Re: My Replikeo Prusa i3 Rework Build May 31, 2015 02:28AM |
Re: My Replikeo Prusa i3 Rework Build June 01, 2015 12:51PM |
Ano
lurch68b
Thanks guys, my y end stop is in back. Why did you guys put it int he front?
Well... Don't know =) The pictures I saw had it on the front. Really doesn't matter though. You just need to have the same physical and software configuration.
Should be this lines in marlin:
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1So for you I think the y should then be +1 instead of -1.
Re: My Replikeo Prusa i3 Rework Build June 04, 2015 07:18AM |
Re: My Replikeo Prusa i3 Rework Build June 04, 2015 08:27AM |
Re: My Replikeo Prusa i3 Rework Build June 04, 2015 10:12AM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2015 01:26PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2015 03:55PM |
Thanks for the info. Well, I tried Bowden (see some of the last pages), but wasn't able to reduce the oozing to an acceptable state. So I went back to the standard direct wade extruder.Quote
tomleeds
You mean, when you start your printer, it shows 0|0|0 as position, wherever the nozzle may be at time of starting? That's normal. But when you select the home command, it should go to the corner you chose. What exactly happens, if you chose to activate the homing?Quote
lurch68b
Confused has been my middle name when it comes to this thing. I haven had any time to work on it since my last post. I did talk to some one at work here and he mentions making user the the coordinates system is setup for relative or absolute or some such thing. I think I have been having an issue that it thinks it is at home position when it is turned on no matter where the head is at. So if it is in the middle of the bead it thinks. Have not been able to look at it and check but does that sound right? Sounds right to me but what do I know??
I hope to have time this weekend and next week to work on it.
Anyone have any luck printing from a PC yet, I saw earlier that people had to use an SD card, I need to buy the display/SD card module.
Re: My Replikeo Prusa i3 Rework Build June 15, 2015 08:33AM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2015 03:38PM |
Ano
tomleeds
lurch68b
Re: My Replikeo Prusa i3 Rework Build June 15, 2015 10:33PM |
lurch68b
Ano
tomleeds
lurch68b
It does seem to home but it don't stop when it gets to the end stops. And when I try to move them away from the end stops it some times wont move and I get the message, endstop hit.
Re: My Replikeo Prusa i3 Rework Build June 17, 2015 01:33AM |
Re: My Replikeo Prusa i3 Rework Build June 18, 2015 12:19AM |
Re: My Replikeo Prusa i3 Rework Build June 18, 2015 02:31AM |
Re: My Replikeo Prusa i3 Rework Build June 18, 2015 11:22AM |
Blue Ice
RRuser, sorry, I have the aluminum frame.
lurch68b,
I'm a little confused about what you mean with the heatbed. Are you saying that you set it for a temperature higher that 60 degrees C, but it stops at 60 degrees C? Or are you saying that you set it for 60 degrees C, but it continues to increase even after it reaches 60 degrees C? Either way, it seems like a problem that we can figure out for you. Thanks.
The filament being stuck in the print head should be easily fixed by heating the hotend to ~190 degrees C, and either PLA or ABS should be able to be pulled out from the feed in side.
Re: My Replikeo Prusa i3 Rework Build June 19, 2015 10:07PM |
Re: My Replikeo Prusa i3 Rework Build June 19, 2015 10:17PM |
lurch68b
Blue Ice
lurch68b,
Sorry, what I mean is that when I try to print that the heat bed seems to go into a thermal run away state, I let it hit 114C and it was still climbing before I aborted. But when I tested to make sure that the hb is working by manual setting it, it maintains the set temperature as expected. I was able to clean the HE, had to pull it apart and clean out the tube manually.
Speaking of printing, when you click print does the print job start after the hb and he reach a stable temprature?
Never mind, the issue was that I didn't have the rite settings in slicer. Now I am having a problem in the Z axis. After homing the z axis goes up, raises the print head, then it acts like it gets stuck. The motors keep trying to raise the axis. I can lift it by hand.
Re: My Replikeo Prusa i3 Rework Build June 19, 2015 11:37PM |
clone
lurch68b
Blue Ice
lurch68b,
Yes, I had a similar problem (kinda of opposite) where the printer would never start even when pronterface temp was reached. I have problems inporting STL file to pronterface so made the g-code first in Slic3r, but realised the temps in slic3r were higher so it was never getting to setpoint. With the z-axis, when you lift it out of the nuts, do the motors start to spin freely?
