Re: Folger Prusa i3 Kit from ebay December 02, 2014 10:31PM |
amphiox
i was getting mirrored prints along the x axis as well.. i have my x endstop on the right and y on the back..with xmotor being on the right.. ymotor on back..so the home point was 0,0 on the front right corner.. but after configuring marlin with my config .home is now 0,0 on the front left corner.. but homes to the max endstop. .. it does do a 5mm bounce as configured in Configuraitonadv.h . full graphics controller is also enabled on it as well. .as someone pointed out earlier as well. they were using pidtempbed? i dont have that enabled.. didnt know if this hardware worked for it.. but the bed heats up just fine without it..(pcb heatbed r1 dual power..)
also dont forget to switch the endstop connector on your ramps 1.4 board to the max.. from top to bottom it goes.. zmax zmin ymax ymin, xmax xmin..
and adjust your max movement if you wish i set it 185 so i wouldnt hit clips and m3 bolts
also another note.. it works as described from the lcd screen.. you may have to change thigns in repetier host.. i posted a picture
here is my config took me a few hours to figure it out as i didnt want to move my endstops..
[attachment 44479 Configuration.h]
picture of repetier host printer settings
[attachment 44480 curainvertx.png]
Re: Folger Prusa i3 Kit from ebay December 03, 2014 06:23AM |
Re: Folger Prusa i3 Kit from ebay December 03, 2014 08:56AM |
Re: Folger Prusa i3 Kit from ebay December 03, 2014 09:35AM |
Re: Folger Prusa i3 Kit from ebay December 03, 2014 10:49AM |
Zavashier
Gannicus, check your bushings they should be well tightened and with no cracks. If they cracked (most of mine cracked) try to fix them with CA glue. If not, it's just a question of setup. Set your rods a bit more away from eachother. That will reduce the existing clearance. There's some gap betwen bearings and the rods. Remember the bed must keep on sliding easy, with no noise.
Re: Folger Prusa i3 Kit from ebay December 03, 2014 11:18AM |
Re: Folger Prusa i3 Kit from ebay December 03, 2014 11:58AM |
Waltermixx
Also double check that the M3 bolts holding the y-belt connector is tight... mine would loosen, so I put locktight on them, and locking nuts...
Re: Folger Prusa i3 Kit from ebay December 03, 2014 12:36PM |
Waltermixx
Re: Folger Prusa i3 Kit from ebay December 03, 2014 01:20PM |
Re: Folger Prusa i3 Kit from ebay December 03, 2014 02:38PM |
mikez104
Waltermixx
As I posted several posts back, I have been trying to track down weird wobbly print issues. You can see the photos on page 21 of this thread. Well last night I leveled the bed for the tenth time and started to print and it seemed off again. So I watched it for a while and what I did notice was just that, those M3 nuts had come loose and the bed was moving. I tightened them up and re tightened the Y belt and things improved but are still not where I think they should be. I used the nuts with the nylon inserts. I though that they would hold pretty well but I guess not.
Re: Folger Prusa i3 Kit from ebay December 03, 2014 02:45PM |
Re: Folger Prusa i3 Kit from ebay December 03, 2014 08:37PM |
Re: Folger Prusa i3 Kit from ebay December 03, 2014 09:56PM |
Zavashier
Hi all, finaly some news from John from Folger. It looks like he did not read my messages in time. He awnsered more than 10 days after my message, when I gave my evaluatuion of the item on ebay. Hopefully John have a great sense of service and is sending to me some of the broken parts. We talked about the kit and encountered problems, some already known by him. Good news for future owners: Folger is switching from PLA to ABS for the printed parts of the kit. Those parts will be stronger, with more flex for an easyer mounting of the bearings.
Re: Folger Prusa i3 Kit from ebay December 04, 2014 01:28AM |
Re: Folger Prusa i3 Kit from ebay December 04, 2014 07:02AM |
mikez104
Made my first real print tonight. I made a spool holder from ABS and it did not turn out too bad. Nothing really went wrong during the print. I'm still getting the "chain" look to the extrusion though.
After that print, I found a spool holder that I liked better so I decided to print that in PLA because I got sick of the ABS smell after smelling it for 4 hours. that's when things went bad. I set the bed for 60 degrees and the hot end for 185 and it started to go ok then the clicking in the extruder started. I then quit and slowed the print down and the clicking started again. I tried to raise the temp of the extruder. I went from 185 all the way to 210 and it made no difference. I quit for the night as it is late. After I stopped the print, I Raised the Z axis and was able to click the extrude button and it extruded without issue. No clicking. I must have run a foot of filament through it without any issues.
Any ideas why the ABS seems to work ok but the PLA will not? It works fine in my son's printrbot simple.
Also I think the "chain" look is not from the bed or anything else, I think it is from the extruder. It seems to kind of pulse as it extrudes. Maybe the two issues (PLA and Pulsing) are related.
Re: Folger Prusa i3 Kit from ebay December 04, 2014 10:11AM |
Re: Folger Prusa i3 Kit from ebay December 04, 2014 10:51AM |
Re: Folger Prusa i3 Kit from ebay December 04, 2014 03:23PM |
KeyserSoze3d
What are you guys doing about wires. Mine are horrible. My printer its trapped in a very colorful spider web. I tried to use split loom to cover them and make it look pretty, but the added drag caused me to skip steps and all my parts were slanted along the Y axis.
Re: Folger Prusa i3 Kit from ebay December 04, 2014 07:22PM |
Re: Folger Prusa i3 Kit from ebay December 04, 2014 07:24PM |
KeyserSoze3d
Re: Folger Prusa i3 Kit from ebay December 04, 2014 09:33PM |
Re: Folger Prusa i3 Kit from ebay December 05, 2014 01:17AM |
Re: Folger Prusa i3 Kit from ebay December 05, 2014 01:43AM |
Re: Folger Prusa i3 Kit from ebay December 05, 2014 02:39AM |
Re: Folger Prusa i3 Kit from ebay December 05, 2014 05:31AM |
My advice : Expandable Braided Sleeving. holded by nylon zip ties and/or shrinkable tubing.Quote
KeyserSoze3d
Re: Folger Prusa i3 Kit from ebay December 05, 2014 10:50AM |
mikez104
Ok, I'll admit it, I didn't use locktite. Duh. Every screw in my bed support was loose. Took it all apart and use blue locktite. I should of listened.
Re: Folger Prusa i3 Kit from ebay December 05, 2014 11:00AM |
Zavashier
The shipping can be delayed 20 days, depending of the stock at Folger's.
KeyserSoze3d
Re: Folger Prusa i3 Kit from ebay December 05, 2014 11:08AM |
jrcaster
I ordered my kit on 17 November, UPS label generated on the first. Here it is the fourth and UPS has not received it yet? WTF!
Re: Folger Prusa i3 Kit from ebay December 05, 2014 11:22AM |
Easy
mikez104
There is a fluid you can buy that welds acrylic. You put it in a squeeze bottle that has a hollow needle, and you just touch the needle to an acrylic joint and the fluid runs into the joint and welds the acrylic together. You can buy the fluid and applicator bottle from Tapp Plastics. It is virtually invisible after application.
