Re: My Replikeo Prusa i3 Rework Build January 08, 2016 05:52PM |
What is the problem here? Is the motor turning but no filament is pushed out? Tighten the screws, if that doesn't work, loosen it a bit again.Quote
owaisshaf
How do i achieve cold extrusion, i tightened the screws on my extruder and still no luck
Normally with not enough power, the motor just whines, then with more power it skips steps and with even more power it works fine. So try with even higher output. Be sure that the rod is aligned with the motor axis to reduce the needed force.Quote
owaisshaf
I also varied the potentiometer for the Y axis motor and it either whines or it skips steps with a lot of resisting noises.
Your nut is loose on the left side. Try to fix this. Another problem could be the motor not having enough torque (needs more current). If the needed torque is less on one side than the other (because of not aligned rod with motor axis or bent rod), one side will turn fine, while the other one can't follow.Quote
owaisshaf
Also I have a new problem, which I don't know how I didn't notice till now. My Z axis motors started to act funny too, here is a video of the same : [www.youtube.com]
See point above.Quote
owaisshaf
The left motor does not rotate uni directionally, it keeps coming back a few steps and then continuing
Re: My Replikeo Prusa i3 Rework Build January 09, 2016 10:44PM |
Re: My Replikeo Prusa i3 Rework Build January 10, 2016 07:07PM |
Re: My Replikeo Prusa i3 Rework Build January 10, 2016 09:28PM |
Re: My Replikeo Prusa i3 Rework Build January 12, 2016 11:31AM |
Re: My Replikeo Prusa i3 Rework Build January 13, 2016 01:40PM |
Ok, that helps to see what the actual problem is, but you still didn't say: Did you try the thing tomleeds suggested?
Re: My Replikeo Prusa i3 Rework Build January 22, 2016 01:20PM |
Re: My Replikeo Prusa i3 Rework Build January 22, 2016 08:03PM |
Re: My Replikeo Prusa i3 Rework Build January 24, 2016 11:36AM |
You should try adjusting the feedrates.Quote
baconator
I cannot get the Z-Axis to move at all. Whenever I try to home it or move it it simply makes a high pitched squeal. I have tried switching motors, stepper drivers, and adjusting the pots. Please Help!!
Re: My Replikeo Prusa i3 Rework Build February 02, 2016 05:15PM |
Re: My Replikeo Prusa i3 Rework Build February 11, 2016 05:27PM |
Re: My Replikeo Prusa i3 Rework Build March 12, 2016 10:06AM |
Re: My Replikeo Prusa i3 Rework Build March 12, 2016 02:51PM |
Re: My Replikeo Prusa i3 Rework Build March 12, 2016 09:51PM |
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 09:30AM |
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 10:37AM |
Thanks!|
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 11:38AM |
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 11:45AM |
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 11:47AM |
Backdraft
permans
Backdraft
Should the rods sit all the way in the corner parts?
Yes, and secured with a cable tie on each corner.
So I have the wrong size parts? The rods are 8mm. The opening on the corner slot is about 7.5mm
Can anyone confirm the sizes?
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 11:54AM |
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 12:11PM |
Re: My Replikeo Prusa i3 Rework Build March 13, 2016 01:32PM |
I am having lots of trouble with vibration and noise though. Does any one have any suggestions? My current feedrates are {1000, 1000, 2, 25}.|
Re: My Replikeo Prusa i3 Rework Build March 19, 2016 07:05AM |
Re: My Replikeo Prusa i3 Rework Build March 21, 2016 03:34PM |
Re: My Replikeo Prusa i3 Rework Build March 25, 2016 09:28AM |
Re: My Replikeo Prusa i3 Rework Build April 04, 2016 01:52PM |
Re: My Replikeo Prusa i3 Rework Build April 16, 2016 05:49PM |
Re: My Replikeo Prusa i3 Rework Build April 16, 2016 09:27PM |
Re: My Replikeo Prusa i3 Rework Build June 03, 2016 03:55AM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2016 04:54PM |
