Re: Folger Prusa i3 Kit from ebay November 18, 2014 09:14PM |
Re: Folger Prusa i3 Kit from ebay November 18, 2014 10:54PM |
Gannicus
Actually what it's doing now is just going back and forth again like I have the pins on the ramps miswired.
It WAS feeding to where I could see it go through the extruder...but now it's stopped, and instead just turns one click to feed, then the next click to reverse, ad nauseum.
I don't have a problem with figuring things out like this, but when the same thing doesn't create the same result...that's a touch infuriating.
NukedWorker
So I went ahead and switched the X and Extruder motors. And it still was doing the jig. So I knew then it had to be something I did. After sitting a few minutes just brewing and stewing, I figured, go back to the beginning - and there it was. The 2 middle wires were in the pin connector wrong. Switched them up and VOILA! I didn't know whether to laugh or cry.
Re: Folger Prusa i3 Kit from ebay November 18, 2014 11:12PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 12:01AM |
Gannicus
Is the pin out on the RAMPS side for the extruder not the same as all the other steppers? Cause I have all five pinned out the same way:
GREEN
YELLOW
GREY
RED
Re: Folger Prusa i3 Kit from ebay November 19, 2014 07:23AM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 07:34AM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 09:31AM |
Zavashier
1) Check pololu's output voltage. You need 0.18v on extruder, X and Z drivers ; and 0.66v on the Y driver output.
2) Check Marlin's configuration and library installation, it's a soft problem.
3) Your glass plate/support plate is not flat. It's maybe two fails working together. Try to flip or rotate it to get a better balance between hi and low points.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 10:02AM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 11:28AM |
louspinuso
SteveRoy
As Gannicus posted - for the Y end stop, if it's at the back it's a MIN, if at the front it's a MAX. You need to change the firmware and the position on the RAMPS to suit.
Same with X, if it's on the left it's a MIN, on the right a MAX
Steve
See, this is what's blowing my mind. The X endstop is on the right but it's in the MIN position. I think that the more I look at this, what's really going on is that the printer is just moving to whatever direction it thinks home is stopping when it hits the endstop and then this is taking over:
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
Which is what I think was messing with my ability to move the motors in both directions until it forced an endstop touch on the home position and then it was like "Oh, you have plenty of space to go in this direction" and allowed me to go. I really believe this was the source of the endstop errors I was getting ("echo:endstops hit: X:-49.94").
And still the HOME_DIR for all of my axis are set to -1
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
which should indicate that the motors should move to the opposite of where I would expect them to go (except for Z) but they don't. I almost feel like I need to drag myself through the code for Marlin to figure out what the thing is doing but I think just flipping my y axis plug will actually make this work how I want, as opposed to switching the line:
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false
to true, though that may cause even more trouble for me.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 11:45AM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 11:46AM |
Zavashier
That voltage is much higher thant the Pololu's calculation formula (provided in the Folger's drive thru...) shows. Some of my motors was too hot with some loose steps. So I did the calculation and found that values. My i3 is now pretty quiet, the motors are cold, and everything is working propperly. Choose the values you like.
I have the same display. Working. Here's my configuration.h. The library have to be installed into the Arduino library folder to compile properly. Maybe you already know.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 12:12PM |
Gannicus
Steve, I just gave in and relocated the X end stop to the left. No matter what I did, it didn't want to work on the right hand side. /shrug
In the end, cutting some wire ties fiddling with wire loom was worth the time spent instead of the Vodoo Magic I was trying in order to get it to work properly.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 02:26PM |
SteveRoy
If your X endstop is on the right, and when you press + in pronterface the carriage should go right. Then if you set X to a MAX end stop in Marlin and click the X home in pronterface the carriage should go right.
The end stop should be wired to X MAX on the RAMPS otherwise it won't stop the carriage when tripped.
louspinuso
X end stop on the left, Y at the back, Z on the bottom
louspinuso
You can either change the code between true/false or reverse the plug on the RAMPS - stand difference
Steve
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1
Re: Folger Prusa i3 Kit from ebay November 19, 2014 05:27PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 05:28PM |
Gannicus
Re: Folger Prusa i3 Kit from ebay November 19, 2014 05:35PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 05:38PM |
Gannicus
Here's the new news.
