Re: My Replikeo Prusa i3 Rework Build December 03, 2014 03:19PM |
Re: My Replikeo Prusa i3 Rework Build December 03, 2014 05:45PM |
Re: My Replikeo Prusa i3 Rework Build December 04, 2014 05:19PM |
Re: My Replikeo Prusa i3 Rework Build December 04, 2014 08:56PM |
Re: My Replikeo Prusa i3 Rework Build December 05, 2014 05:15AM |
Re: My Replikeo Prusa i3 Rework Build December 05, 2014 06:47AM |
Re: My Replikeo Prusa i3 Rework Build December 05, 2014 07:40AM |
Re: My Replikeo Prusa i3 Rework Build December 05, 2014 07:43AM |
Re: My Replikeo Prusa i3 Rework Build December 05, 2014 05:18PM |
Re: My Replikeo Prusa i3 Rework Build December 06, 2014 07:35AM |
Re: My Replikeo Prusa i3 Rework Build December 06, 2014 03:16PM |
Re: My Replikeo Prusa i3 Rework Build December 06, 2014 05:02PM |
Re: My Replikeo Prusa i3 Rework Build December 06, 2014 06:20PM |
tomleeds
raphaelbruno3d
Oops, I think I did jump this step...Where set I this 'configuratioin.h'? Is it on pronterface? Do you have a link with instructions?
It is in merlin FW. Open it in adruino IDK and there you will see configuration.h tab. there search for serial rate.
Re: My Replikeo Prusa i3 Rework Build December 07, 2014 04:24PM |
#define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1
#define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 1 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 0
Re: My Replikeo Prusa i3 Rework Build December 07, 2014 06:09PM |
Re: My Replikeo Prusa i3 Rework Build December 08, 2014 04:08AM |
Re: My Replikeo Prusa i3 Rework Build December 08, 2014 04:11AM |
Re: My Replikeo Prusa i3 Rework Build December 08, 2014 04:50AM |
Re: My Replikeo Prusa i3 Rework Build December 08, 2014 05:02AM |
Re: My Replikeo Prusa i3 Rework Build December 08, 2014 05:10AM |
Re: My Replikeo Prusa i3 Rework Build December 08, 2014 06:00AM |
Re: My Replikeo Prusa i3 Rework Build December 08, 2014 06:40AM |
#define BAUDRATE 115200
#define MOTHERBOARD 33
#define EXTRUDERS 1
#define POWER_SUPPLY 1
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR -1
// prusa i3 settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,600} // default steps per unit for prusa i3 rework
#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {2000,2000,20,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
Re: My Replikeo Prusa i3 Rework Build December 11, 2014 12:03PM |
Re: My Replikeo Prusa i3 Rework Build December 11, 2014 02:35PM |
Re: My Replikeo Prusa i3 Rework Build December 11, 2014 09:17PM |
Re: My Replikeo Prusa i3 Rework Build December 12, 2014 06:28AM |
Anonymous User
Re: My Replikeo Prusa i3 Rework Build December 18, 2014 03:57PM |
Re: My Replikeo Prusa i3 Rework Build December 18, 2014 07:23PM |
Re: My Replikeo Prusa i3 Rework Build December 21, 2014 05:08PM |
Re: My Replikeo Prusa i3 Rework Build December 21, 2014 06:39PM |
Bratan
Can someone recommend me a better hotend? I'm having so many issues with this one such as I spend about 15 minutes trying to get new filament inside the hole, and it clogs and backs out frequently, doesn't feed correct length no matter how many extrusion steps I take, and so on. No a single print is the same... I tried a lot of things for the many months that I had this printer, that I'm now convinced it's the HE that's the problem...
