Re: Folger Prusa i3 Kit from ebay November 23, 2014 10:38AM |
Waltermixx
My extruder came with two nuts, tightened up against the hot block. I removed one and now I only have one nut now tightened up against the cooling block...
Re: Folger Prusa i3 Kit from ebay November 23, 2014 11:35AM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 12:14PM |
Waltermixx
can you post pictures of your extruder close up, hot end and cooling block
and how far up the threaded hole in the cooling block are you?
here is a pic of mine
closer pic:
Re: Folger Prusa i3 Kit from ebay November 23, 2014 12:54PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 01:22PM |
Gannicus
Sorry to keep making so many replies guys, but I notice on every Prusa kit BESIDES this one, the idlers have tensioner screws in them. My Y axis belt is tight (though it could stand to be a bit tighter) but my X has a lot of slop in it. I don't like the idea of the metal tension clips, as they must interfere at some point, and would rather have a proper adjustment for it.
Does anyone have a STL of either, preferably the X, but I'd love them both.
Thanks!
Re: Folger Prusa i3 Kit from ebay November 23, 2014 01:30PM |
Waltermixx
Your fan is facing the wrong way...
it should be label in, not out...
so perhaps it is not cooling the cool end properly...
it makes a difference... other than that it does look good.
Re: Folger Prusa i3 Kit from ebay November 23, 2014 01:49PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 01:51PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 01:56PM |
SteveRoy
Gannicus
Thanks!
Not sure if the Folger kit uses "rework" design X-motor/idler, but if it does this is what I use on my rework
[www.thingiverse.com]
Steve
Re: Folger Prusa i3 Kit from ebay November 23, 2014 01:57PM |
Waltermixx
Here's a review of the Folgertech Prusa i3... on youtube
[www.youtube.com]
it's about 25 minutes long
Re: Folger Prusa i3 Kit from ebay November 23, 2014 02:20PM |
louspinuso
Waltermixx
Are you sure? I'm pretty sure that the fan was in that orientation when I got the extruder. I'll take it off and take a look.
Ok, took it off and found that there are labels on both sides, but the screws are really meant to go in from one side, the side I have them going in through so I'm pretty sure that they are right.
Front:
[attachment 44198 extruderfanfront.jpg]
Back:
[attachment 44199 extruderfanback.jpg]
Re: Folger Prusa i3 Kit from ebay November 23, 2014 02:38PM |
Waltermixx
Ok sorry, I was basing this on my fan, and makerbot replicator 2 fan, where the label faces in...
direction of air should be into the fan, not blowing out of the fan, if that helps. , so it should be sucking air in,
and blowing it towards the heat sink... Too bad i was really hoping that was the issue...
Re: Folger Prusa i3 Kit from ebay November 23, 2014 02:59PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 03:45PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 03:47PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 04:50PM |
Gannicus
Thanks!
Re: Folger Prusa i3 Kit from ebay November 23, 2014 05:45PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 06:11PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 08:25PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 08:27PM |
Wpflum
Just to add to the general info I recently picked up a tube of 'Super Lube' a multipurpose synthetic lube with PTFE in it from Harbor Freight, I luck out in having an actual brick and mortar one a couple of miles away, for about 7 bucks. I saw this lube recommended on the reprap wiki page for lubrication and I must say after putting it on both the smooth and threaded rods everything is quieter and smoother feeling when I move the carriages by hand. Much better than the squeaking I was getting during prints
Re: Folger Prusa i3 Kit from ebay November 23, 2014 08:40PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 08:47PM |
Waltermixx
they will most likely go in the spool holder you print for your printer...
they are spares... i had those as well. so i used them in a spool holder
Re: Folger Prusa i3 Kit from ebay November 23, 2014 08:51PM |
Easy
Zavashier
Bad news today... Less than 100 hours printing. The hotend started to twist during printing, then fall out.
Maybe this is a clue for people that are having problems with extruding filament.
Re: Folger Prusa i3 Kit from ebay November 23, 2014 09:10PM |
Re: Folger Prusa i3 Kit from ebay November 23, 2014 09:12PM |
Re: Folger Prusa i3 Kit from ebay November 24, 2014 05:05AM |
A clue ? Hmm. I realy don't know why that happens. I did not noticed any crack. I had no problems with extruding since the start, The steps per mm of the extruder needs no adjusting. My parts were pretty clean and without any gap between paths. Looking at the unfinished part, at the moment of the crash the flow was as good as expected. I guess that was something wrong into the steel or maybe a previous hit during the shipping. The package was in good shape, but I had some of the frame parts broken. I don't forget the kit is 100% chinese parts too.Quote
EasyMaybe this is a clue for people that are having problems with extruding filament.Quote
Zavashier
I measured the wall thickness of the part at the break point, and it is 0.4 to 0.2mm because the hole is a bit off centre. Chinese parts... This is pretty thin, you're absolutely right. Same hardware should lead to same problems. I decided to upgrade the extruder to a shopmade E3D extruder. I wish things will be even better and will allow me to raise a bit the temperature. With the provided hot end, the filament gets a bit too hot in the tubing at 230°C during long prints. I measured with a IR thermometer and it gets up to 200°C, so you need to low the extruder temperature to 225 or lower. I thought the kit was a base, not a durable printer anyways.Quote
AKFoddy7
Zavashier, Exact same place I broke mine. That throat is awfully thin!. You can pick them up from Ebay for next to nothing, just make sure they have the PTFE (Teflon) tube inside. There isn't enough of a heat break without it.
Re: Folger Prusa i3 Kit from ebay November 24, 2014 06:18AM |
Re: Folger Prusa i3 Kit from ebay November 24, 2014 12:42PM |
Re: Folger Prusa i3 Kit from ebay November 24, 2014 01:13PM |
Re: Folger Prusa i3 Kit from ebay November 24, 2014 04:26PM |
