Re: My Replikeo Prusa i3 Rework Build September 15, 2014 12:11AM |
Allnei
LittleMike
Oh, and my y-belt holder keeps hitting into the motor. It's kind of hard to see in the picture
This is because you are trying it without HB. Install HB and it will fix your problem
SteveRoy
From the picture it looks like you will have to move the motor over some more to line the belt up..
Steve
Re: My Replikeo Prusa i3 Rework Build September 15, 2014 01:28AM |
Re: My Replikeo Prusa i3 Rework Build September 15, 2014 01:39AM |
Orion
Hi Littlemike
Don't worry about y-belt holder hitting motor. When you install heatbed ,the heatbed will hit endstop before y-belt holder hit motor.
Re: My Replikeo Prusa i3 Rework Build September 15, 2014 03:51AM |
LittleMike
Orion
Hi Littlemike
Ah gotcha. Maybe that's what Allnei was trying to say - not that it would fix the problem, but that it won't be a problem anymore because the heatbed hits first. Haha.
I have another belt related question - if I manually move the y-carriage by pushing the carriage itself, in one direction it moves fine, but in the other, it seems like the belt slips or something and doesn't catch right on the pulley. Does that mean my belt isn't tight enough or is that just normal. The same thing goes for the x-carriage. If I pull one end of the belt then pull the other end of the belt to get it to go the other way, it seems fine, though.
Re: My Replikeo Prusa i3 Rework Build September 15, 2014 11:19AM |
Re: My Replikeo Prusa i3 Rework Build September 16, 2014 03:05PM |
Re: My Replikeo Prusa i3 Rework Build September 21, 2014 02:46AM |
Re: My Replikeo Prusa i3 Rework Build September 21, 2014 09:33AM |
Re: My Replikeo Prusa i3 Rework Build September 21, 2014 10:12AM |
Re: My Replikeo Prusa i3 Rework Build September 22, 2014 06:05AM |
Re: My Replikeo Prusa i3 Rework Build September 22, 2014 07:13AM |
I design my own auto bed mount. The idea is to have auto bed + led ring, like on the picture.Quote
Allnei
Right auto bed leveling mount is this [www.thingiverse.com] or similar. I am using this design without problems.
Re: My Replikeo Prusa i3 Rework Build September 22, 2014 09:47AM |
Re: My Replikeo Prusa i3 Rework Build September 22, 2014 10:14AM |
yes, you can do 5*5 of probes, but I think there is an average of the values to a 3*3 matrix.Quote
Allnei
In Enhanced G29 you can define number of probes, so you can do 5x5 matrix or more
With the lever effect, I think the probe needs less strength on the bed for the measure, as my bed is not rigid. Don't you think ?Quote
Allnei
Btw remove that metal lever from microswitch for better measurement
Re: My Replikeo Prusa i3 Rework Build September 22, 2014 10:53PM |
Re: My Replikeo Prusa i3 Rework Build September 23, 2014 12:38PM |
Allnei
Blue_ice: I used some pc power cord that I had home, cut off end and wired it up.
AbuMaia
I went to Radio Shack and purchased a computer power cord, three pronged, and cut off the end that usually goes into the computer power supply. I then wired it up to the 12v 30a supply for my printer.
underthetire
I used a decent 3 prong cord with ground myself.
Re: My Replikeo Prusa i3 Rework Build September 28, 2014 07:29AM |
Re: My Replikeo Prusa i3 Rework Build September 28, 2014 04:40PM |
Allnei
flywire: What you have is not Prusa i3 Rework, but vanila Prusa i3 with Greg's Wade extruder, but Prusa i3 rework that we have use Greg's Hinged Extruder. So it will be better if you look in this section of forum (since this section is about Prusa X printers) , but not in this topic, because we have different hardware here.
Re: My Replikeo Prusa i3 Rework Build October 17, 2014 09:55AM |
Re: My Replikeo Prusa i3 Rework Build October 21, 2014 05:23AM |
syl20077
I have just published a new fork of Marlin on github (https://github.com/syl-20/Marlin) for ours Replikeo.
It supports auto bed leveling (ABL) with
- Roxy's enhanced G29 command (http://3dprintboard.com/showthread.php?3105-Auto_Bed_Leveling-Enhanced-G29-command/),
- dynamic probe area (from bonm14: [github.com]),
- new post-processing script for slic3r (replaces the gcode "G29 L[G29XMIN] F[G29YMIN] R[G29XMAX] B[G29YMAX] n4" by "G29 L10 F20 R50 B40 n4" for example),
- last commits from the original EricZalm version (16/10/14).
Enjoy !
extruder motor die November 01, 2014 06:17AM |
Re: My Replikeo Prusa i3 Rework Build November 02, 2014 12:11PM |
Re: My Replikeo Prusa i3 Rework Build November 03, 2014 08:49AM |
Re: My Replikeo Prusa i3 Rework Build November 11, 2014 02:26PM |
Re: My Replikeo Prusa i3 Rework Build November 11, 2014 02:38PM |
Re: My Replikeo Prusa i3 Rework Build November 11, 2014 02:44PM |
Re: My Replikeo Prusa i3 Rework Build November 11, 2014 05:59PM |
I feel so stupid I didn't realize this earlier... But thing is I calibrated bed just before printing, and it got misaligned on it's own. Gotta figure out what's causing that...|
Re: My Replikeo Prusa i3 Rework Build November 12, 2014 09:54AM |
Bratan
Oh, yeah it makes sense now! I actually tightened hubbed bolt as it was too loose. Gotta loosen it back and give it a try...
BTW sweet build!
Bratan
Update: Having some success! I basically loosened bold slightly, and most important backed away two tentioner screws that push filament onto the bolt. I think that was it. Oh yeah and I started having wavy lines again (just like in my post on page 24) but only on far left edge. So I finally figured out what's causing wavy lines on 1st layer. Nozzle is too close to the glass on one side, duh!I feel so stupid I didn't realize this earlier... But thing is I calibrated bed just before printing, and it got misaligned on it's own. Gotta figure out what's causing that...
Re: My Replikeo Prusa i3 Rework Build November 12, 2014 02:06PM |
Good luck! Plastic spiral wrap that came with kit is a little too short. I found super long one at Radioshack for $7 it was enough to hide almost all wires and also wrap around threaded rods for slicker lookQuote
Blue Ice
Thanks! I'm working on cable management right now, so it should look even better![]()
Nah, my issue was definitely bed calibration. Hot end smearing filament around the bed and it made wavy lines. Farther from the edge, less lines I had... After I figured out that issue, got another one. After printing 2nd layer, filament would stop feeding in. After I removed it from the nozzle I saw that it doubled on itself trying to leave from where it came fromQuote
Blue Ice
I had wavy sides of prints from the hotend wobbling in its mount. I don't know if this is your issue, but you can look on this forum topic if it feels even slightly wiggly.
I posted there about how to fix the issue- you just basically put larger screws in the mount.
I figured it was temperature issue. Increasing from 230C to 235C made if flow correctly...|
Re: My Replikeo Prusa i3 Rework Build November 15, 2014 03:49PM |
Re: My Replikeo Prusa i3 Rework Build November 15, 2014 10:00PM |
