Re: My Replikeo Prusa i3 Rework Build June 18, 2014 01:35PM |
Re: My Replikeo Prusa i3 Rework Build June 19, 2014 10:52AM |
Re: My Replikeo Prusa i3 Rework Build June 19, 2014 05:43PM |
Re: My Replikeo Prusa i3 Rework Build June 19, 2014 05:45PM |
Re: My Replikeo Prusa i3 Rework Build June 20, 2014 12:21AM |
Re: My Replikeo Prusa i3 Rework Build June 20, 2014 04:41AM |
Re: My Replikeo Prusa i3 Rework Build June 20, 2014 06:32AM |
Re: My Replikeo Prusa i3 Rework Build June 20, 2014 01:16PM |
McCringleberry
1- I've been using the guide here, plus the pictures on Replikeo.com as a guide. I got the plexiglass 6mm version, which came with 2 additional plexiglass pieces that fit into the back of the main z-axis frame and the top threaded rod in the back of the y-carriage slips through a notch on each piece and is secured with bolts. I haven't seen that mentioned anywhere here, so I was wondering if they're unique to the plexiglass model.
Re: My Replikeo Prusa i3 Rework Build June 20, 2014 03:21PM |
Re: My Replikeo Prusa i3 Rework Build June 21, 2014 09:41AM |
Re: My Replikeo Prusa i3 Rework Build June 22, 2014 02:03AM |
Re: My Replikeo Prusa i3 Rework Build June 22, 2014 04:03AM |
Re: My Replikeo Prusa i3 Rework Build June 22, 2014 06:35AM |
Re: My Replikeo Prusa i3 Rework Build June 22, 2014 09:06AM |
Re: My Replikeo Prusa i3 Rework Build June 23, 2014 01:12PM |
Re: My Replikeo Prusa i3 Rework Build June 23, 2014 02:15PM |
Re: My Replikeo Prusa i3 Rework Build June 23, 2014 02:21PM |
Can you take some pictures? About an inch of tie sounds about normal... But you can probably shorten it.Quote
McCringleberry
Thanks for everyone's help so far. I've gotten a lot done in the limited time I've had lately. Here's a probably stupid question that hopefully someone could answer if you have fre time:
- Before I installed the y-axis belt, the bed his the endstop just fine. Now that I've got the belt on, the zip tied pars on the top of the belt get caught on the motor or the y-idler before the carriage gets to the ends. I've got about a inch of belt tied up on each end, with the y belt holder facing right (the side with two bearings), and the motor mounted to the back right, pointed left. Do I need to shorted the ends of the belt and put the zip ties closer together? I have the ends of the belt looped through the top of the clete and wrapping around and up again to tie of, which puts them in line with going into the motor or idler at the top. I left the belt a little loose and coult shorter the excess ends. I think that'll solve the problem, but it seems weird that the fixtures at both ends would eath the zip ties so easily.
Any advice is appreciated!
Re: My Replikeo Prusa i3 Rework Build June 23, 2014 05:03PM |
Re: My Replikeo Prusa i3 Rework Build June 23, 2014 05:05PM |
Re: My Replikeo Prusa i3 Rework Build June 23, 2014 05:10PM |
Re: My Replikeo Prusa i3 Rework Build June 23, 2014 08:54PM |
Re: My Replikeo Prusa i3 Rework Build June 24, 2014 01:16AM |
Re: My Replikeo Prusa i3 Rework Build June 24, 2014 03:30AM |
Re: My Replikeo Prusa i3 Rework Build June 24, 2014 09:08AM |
Re: My Replikeo Prusa i3 Rework Build June 24, 2014 09:27AM |
Re: My Replikeo Prusa i3 Rework Build June 24, 2014 03:04PM |
Re: My Replikeo Prusa i3 Rework Build June 24, 2014 05:16PM |
Re: My Replikeo Prusa i3 Rework Build June 24, 2014 08:05PM |
Re: My Replikeo Prusa i3 Rework Build June 25, 2014 02:25AM |
Re: My Replikeo Prusa i3 Rework Build June 25, 2014 11:07AM |
Thanks Alllnei! I'll give it a try! I do have nozzle diameter set to 0.4mm in the Slic3r.Quote
Allnei
Bratan, it looks like that your layers are too thick. Print with 0.3 first layer and 0.2 other layers. Also make sure, that you have set correct nozzle diameter in Slic3r
Gotta revert to original setting,but I also might have issue with extruder part. I used only one screw with spring and filament pushed to the side and broke small piece of plastic that was guiding filament. It's probably not a big deal, but I wanted to ask, do you guys tighten extruder screws as tight as possible or it doesn't matter?Yeah print that Spool holderQuote
gadget_greg
I changed my settings to 0.3 first-layer and 0.2 other layers and at first I was pretty excited, it was coming out great! I walked away for a while and when I came back it had shifted but this time in the y-axis?!? I really have to hang my filament spool to eliminate that as a variable. :/
I plan to do that as soon as I'm able to start using printer
Also make sure your printer is on a steady surface. I put mine on portable table and it was shaking like a dryer machine...
