Re: My Replikeo Prusa i3 Rework Build
December 03, 2014 03:19PM
My kit came so too... I finished to assembly yesterday, left to configure. smiling smiley
I'll post some photos tonight.
December 03, 2014 05:45PM
My kit comes so too... left only to configure. smiling smiley
I shared all the photos at here [drive.google.com]
December 04, 2014 05:19PM
Nice!
Those parts do look good. The build is a lot of work but a lot of fun smiling smiley
I also just got another build log, going over the y-axis steps, up on my blog. I'm trying to add more pictures for people, so if you get stuck, maybe my posts can help out with the images.
Out of curiosity, which lubricant did you end up going for, Zippit?
December 04, 2014 08:56PM
I'm trying to print a "Hello Wolrd!", but when I try to connect on pronterface, it say "connecting...", and nothing happens.
I'm following this tutorial [www.youtube.com]
Arduino has been installed
What I do?
Edited 1 time(s). Last edit at 12/05/2014 06:29AM by raphaelbruno3d.
December 05, 2014 05:15AM
I have my printer all build but I couldn't mount the arduino because I think I have the frame backwards. And my motor for the y is in the back.
I'll check it out tonight and start configuring the printer!
December 05, 2014 06:47AM
Are you using configuration.h from replikeo? If yes, there is define BAUDRATE 115200
December 05, 2014 07:40AM
Oops, I think I did jump this step... smiling smiley Where set I this 'configuratioin.h'? Is it on pronterface? Do you have a link with instructions?
December 05, 2014 07:43AM
raphaelbruno3d
It is in merlin FW. Open it in adruino IDK and there you will see configuration.h tab. there search for serial rate.
December 05, 2014 05:18PM
I'm currently calibrating my extruder.
I've told it to print out 100mm but it actually printer 185mm
How do I correct for such a big difference?
December 06, 2014 07:35AM
Zippit
Never mind! Found it!
My E Steps were set to 1173... I caculated it to be 619 so there was my problem!
December 06, 2014 03:16PM
What a difference calibrating makes!
December 06, 2014 05:02PM
Zippit
Wow, nice comparasion! thumbs upsmiling smiley
December 06, 2014 06:20PM
tomleeds
raphaelbruno3d
Thank's tomleeds, I done it following this tutorial: [www.replikeo.com]
This is connected, I'm ready to print the hello world. smiling smiley
December 07, 2014 04:24PM
I can't to print, I got this error, but the HBP (heated bed) is cold (~29ºC)...
On Merlin, I've set like replikeo configuration
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 1
My circuit...
If I to setup so...
#define TEMP_SENSOR_1 1
#define TEMP_SENSOR_BED 0
The issue above was fixed, now I can to connect the printer on Pronterface, I can to move X,Y and Z motors on Pronterface, I can warm up the hotend...
But I can't warm up the HBP, in the Pronterface shows 0ºC. And if I click on "Print" nothing happens confused smiley
I Attached my "Configuration.h"
Edited 1 time(s). Last edit at 12/07/2014 04:29PM by raphaelbruno3d.
open | download - Configuration.h (35.8 KB)
December 07, 2014 06:09PM
I had same problem with HB thermistor, try set another type in Config file
bc
December 08, 2014 04:08AM
Hello,
I have put the kit together and double checked the wiring but run into problems with the sw.
I downloaded ardino and marlin and prontoface and they are now installed on my pc.
There is a red light blinking on the ardino board.When I try to upload ardino firmware it goes through the motions but end up unsuccessful.
I am not a programmer so any help for dummies appreciated.
December 08, 2014 04:11AM
Do you see some errors during compilation?
bc
December 08, 2014 04:50AM
Hello,
Correction to my last mail.There is a steady red light on the ardino 2560 board and a blinking red light on the ramps 1.4 board when either power is applied or my pc is active.
bc
December 08, 2014 05:02AM
Hello tomleeds,
When i try to upload sketch it goes though the motion but ends up with fault at compilation
December 08, 2014 05:10AM
bc
Hello tomleeds,
Paste here screenshot from compilation error.
bc
December 08, 2014 06:00AM
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Mega 2560 or Mega ADK"
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:34: undefined reference to `setup'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:44: undefined reference to `loop'
December 08, 2014 06:40AM
I had similar problem, if you replaced the Merlin original "Configuration.h" by replikeo "Configuration.h"... Try to change only the needed params.
#define BAUDRATE 115200
#define MOTHERBOARD 33
#define EXTRUDERS 1
#define POWER_SUPPLY 1
#define INVERT_X_DIR false    // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true    // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true     // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false    // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR -1
// prusa i3 settings
#define DEFAULT_AXIS_STEPS_PER_UNIT   {80,80,4000,600}  // default steps per unit for prusa i3 rework
#define DEFAULT_MAX_FEEDRATE          {500, 500, 2, 25}    // (mm/sec)
#define DEFAULT_MAX_ACCELERATION      {2000,2000,20,1000}    // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
Replikeo "Configuration.h" is outdated than last version of the Merlin FW, some params has been added.
Marlin firmware, (updated version) [github.com]
Replikeo, (Configuration tutorial) [www.replikeo.com]
bc
December 11, 2014 12:03PM
Hello,
I have now got it working, including bed levelling, except for the extruder motor that avoids
controlling via the repetier host.Could anybody help?
Thank you.
December 11, 2014 02:35PM
Can someone point me in the right direction to calibrate the center of the bed?
When I print things they are not centered so I can't make full use of my print bed.
December 11, 2014 09:17PM
About my issue of bed thermistor, I tried all in configuration and nothing, I bought another thermistor and it did work. It really was thermistor damaged. drinking smiley
Edited 1 time(s). Last edit at 12/11/2014 09:19PM by raphaelbruno3d.
bc
December 12, 2014 06:28AM
hello,
now everything works ok ---i am just before my first print
Anonymous User
December 18, 2014 03:57PM
Just ordered one, will join your people when the kit arrived.
December 18, 2014 07:23PM
Welcome smileys with beer
This kit from Replikeo is pretty good.
December 21, 2014 05:08PM
Can someone recommend me a better hotend? I'm having so many issues with this one such as I spend about 15 minutes trying to get new filament inside the hole, and it clogs and backs out frequently, doesn't feed correct length no matter how many extrusion steps I take, and so on. No a single print is the same... I tried a lot of things for the many months that I had this printer, that I'm now convinced it's the HE that's the problem...
Edited 2 time(s). Last edit at 12/21/2014 05:08PM by Bratan.
December 21, 2014 06:39PM
Bratan
Hi Bratan,
Been away from this thread for a while, but I've been reading all of the posts. After reading yours, I thought I'd share a few tips about the hotend that I found out that might be helpful for you:
  • When I withdraw filament, I just loosen the screws holding the filament against the drive gear, with the extruder up to temperature. Then I pull it out. At the end, the tip of the filament is pointed.
  • My filament hole in the extruder and in the hotend don't line up. I find the easiest way to reinsert filament is to keep the pointed end from the step before (I used to trim it off). Now when I insert filament it just guides itself in.
  • Make sure that you have a fan for PLA. I tried printing PLA without a fan and it was very tough to get things to work out.
  • I have been running my printer for 3 months with spacers instead of springs on the tensioning screws that press the filament against the drive gear (picture later tonight). It has worked very well and very accurately.
  • If the print comes out wobbly, try replacing the screws that hold the hotend in place with slightly larger screws (only if the hotend wobbles when you pull on it). Worked wonders for me.
Blue Ice
blog at [contemporarymaker.com]
