Re: My Replikeo Prusa i3 Rework Build May 22, 2014 10:01AM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 10:40AM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 12:00PM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 12:05PM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 12:34PM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 12:46PM |
Allnei
My prints are not so good as they looks. I have many prints with shifted layers and other defects. I found one problem, if I turn on some hungry device (soldering iron, stove etc.) Y axis start shifting pretty hard.
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 12:58PM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 01:39PM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 06:44PM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 06:55PM |
Re: My Replikeo Prusa i3 Rework Build May 22, 2014 06:58PM |
Re: My Replikeo Prusa i3 Rework Build May 23, 2014 08:04AM |
. Thanks all for the updates about your own builds! Going to buy some PLA to starting printing with as you all mention it being easier. Any thing else you would all recommend? I.e. any tools, additional little parts needed for build?
Re: My Replikeo Prusa i3 Rework Build May 23, 2014 09:36AM |
Re: My Replikeo Prusa i3 Rework Build May 24, 2014 03:25PM |
Trike
Another weekend update. I could not get the bed to stay leveled consistently with the springs, I could visibly see the bed move when doing really fast/abrupt Y axis direction changes. If I tightened the bed more, the center would start bowing. I needed another solution. I printed out a servo mount to try out the auto bed leveling. That way, I can hard mount the bed and not worry about it changing directions during a print.
When I got it all working correctly, My prints were still off, one side of the bed would leave a good bead, then once it got to the other side, the head wasn't close enough to the bed, leaving a really weak first layer. I think it's because the hotend is shifting inside the extruder. When a retract occurs, the hot end moves a good 5mm to the rear, then resets back to the front. I think this movement is screwing up the prints since the head might not be going back to the same position after the retract. I think i'm going to drill out the extruder body holes to M4 and hope that will keep the hot end secured.
One other note, the m3 screws that holds the extruder idler is too long. They need to be shortened to provide enough pressure on the hob bolt. Otherwise, you'll bottom out the left screw and the right screw will bottom out on the extruder stepper motor, forcing it into the gear. However, that could be a good way to eliminate any backlash in the gears. There isn't enough adjustment to move the stepper motor into the gear to reduce all the backlash. I left that bolt a little longer for this purpose.
Greg,
The roll of ABS I got from Replikeo is black.
Re: My Replikeo Prusa i3 Rework Build May 24, 2014 07:06PM |
Re: My Replikeo Prusa i3 Rework Build May 24, 2014 10:42PM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 02:32AM |
I had to chop up the heatsink to make it fit in the tiny space that mosfet occupies. I'll show it in the next youtube video.
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 03:50AM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 05:39AM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 08:44AM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 08:47AM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 09:11AM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 12:41PM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 03:03PM |
Re: My Replikeo Prusa i3 Rework Build May 25, 2014 03:46PM |
Re: My Replikeo Prusa i3 Rework Build May 26, 2014 07:07AM |
Tech2C
Ok, new videos are up - Initial assembly, Final assembly and First print!
Yes I have finally been able to print! More calibration required but I'm very happy so far
Has anyone received a warped PCB Heatbed? Mine has a bow in it causing the entire bed not to sit level. Not sure how I'm going to fix it
Re: My Replikeo Prusa i3 Rework Build May 26, 2014 08:39AM |
Giuss
The iron frame seems not very stable, or I'm wrong?
Re: My Replikeo Prusa i3 Rework Build May 26, 2014 10:39AM |
Re: My Replikeo Prusa i3 Rework Build May 26, 2014 12:29PM |
Re: My Replikeo Prusa i3 Rework Build May 27, 2014 12:51PM |