During the day, I got to thinking...the Folgertech Marlin software on their Google Drive was probably the cause of EVERY problem I was having.
So, I downloaded the fresh copy of Marlin from github and Dooms101 configuration.h he posted on page 2, and recompiled and uploaded.
Plugged in the LCD... and poof. Magic. Everything works. EXCEPT for the hotend.
Here's where I'm at. The extruder IS feeding INTO the hotend now. But once the entire length gets to the hotend, while the extruder will TRY to push it into the hotend, it just sits there.
I've included a youtube video. You can see the screen working, and the temp. I turned the hotend all the way up to 245C...and STILL you can hear it once I hit extrude, the bang sound of the extruder feeding it into the hotend, and it sounds like it just bouncing off a solid object in the hotend.
I want to get this thing printing already. The stepper drivers have all been dialed in to John's specifications from an earlier post received from the guys at Folgertech that everyone says work like a dream.
Well, without further dudes...on with the show.
YOUTUBE LINK
Re: Folger Prusa i3 Kit from ebay November 19, 2014 05:55PM |
louspinuso
Gannicus
YOUTUBE LINK
That's teh same sound mine was making when it got stuck on feeding. I pulled the filament out and I was able to straighten the tip out just enough to get it to feed (though it seems like you're already feeding now) so my guess is that there is something in the way in your extruder. I hate to say it, but you may need to take it apart to check. I still haven't taken mine apart so I'm not sure what is involved in that feat.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 06:21PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 06:44PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 09:33PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 09:53PM |
louspinuso
Ok, so I've finally put plastic through my hot end and everything seems to be working right so I went to load a calibration cube to print and I watched the hot end temp get up to about 70C and then start dropping. The hot bed kept heating, but really slowly. I know I got the hot end up to temp to get the test piece to feed so I'm not sure what's going on. At this point I've umplugged everything and I'm letting the whole thing cool off. I know that there has been talk about taking a long time to heat up, but has anyone ever seen their hotend suddenly start losing heat? Also it's a bit colder in my house than regular. At the moment it's probably right around 20c but normally closer to 24c. Could that make that much of a difference? I do plan on making an enclosure for the kit anyway (like I stated in an earlier post) Anyone think that will help? Maybe a fan to cool the ramps board? one of those mosfets does seem to get pretty warm.
Thoughts?
Re: Folger Prusa i3 Kit from ebay November 19, 2014 10:23PM |
Gannicus
Got it. Had to push it in harder, and twist it. Finally grabbed.
Tried to print a test box, and from home to start printing, the nozzle lifted way higher than the paper thick closeness I had set previously.
And just squirted out black strands all over the place.
Why would it raise up higher than where I had set my homes?
I want it right on the glass, not 1/4 inch above it.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 10:31PM |
louspinuso
Gannicus
Just curious but in your slic3r settings, do you have a Z offset?
[attachment 44000 ScreenShot057.jpg]
Re: Folger Prusa i3 Kit from ebay November 19, 2014 10:41PM |
zorg1179
I am guessing that you hit start print and this happened. My bed took a while to heat up too, sometimes up to 20 min to hit 100c. Normal operation of the printer is to heat the bed to the set temp, then heat the extruder(it heats much faster). If you have the extruder at temp while waiting on the bed, the filament inside the extruder will get soft and fail to feed properly. I see this anytime my extruder is sitting for more than a few minutes without feeding. I put some insulation between the bed and the y carriage. This sped up my bed heat time a small amount. I recently added an enclosure. Now, the bed is up to temp in about 5min.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 10:45PM |
Gannicus
Don't user slic3r.
I'm trying cura now, but have simplify3d that I plan to use instead.
Re: Folger Prusa i3 Kit from ebay November 19, 2014 11:07PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 11:18PM |
Re: Folger Prusa i3 Kit from ebay November 19, 2014 11:38PM |
Re: Folger Prusa i3 Kit from ebay November 20, 2014 05:46AM |
