Re: Folger Prusa i3 Kit from ebay October 28, 2014 11:26AM |
Re: Folger Prusa i3 Kit from ebay October 28, 2014 12:14PM |
these video's are a great way to start.
lots of good timps.
Re: Folger Prusa i3 Kit from ebay October 28, 2014 12:39PM |
Re: Folger Prusa i3 Kit from ebay October 28, 2014 02:34PM |
Waltermixx
Not sure if I mentioned it before, but this guy (Tom ) has an awesome series of youtube videos on using setting up Marlin firmware so you can use an LCD display,
along with tips on how to set things upthese video's are a great way to start.
[www.youtube.com]
here is the one on adding an LCD with SD card.
[www.youtube.com]
lots of good timps.
Re: Folger Prusa i3 Kit from ebay October 28, 2014 02:38PM |
Re: Folger Prusa i3 Kit from ebay October 28, 2014 09:10PM |
AKFoddy7
Waltermixx, if you do manage a way to export your settings, I think it would be great to benchmark to fine tune my settings. Your prints seem to be problem free! I notice you are using ABS, where did you order your filament from? Any smell associated with the filament you are using?
And for those of you messing around with the hot end, do not over tighten it....See below for what can happen. (Had a bit too much hear and a little too much force when installing the threaded portion, the heat throat snapped like a piece of spaghetti.
Anyone have any experience with Folger's all metal hot end? Seems really cheap?
Re: Folger Prusa i3 Kit from ebay October 28, 2014 09:51PM |
Re: Folger Prusa i3 Kit from ebay October 28, 2014 11:42PM |
Double Post October 28, 2014 11:42PM |
Re: Folger Prusa i3 Kit from ebay October 29, 2014 12:39AM |
czmorris
Before I saw your last post I modified the bearing mount during my lunch hour for the half cylinder idea I was talking about. Added the update as another file on Thingiverse. I will do a test print just to confirm the model when I get home.
http://www.thingiverse.com/thing:513656
Re: Folger Prusa i3 Kit from ebay October 29, 2014 08:28AM |
Gannicus
Has anyone here bought the new E3d v6 hot end?
Waiting to get my kit, ordered it with the graphical LCD, and think the E3D hot end looks to be the cats ass, could cure up a lot of the issues I've read in here.
Re: Folger Prusa i3 Kit from ebay October 29, 2014 09:18AM |
jjbunn
czmorris
I printed one of these off, and it looks good: capped Y bearing holder. There are no frame clearance issues.
I had to rotate the model so that it was sitting on its base - printing it vertically was problematic as the cap ends are slightly proud.
Re: Folger Prusa i3 Kit from ebay October 29, 2014 01:18PM |
czmorris
jjbunn
czmorris
Good news. Thanks for trying it out and for the idea about the ends. Printed mine on the base as well (Forgot to rotate it before creating the stl). I attempted to make it so that the LM8UU fits snug. I have been running mine without any zip ties in place at all just to see how well it would work. So far no issues. Though I would recommend adding the zip ties for anyone installing it.
When I get a chance I am planning on moving the holes for the zip ties closer in as Waltermixx suggested. That might make for a better hold and less force on the thin edge of the hole.
Re: Folger Prusa i3 Kit from ebay October 29, 2014 07:57PM |
dougal1957
Gannicus
I have an E3D V6 (tho not on a folger but a very similar I3 printer) and can safely say that they are the Dogs Danglies if you get what I mean they are superb so much so I have purchased one of E3D's 4 head setups called the Kraken.
The Kraken Hot End
Doug
Re: Folger Prusa i3 Kit from ebay October 29, 2014 10:00PM |
Re: Folger Prusa i3 Kit from ebay October 29, 2014 10:32PM |
Re: Folger Prusa i3 Kit from ebay October 29, 2014 11:36PM |
AKFoddy7
How do you find it with PLA? I haven't heard of too many good reviews of the all metal hot ends with PLA>
By the way, for those of you printing with ABS, how bad is the smell?
