Re: My Replikeo Prusa i3 Rework Build June 29, 2014 02:12AM |
gadget_greg
Thanks for all that! I'm printing with PLA, my fan is on D9, and it is running non-stop.
Also, I did an extrusion test and no matter how high I seem to set the steps-per-mm I'm still getting between 73mm and 82mm when I call for 100mm. I must be missing something.
Re: My Replikeo Prusa i3 Rework Build June 29, 2014 02:50PM |
Re: My Replikeo Prusa i3 Rework Build June 30, 2014 08:26AM |
Re: My Replikeo Prusa i3 Rework Build June 30, 2014 02:29PM |
Re: My Replikeo Prusa i3 Rework Build June 30, 2014 03:19PM |
Thanks for the lube advise!Quote
gadget_greg
For lubrication: [www.reprap.org]
I've been using a silicone lube or Duralube. The silicone is more of a penetrating-type lube, whereas the Duralube is more of a PTFE-type lube.
I'm not sure where you're talking about on the spool holder but there was a light layer printed adjacent to the bearing, creating a barrier between the bearing and where the shaft runs. I just cut it away. I also had to trim with my dremel to get the bearing to fit properly. It works get though!
Did you have any luck getting your extrusion right? I'm getting between 72 and 82 mm extruded when I called for 100, no matter how I set the steps per mm. :/
Check/redo your header connectors. I had headers broken/loose on 3!!! stepper motors.Quote
esponda
I received my kit last week, finally. Everything is ok, I just got a bad stepper ( no continuity in 1 coil) ; anyone received a bad part and got a replacement as soon as you report it to them?
Re: My Replikeo Prusa i3 Rework Build June 30, 2014 04:39PM |
Re: My Replikeo Prusa i3 Rework Build June 30, 2014 05:05PM |
Re: My Replikeo Prusa i3 Rework Build June 30, 2014 05:23PM |
Re: My Replikeo Prusa i3 Rework Build June 30, 2014 05:25PM |
Yes, I had some issues, but considering price I'd say it's worth it.Quote
Rayton
Thanks. Has the kit in general worked out well for you?
Re: My Replikeo Prusa i3 Rework Build July 01, 2014 05:26PM |
Re: My Replikeo Prusa i3 Rework Build July 02, 2014 03:49AM |
Re: My Replikeo Prusa i3 Rework Build July 03, 2014 12:30AM |
Re: My Replikeo Prusa i3 Rework Build July 03, 2014 02:07AM |
Re: My Replikeo Prusa i3 Rework Build July 04, 2014 01:54AM |
Re: My Replikeo Prusa i3 Rework Build July 05, 2014 06:28AM |
Re: My Replikeo Prusa i3 Rework Build July 05, 2014 12:44PM |
Maybe the y-endstop extender too...
Re: My Replikeo Prusa i3 Rework Build July 05, 2014 10:20PM |
Re: My Replikeo Prusa i3 Rework Build July 05, 2014 11:35PM |
Re: My Replikeo Prusa i3 Rework Build July 06, 2014 04:47AM |
Re: My Replikeo Prusa i3 Rework Build July 06, 2014 01:31PM |
Re: My Replikeo Prusa i3 Rework Build July 06, 2014 08:08PM |
Re: My Replikeo Prusa i3 Rework Build July 07, 2014 03:47AM |
Re: My Replikeo Prusa i3 Rework Build July 07, 2014 12:09PM |
Re: My Replikeo Prusa i3 Rework Build July 07, 2014 11:30PM |
Re: My Replikeo Prusa i3 Rework Build July 08, 2014 12:48AM |
Re: My Replikeo Prusa i3 Rework Build July 08, 2014 01:16PM |
Re: My Replikeo Prusa i3 Rework Build July 08, 2014 02:44PM |
Re: My Replikeo Prusa i3 Rework Build July 08, 2014 08:20PM |
Re: My Replikeo Prusa i3 Rework Build July 09, 2014 07:18AM |
Re: My Replikeo Prusa i3 Rework Build July 09, 2014 02:10PM |
