Re: My Replikeo Prusa i3 Rework Build June 10, 2014 02:42PM |
Re: My Replikeo Prusa i3 Rework Build June 10, 2014 02:50PM |
Re: My Replikeo Prusa i3 Rework Build June 10, 2014 11:00PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 04:04AM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 05:11AM |
I'm also planning to print longer Z endstop mount.Quote
Allnei
I have problem with Z endstop holder too, probably tomorrow I will print some extended version. Wires that I use for my HB are standard copper ~ 2.5mm diameter wires (don´t know what number it is in USA)
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 01:13PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 01:32PM |
From what I understand regular glass can handle HB temperatures, however if it's heated or cooled quickly it can crack. Borosilicate glass is recommended for this.Quote
gadget_greg
I'm going to buy a piece of glass to print on in a few minutes, just to alleviate the slight bow in the heat bed. Is regular glass ok? I can get tempered glass or wood-stove glass (rated to 1400 degrees F) if needed. What thickness glass?
Once I have the glass on the bed I'll rig up something for the Z-endstop. I'll also remove the springs.
Borosilicate glass is a type of glass with the main glass-forming constituents silica and boron trioxide. Borosilicate glasses are known for having very low coefficients of thermal expansion (~3 × 10−6 /°C at 20 °C), making them resistant to thermal shock, more so than any other common glass.
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 01:35PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 02:32PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 02:44PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 02:55PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 02:58PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 03:33PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 03:38PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 03:43PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 03:50PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 03:57PM |
Re: My Replikeo Prusa i3 Rework Build June 11, 2014 10:10PM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 06:40AM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 10:57AM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 01:22PM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 02:01PM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 02:15PM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 03:16PM |
Aaaahhh holy prusa, I didn't realize it was in reverse!Quote
Allnei
I use clips, that come with kit for secure cork in place.
You can´t find good way how to organize wires, because your Y axis assemble is inverted. You should have motor on other side (It is problem of manual on Reprap wiki, my Y assembly is inverted too). It can be problem, if firmware is not configured right, and your prints can be printed mirrored, best way how to check it is print Z-endstop holder.
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 03:48PM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 05:50PM |
Good point, didn't realize motor will be in reverse. I just moved it to another side, now all should be good.Quote
Allnei
Probably you will need reverse it in FW and set homing towards max endstop (or min, I don´t know where is home point on Prusa i3)
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 05:54PM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 05:58PM |
Re: My Replikeo Prusa i3 Rework Build June 12, 2014 06:07PM |
