Re: My Replikeo Prusa i3 Rework Build September 17, 2015 10:00PM |
Re: My Replikeo Prusa i3 Rework Build September 19, 2015 12:40AM |
Re: My Replikeo Prusa i3 Rework Build September 20, 2015 08:29AM |
Re: My Replikeo Prusa i3 Rework Build September 21, 2015 08:01AM |
Re: My Replikeo Prusa i3 Rework Build September 25, 2015 04:57PM |
Re: My Replikeo Prusa i3 Rework Build September 26, 2015 01:14AM |
Re: My Replikeo Prusa i3 Rework Build September 26, 2015 01:31AM |
Re: My Replikeo Prusa i3 Rework Build September 26, 2015 08:20AM |
Re: My Replikeo Prusa i3 Rework Build September 27, 2015 09:41AM |
Re: My Replikeo Prusa i3 Rework Build September 27, 2015 11:01AM |
Re: My Replikeo Prusa i3 Rework Build September 27, 2015 01:00PM |
Re: My Replikeo Prusa i3 Rework Build September 27, 2015 06:33PM |
Re: My Replikeo Prusa i3 Rework Build September 29, 2015 03:53PM |
Re: My Replikeo Prusa i3 Rework Build October 29, 2015 07:56PM |
Re: My Replikeo Prusa i3 Rework Build October 30, 2015 05:30AM |
Re: My Replikeo Prusa i3 Rework Build October 30, 2015 08:22PM |
Re: My Replikeo Prusa i3 Rework Build November 05, 2015 04:20PM |
Re: My Replikeo Prusa i3 Rework Build November 08, 2015 10:26PM |
Qdeathstar
I have to say, i am happy with this printer, i feel it is a good choice for a beginner. The only immidiate upgrades i would recommend is the MK3 heatbed, and the proximity sensor on the z axis, not just for auto leveling, but because it helps put the extruder in exactly the right spot everytime without having to worry about a springy zstop switch. Most of the things i got as an "upgrade" ended up being downgrades... i printed out some antibacklash things for my printer, and they just made it noisy, with no difference in print quality...... and they made my heatbed too low because they went under the crossbar....
The stock hotends were actually pretty good, i got the chimera, but i had to tinker with it a lot to get it right... I'm sure if i didn't dismiss the stock hotends righ away, i could have gotten those working aswell, as getting one to work was actually easier than getting one of the chimera's hotends to work (jamming).
I'll post some pics of my printer in its final (for now) state after i finish calibrating the thermistors.
Re: My Replikeo Prusa i3 Rework Build November 18, 2015 01:27PM |
Re: My Replikeo Prusa i3 Rework Build December 01, 2015 04:54PM |
owaisshaf
1.I cant seem to get my nylon stop nut all the way to the washer/bearing in my extruder assembly.
The Hobbed bolt isn't threaded all the way and the nut stops at the thread.
2. I'm using m3x14 mm screws for my heated bed mount. Its a little too long, is that okay? I've shown both possible variations in the image. Can i apply either one or none?
3. Lastly my X axis smooth rods, protrudes out from the x axis idler by a few cms. Had to let this happen to align it right. It isn't lose. Should i worry about this?
I am attaching some images, It'd be great if someone could tell me what I'm doing wrong.
Re: My Replikeo Prusa i3 Rework Build December 01, 2015 06:29PM |
Re: My Replikeo Prusa i3 Rework Build December 02, 2015 05:08PM |
Re: My Replikeo Prusa i3 Rework Build December 14, 2015 12:05PM |
Re: My Replikeo Prusa i3 Rework Build December 21, 2015 09:10AM |
Ano
owaisshaf
1) This seems odd. Normally it should be threaded a bit longer. You can however use some more washers on this side, if you have some.
2) It worked for me. The screw head must be on the upper side, because the heated bed will be mounted on top, so there is little space there.
3) What exactely do you mean by this, sry can't imagine the situation right now.
I used washers and it worked just fine.
I'm in the last stages, well I'm done to be honest but i have two problems which will just not sort themselves out
1) My extruder, doesn't extrude. When i put the command on ponterface, the motor moves, but the plastic spool doesn't get pulled in. I tried all sorts of things to only achieve the best result of a small blob of plastic coming out and consequently staying fixed to the extruder.
2) My Y axis refuses to move, my y-belt isn't the tightest, could that be a problem.
3) How do i calibrate the end stops, can anyone please share their marlin config and what version of arduino, they're running it in. I used the replikeo one that was shared in the earlier posts
Still haven't managed a first print
Re: My Replikeo Prusa i3 Rework Build December 21, 2015 03:15PM |
//=========================================================================== //=============================Mechanical Settings=========================== //=========================================================================== // Uncomment the following line to enable CoreXY kinematics // #define COREXY // coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // Disable max endstops for compatibility with endstop checking routine #if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS) #define DISABLE_MAX_ENDSTOPS #endif // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled #define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 190 #define X_MIN_POS 0 #define Y_MAX_POS 180 #define Y_MIN_POS 0 #define Z_MAX_POS 190 #define Z_MIN_POS 0The last values are for my printer, as my setup doesn't allow full 200x200 mm, because my heated bed is attached with clamps.
Re: My Replikeo Prusa i3 Rework Build December 29, 2015 11:51AM |
Re: My Replikeo Prusa i3 Rework Build January 06, 2016 05:39AM |
Re: My Replikeo Prusa i3 Rework Build January 07, 2016 05:12AM |
Re: My Replikeo Prusa i3 Rework Build January 07, 2016 10:15AM |
tomleeds
Hi Riccardo,
The might be several problems. So follow steps
1, if you are using driver A4988, check current which is going to motors , especially Y motor have this problem. normal current is between 0.5 - 0.8
2, Check your marlin settings in configuration.h. There should be feedrate , max acceleration. see wiki page of replikeo: [wiki.replikeo.com] (post here your configuration.h file.)
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,600}
#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 25}
#define DEFAULT_MAX_ACCELERATION {2000,2000,20,1000}
3, Check if you motor connector to RAMPS are inserted well.
4, insert driver with correct position
Are you using RAMPS 1.4
Are U using pololu A4988 or/and DVR (if U don't know, post here pictures of electronic)
Re: My Replikeo Prusa i3 Rework Build January 08, 2016 12:19AM |
