Re: My Replikeo Prusa i3 Rework Build November 15, 2014 11:21PM |
Re: My Replikeo Prusa i3 Rework Build November 16, 2014 12:27AM |
Re: My Replikeo Prusa i3 Rework Build November 16, 2014 08:24AM |
Re: My Replikeo Prusa i3 Rework Build November 17, 2014 12:36PM |
Re: My Replikeo Prusa i3 Rework Build November 17, 2014 02:35PM |
Zippit
Metric won't be a problem since I'm European. Dutch to be exact.
Ik ben er zeer tevreden mee. Ik heb een spiegel van 20x20 in gebruik ipv een stuk glas. Mss ook een optie
Re: My Replikeo Prusa i3 Rework Build November 17, 2014 03:21PM |
Bratan
I'm reading on Replikeo's site that they now use injection molded parts (rather than 3D printed). That should improve quality considerably! Zippit if your's are molded post some pics pleas
Repelsteler
Zippit
dutch mode on
Veel geluk ermeeIk ben er zeer tevreden mee. Ik heb een spiegel van 20x20 in gebruik ipv een stuk glas. Mss ook een optie
dutch mode off
Just wishing him good luck and told him I used a mirror instead of glass
Greetz
Bert
Re: My Replikeo Prusa i3 Rework Build November 18, 2014 08:23AM |
Re: My Replikeo Prusa i3 Rework Build November 19, 2014 04:04PM |
Re: My Replikeo Prusa i3 Rework Build November 19, 2014 04:19PM |
Re: My Replikeo Prusa i3 Rework Build November 19, 2014 04:26PM |
Re: My Replikeo Prusa i3 Rework Build November 19, 2014 04:59PM |
Re: My Replikeo Prusa i3 Rework Build November 19, 2014 05:03PM |
Re: My Replikeo Prusa i3 Rework Build November 22, 2014 09:06AM |
) at Nov 17 (about 5 days), and the tracking code (CT307808002CN) still not posted, is this normal? Do anymore has the same problem?|
Re: My Replikeo Prusa i3 Rework Build November 22, 2014 09:52AM |
raphaelbruno3d
Hi, i'm follow this topic about any days, because of this topic, I created courage and bought the Prusa i3 at Replikeo...
It was sent by DHL (Shipping $168.46) at Nov 17 (about 5 days), and the tracking code (CT307808002CN) still not posted, is this normal? Do anymore has the same problem?
I seen here on topic the Bratan no have update on tracking...
Re: My Replikeo Prusa i3 Rework Build November 22, 2014 12:39PM |
Re: My Replikeo Prusa i3 Rework Build November 22, 2014 05:18PM |
Re: My Replikeo Prusa i3 Rework Build November 23, 2014 05:19AM |
I'm using 1.75mm ABS filament now, it seems to work ok. I've yet to get a perfect print, but that's another story (same issues with 3mm filament).Quote
SkyJack
Someone built the Replikeo kit for 1.75mm filament? Does it works well with the geared extruder and hobbed-bolt?
I think most of you use the 3mm version.
Re: My Replikeo Prusa i3 Rework Build November 25, 2014 12:46PM |
Re: My Replikeo Prusa i3 Rework Build November 26, 2014 07:12AM |
Wow, my package arrived in my city, thank's @Replikeo, it was very fast, about 2 week, the DHL called me today to mark better hour... It came with tax from my country (+-$60, that's ok)...
But dont understood why it have other tax from DHL (+- $50), have anybody in here this tax from DHL too?
Re: My Replikeo Prusa i3 Rework Build November 27, 2014 04:35PM |
Re: My Replikeo Prusa i3 Rework Build November 27, 2014 10:16PM |
Re: My Replikeo Prusa i3 Rework Build November 27, 2014 10:59PM |
Re: My Replikeo Prusa i3 Rework Build November 28, 2014 09:21AM |
tomleeds
Hello guys,
I just finished printing of calibration cube 20mm and 0.5mm thin wall. Thin-wall looks perfect but 20mm cube is very bad (see attachment). Start where print is creating of object border is well but second layer is printed out of borders. Printer is calibrated, when I press 100mm for X,Y axis in pronterface it will move only 100mm. Bed Level is also calibrated, I can put paper under nozzle with resistance.Im using 0.4mm nozzle and 1.75mm filament. Temp. is 230C nozzle and 110C for bed. Y axis have default steps 80.40 becasue 80 will pull bed on 86.45mm. My printer is Replikeo Iron. Please help me. I tested almost all.
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80.40,4000,600}
Re: My Replikeo Prusa i3 Rework Build November 28, 2014 09:26AM |
raphaelbruno3d
It is being hard to find a tutorial equal, I'm following the oficial reprap.org, but I do not undertsood any parts...
For example, this part...
If I put only bearing on center, this is handily, is it this way?
how do I solve it?
Re: My Replikeo Prusa i3 Rework Build November 28, 2014 09:42AM |
Re: My Replikeo Prusa i3 Rework Build November 28, 2014 11:08AM |
Tech2C
tomleeds
Hello guys,
Which axis are the layers shifting - X or Y?
On that axis, make sure it's easy to move by hand. Any binding will cause the stepper motor to stall.
If that's ok, check that stepper driver pot setting. I have mine a little under half way around. If it's too low, there won't be enough power for the motor. If it's too high, the driver and/or motor may be over-heating and shutting down briefly mid-print.
Failing those, Replikeo had mentioned some of the stepper motor connectors may have insufficient contact, resulting in not enough power being delivered to the motor. Their recommendation is to re-terminate the motor connector.
Re: My Replikeo Prusa i3 Rework Build December 01, 2014 06:46AM |
Re: My Replikeo Prusa i3 Rework Build December 02, 2014 01:54PM |
Re: My Replikeo Prusa i3 Rework Build December 03, 2014 12:57PM |
Re: My Replikeo Prusa i3 Rework Build December 03, 2014 02:09PM |
Zippit
So it just arrived and someone asked for pictures of the moulded plasic parts.
Here they are:
Clicky for the Imgur Album
Let the build begin!