Re: Folger Prusa i3 Kit from ebay October 29, 2014 11:52PM |
Wpflum
Ok, this is becoming annoying, I'm using repetier host to see if the issues I'm having might be related to cura and I had the same X carriage skip I've been having whenever I try to do a large area print. I had thought originally it was because I didn't have the belt tight enough but after I took it apart again and worked on it a bit I was able to get is, what I think, a very tight belt but it still happened. I'm using the settings posted here for the motors and ramps board and small items print well, even larger items do but it seems that when I get either multiple items or items that take up most of the print bed then I run into the skipping. Any thoughts? It's very annoying as I'll print some small test cubes and everything works well, even when I up the feed rate 200% using the control panel but the moment I try something of useful size I either get it during the skirt print or it waits until a few layers print then it does it.
Where do I go next?
Re: Folger Prusa i3 Kit from ebay October 30, 2014 04:11AM |
czmorris
Wpflum
Where do I go next?
Do you have a picture of a print with the problem or maybe a short video clip?
Without knowing more a few shots in the dark...
-Check the wire terminations of the stepper on the pre-made side. This usually causes more jerky type behaviour but worth a shot.
-If you have steppers disabled and attempt to move the axis by hand do you feel any resistance?
-You might try replacing the stepper driver with the spare for a test and re-tuning vref.
Re: Folger Prusa i3 Kit from ebay October 31, 2014 01:25PM |
echo:endstops hit: Y:-99.09 echo:endstops hit: Y:-99.07 echo:endstops hit: Y:-99.06 echo:endstops hit: Y:-99.05 echo:endstops hit: Y:-99.04 echo:endstops hit: Y:-99.02 echo:endstops hit: Y:-99.02 echo:endstops hit: Y:-99.04 echo:endstops hit: Y:-99.05 echo:endstops hit: Y:-99.06 echo:endstops hit: Y:-99.07 echo:endstops hit: Y:-99.09 echo:endstops hit: Y:-99.07 echo:endstops hit: Y:-99.06 echo:endstops hit: Z:0.00I also get this message if i remove the endstop from ramp board.
17:17:08.439 : Reporting endstop status 17:17:08.439 : x_min: open 17:17:08.439 : x_max: TRIGGERED 17:17:08.439 : y_min: open 17:17:08.439 : y_max: TRIGGERED 17:17:08.439 : z_min: open 17:17:08.439 : z_max: TRIGGERED
Re: Folger Prusa i3 Kit from ebay October 31, 2014 04:10PM |
eoiser
I get this message when trying to move my stepper motors
I checked the wiring, and the end stop lights red
I also measured the voltage to check the switch
When sending M119 i get this
Any suggestions?
Re: Folger Prusa i3 Kit from ebay October 31, 2014 04:33PM |
Re: Folger Prusa i3 Kit from ebay October 31, 2014 04:54PM |
Re: Folger Prusa i3 Kit from ebay October 31, 2014 05:05PM |
#define X_MAX_POS 200 #define X_MIN_POS 0 #define Y_MAX_POS 200 #define Y_MIN_POS 0 #define Z_MAX_POS 185 #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
//X axis
#if X_HOME_DIR == -1
#ifdef BED_CENTER_AT_0_0
#define X_HOME_POS X_MAX_LENGTH * -0.5
#else
#define X_HOME_POS X_MIN_POS
#endif //BED_CENTER_AT_0_0
#else
#define X_HOME_POS X_MAX_LENGTH * 0.5
#else
#define X_HOME_POS X_MAX_POS
#endif //X_HOME_DIR == -1
Re: Folger Prusa i3 Kit from ebay October 31, 2014 05:19PM |
Re: Folger Prusa i3 Kit from ebay October 31, 2014 05:55PM |
Re: Folger Prusa i3 Kit from ebay October 31, 2014 09:17PM |
AKFoddy7
Just ordered another set of the stepper drivers, one of mine is toast (The pot only seats when I apply pressure). $10 for 4 from Hong Kong, figure if they work it will be good to have them as spares. I managed to order a J-Head hot end from Ontario. should be here Tuesday.
And for Eoiser, You want to remove the // from the disablemaxendstops (That is is you are using all min endstops).
It is in the Configuration.h file.
Re: Folger Prusa i3 Kit from ebay November 01, 2014 08:56AM |
Re: Folger Prusa i3 Kit from ebay November 01, 2014 01:51PM |
Re: Folger Prusa i3 Kit from ebay November 03, 2014 07:21PM |
eoiser
Thank you, that worked.
My next problem is i set my Z endstop to activate when the nozzle is just above the bed (home z). But when i start a a print i goes 10mm or so above the bed and prints
