Re: Folger Prusa i3 Kit from ebay November 29, 2014 10:49PM |
Re: Folger Prusa i3 Kit from ebay November 30, 2014 01:30AM |
Re: Folger Prusa i3 Kit from ebay November 30, 2014 01:58AM |
Re: Folger Prusa i3 Kit from ebay November 30, 2014 01:48PM |
Re: Folger Prusa i3 Kit from ebay November 30, 2014 01:57PM |
Re: Folger Prusa i3 Kit from ebay November 30, 2014 02:03PM |
Re: Folger Prusa i3 Kit from ebay November 30, 2014 02:41PM |
im having the same problem, abliet much less profound. i have contacted folgertech about it, to see if it is a widespread problem. waiting on a reply.Quote
mikez104
My X axis is nice and smooth but the Y axis is not. When the bed moves, it kind of jerks. Here is a pic of what I think should look smooth but actually looks like rope.
Re: Folger Prusa i3 Kit from ebay November 30, 2014 02:58PM |
Re: Folger Prusa i3 Kit from ebay November 30, 2014 03:36PM |
Try re leveling the print bed, it can be caused by a bed that isn't flat. Too much distance between the extruder and the bed.Quote
btyder
mikez104
Re: Folger Prusa i3 Kit from ebay November 30, 2014 04:43PM |
You need to level your bed and bring your nozzle closer to the bed.Quote
mikez104
Re: Folger Prusa i3 Kit from ebay November 30, 2014 08:29PM |
amphiox
i was getting mirrored prints along the x axis as well.. i have my x endstop on the right and y on the back..with xmotor being on the right.. ymotor on back..so the home point was 0,0 on the front right corner.. but after configuring marlin with my config .home is now 0,0 on the front left corner.. but homes to the max endstop. .. it does do a 5mm bounce as configured in Configuraitonadv.h . full graphics controller is also enabled on it as well. .as someone pointed out earlier as well. they were using pidtempbed? i dont have that enabled.. didnt know if this hardware worked for it.. but the bed heats up just fine without it..(pcb heatbed r1 dual power..)
also dont forget to switch the endstop connector on your ramps 1.4 board to the max.. from top to bottom it goes.. zmax zmin ymax ymin, xmax xmin..
and adjust your max movement if you wish i set it 185 so i wouldnt hit clips and m3 bolts
also another note.. it works as described from the lcd screen.. you may have to change thigns in repetier host.. i posted a picture
here is my config took me a few hours to figure it out as i didnt want to move my endstops..
[attachment 44479 Configuration.h]
picture of repetier host printer settings
[attachment 44480 curainvertx.png]
Re: Folger Prusa i3 Kit from ebay November 30, 2014 08:32PM |
louspinuso
mikez104
Re: Folger Prusa i3 Kit from ebay November 30, 2014 09:11PM |
Are you checking the level at all four corners?Quote
mikez104
louspinuso
mikez104
I'll tty again but that was right after I leveled it. And I've been having trouble with the head looking like it is too far from the bed. When I level it, I can just get a piece of paper under it then it seems too rise and print too high.
Re: Folger Prusa i3 Kit from ebay November 30, 2014 09:16PM |
louspinuso
mikez104
louspinuso
Are you checking the level at all four" corners?
Yes. I've done it several times. The Y axis just seems not smooth. I don't know how else to describe it. When I disconnect the motor, it seems smooth. Its like there is no micro stepping but I have the jumpers installed.
Re: Folger Prusa i3 Kit from ebay November 30, 2014 10:36PM |
mikez104
louspinuso
Maybe the stepper isn't getting enough power.Quote
mikez104
louspinuso
Re: Folger Prusa i3 Kit from ebay December 01, 2014 03:56PM |
HairLikeFrodo
mikez104
louspinuso
Re: Folger Prusa i3 Kit from ebay December 01, 2014 04:22PM |
Re: Folger Prusa i3 Kit from ebay December 01, 2014 06:38PM |
[Problem] Not moving on (+) positive axis December 01, 2014 10:12PM |
Re: [Problem] Not moving on (+) positive axis December 01, 2014 10:20PM |
juanmagmen
Does any body had this problem?, when I try to move it or any positive axis, it send me a message "echo:endstops hit: X:-0.10" depends what axis I'm trying to move, but my endstop is not press, also I notice a steady hum or continuous beep, like a tinnitus when I press to move it on positive axis, that only stops if I press the "Turn Motor off", I already invert the cables and Configuration.h and it does move the other way but always with the (-) negative axis, what makes me thing the motor and the cables are correct, I tried to move on and install the REPRAP_DISCOUNT_SMART_CONTROLLER to see if send me any error messages, and it does power on (blue screen) but it does not show information I will appreciate any information, thank you....
Re: [Problem] Not moving on (+) positive axis December 01, 2014 10:29PM |
louspinuso
juanmagmen
I had that same problem. Turned out to be that you need to home the motor first otherwise it doesn't know how far it has traveled. Be sure to have the end stop plugged into the right plug (max or min end stop) and that is set right in the configuration.h file.
And be ready to pull the plug if it thinks home is towards the side without the end stop. That high pitch sound either means too much power or not enough (I don't remember) check your vrefs and make sure they are set right and don't try to adjust them unless the motors are off. And are all the jumpers on the board? They need to be under the pololu boards.
As for the display, I posted back a bit the webpage that had the directions to follow to get that display working. You need to edit 2 files.
Good luck
Re: Folger Prusa i3 Kit from ebay December 02, 2014 02:53AM |
Re: Folger Prusa i3 Kit from ebay December 02, 2014 04:05AM |
Re: Folger Prusa i3 Kit from ebay December 02, 2014 08:45AM |
Re: Folger Prusa i3 Kit from ebay December 02, 2014 11:20AM |
Re: Folger Prusa i3 Kit from ebay December 02, 2014 11:53AM |
Re: Folger Prusa i3 Kit from ebay December 02, 2014 12:07PM |
Re: Folger Prusa i3 Kit from ebay December 02, 2014 12:18PM |
djcdude95
Hey guys! I don't know if anyone has posted it, but I did a full review of the Folger Tech Prusa i3.
[www.youtube.com]
Enjoy!
Re: Folger Prusa i3 Kit from ebay December 02, 2014 12:40PM |
Re: Folger Prusa i3 Kit from ebay December 02, 2014 02:38PM |
djcdude95
[www.youtube.com]
Enjoy!
