't fix.
Here are some pics:
Re: My Replikeo Prusa i3 Rework Build May 28, 2015 07:05PM |
Re: My Replikeo Prusa i3 Rework Build May 29, 2015 01:35PM |
Re: My Replikeo Prusa i3 Rework Build May 29, 2015 06:16PM |
No, everz new printer gets injected molded parts (only extruder bodz is still printed I think). This fotos are from an older version.Quote
tomleeds
OMG This is Replikeo printer? i see very poor printed parts. As i know replikeo is selling parts from injected abs. Anyway, from my experience your first print after calibration must be extruder. I think that orinal extruder is printed with 50% infill and will be damaged soon.
lurch68b
Hi all, I got min a couple weeks ago and so far it has been a lot of fun, I mean frustration, at least when I have time to work on it it is. So let me ask a stupid question about the home spot for the HE. 0,0,0 is supposed to be at the end stops, that would mean the HE is at its lowest position to the right front corner of the HB, at the xyz endstops? And just so that I can make sure all is clear, when you click in pronterface X, Y, Z+ that axis should move towards the mechanical end stops or the other way. Sorry if this was answered later in this thread, just started reading it the other day and it has been a wealth of knowledge but I would really like to make some progress on this thing before I toss it out the window.
Oh, and I did get my unit with no damage even though it looked like Ace Ventura had delivered it. You think China Postal uses that movie for a training video?
Re: My Replikeo Prusa i3 Rework Build May 29, 2015 07:16PM |
lurch68b
Re: My Replikeo Prusa i3 Rework Build May 30, 2015 12:02AM |
Blue Ice
lurch68b
Welcome to the community! Hopefully we can help you figure out the frustrating problems!
I'm seconding what Ano put. My zero spot is in the back right. I took a quick picture last night of what my printer looks like when zeroing, which might help.
Let us know if you need help with anything else
Re: My Replikeo Prusa i3 Rework Build May 30, 2015 10:28AM |
lurch68b
Thanks guys, my y end stop is in back. Why did you guys put it int he front?
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1So for you I think the y should then be +1 instead of -1.