Re: My Replikeo Prusa i3 Rework Build June 21, 2015 01:31AM |
Re: My Replikeo Prusa i3 Rework Build June 21, 2015 01:38AM |
clone
Hi All,
Have been reading this thread for a while now, and have now ordered and build one of these.
Mechanically everything seems to be OK, except the extruder.
I raised the z-axis and am trying to manually extrude ABS, but it always gets jammed. If I set it to extrude by say 50mm, as long as I apply downward pressure on the filament by hand whilst the bolt is turning, it will extrude, but as soon as I release the pressure, it starts slowing down until a complete stop.
Without the downward pressure, the bolt eventually chews up the filament. I have tried increasing the temp to 240degC, tried loosening/tightening the hobbed bolt bearing. When it gets jammed and I pull it out, it appears to bulge. I've attached photos of the bolt chew, ABS bulge and fan position. Anybody have any ideas? Maybe the hotend is partially blocked?? The filament tends to curl up as it comes out of the nozzle. Maybe even the quality of the ABS Replikeo send perhaps?
Any help from experienced extruderists would be greatly appreciated.
Re: My Replikeo Prusa i3 Rework Build June 21, 2015 04:38AM |
Blue Ice
clone
Hi All,
I had the exact same problem when I started out with my RepRap. I had the same bulging piece on the filament and tried everything, like you did. The only thing that worked at the time for me was pinching the extruder shut more tightly (by hand).
In the end, I decided that the design of the printer was not working for me. Long story short, I ended up switching the long M3 screws with springs that squeeze the extruder shut for shorter M3 x 25mm screws with washers that press directly up against the plastic (no springs). This caused the extruder to pinch tightly enough against the filament, and I continue to use it today with ABS and PLA because it is repeatable and works each time.
I would definitely recommend doing that; it's worked a charm for me so far.
Re: My Replikeo Prusa i3 Rework Build June 21, 2015 02:51PM |
clone
Blue Ice
clone
Hi All,
That's great news, I will definitely try that and see how I go. Also, I was constantly browsing your build thread and crosschecking as I was building the machine, was super helpful. So thank you very much for all the help you have provided.
Re: My Replikeo Prusa i3 Rework Build June 27, 2015 01:54AM |
Re: My Replikeo Prusa i3 Rework Build June 28, 2015 09:13PM |
Re: My Replikeo Prusa i3 Rework Build June 28, 2015 11:09PM |
clone
Hi Blue Ice. I didn't have the correct length screw and just decided to trim the long screw down a bit so the springs would be a lot tighter. This worked well, extruding was much better and uniform. So I started to print a cube, about a third of the way though, the extruder motor started stuttering and would stop the stuttering if I applied a small rotational force to the gear to help. In the end, the filament got chewed again. So I took it out, cleaned all the debris, and increased the motor pot by about an 1/8. Now I tried again and it worked, didn't have any troubles extruding throughout the print. Again thankyou for the advice. Only thing I need to look into now is it printed x and y at more or less 20cm, but only printed 15cm high. Regardless, I am rapped that I have actually finally printed something.
Edit: 20mm I meant. I think all I need to do is modify the steps per mm in the firmware.
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,607}
Re: My Replikeo Prusa i3 Rework Build June 28, 2015 11:41PM |
Re: My Replikeo Prusa i3 Rework Build June 29, 2015 02:36PM |
Re: My Replikeo Prusa i3 Rework Build June 29, 2015 04:53PM |
#define DEFAULT_MAX_FEEDRATE {500, 500, 1, 25}line. If the feedrates are to high, the motor will not turn or turn incorrectely. I think your
Re: My Replikeo Prusa i3 Rework Build June 30, 2015 06:35AM |
Blue Ice
clone
All right! That's awesome that you got it to work!
It seems like your problem with height could be caused by an incorrect value for the DEFAULT_AXIS_STEPS_PER_UNIT value in Marlin. If you get stuck, here's mine:
That's great that you're making progress! Calibration is the hard part, and then you have a working 3D printer
Re: My Replikeo Prusa i3 Rework Build July 05, 2015 01:08AM |
Re: My Replikeo Prusa i3 Rework Build July 16, 2015 09:16AM |
