Re: Folger Prusa i3 Kit from ebay December 18, 2014 08:18PM |
Re: Folger Prusa i3 Kit from ebay December 18, 2014 08:43PM |
Jamus
Thanks, I was posting while you posted the manual, thanks for all your effort on it. I think it will help most people, I see a lot of places it would have saved me some headaches.
I do have my fan on D9 and till now had not installed repetier host. It's installing now and I'll check the fan.
Sounds like my thermistor is bad then. Looks like ratshack doesn't carry them.
Re: Folger Prusa i3 Kit from ebay December 19, 2014 09:38AM |
cliferton1
getting better i guess lol. something is up with my z. x and y seem to have correct scale but z is stretched. i attached a pic of a part we make at work and a slightly scaled down version i just printed. I have not adjusted my stepper voltage no idea if thats going to have anything to do with it or should i be looking at marlin settings. the 20mm cube i printed was 19.98mmx19.97mmx25.7mm
Re: Folger Prusa i3 Kit from ebay December 19, 2014 10:39AM |
Re: Folger Prusa i3 Kit from ebay December 19, 2014 11:27AM |
Re: Folger Prusa i3 Kit from ebay December 19, 2014 01:50PM |
Re: Folger Prusa i3 Kit from ebay December 19, 2014 09:26PM |
Re: Folger Prusa i3 Kit from ebay December 19, 2014 09:34PM |
Re: Folger Prusa i3 Kit from ebay December 19, 2014 09:44PM |
Re: Folger Prusa i3 Kit from ebay December 19, 2014 10:41PM |
MakerFront
I worked with the people at FolgerTech (very accommodating by the way) and put 2 manuals together for the Prusa I3 from them. There's a build manual (rev 1.1) and a config guide for the marlin/repetier/slicer config.
So, here's the two manuals:
[drive.google.com]
Enjoy everybody!
Re: Folger Prusa i3 Kit from ebay December 19, 2014 10:51PM |
dooms101
Here's an update on my adjustments to the extruder. Looks like it fixed the problem, I just got done with a perfect 3 hour print of a really tricky T-Rex skull that failed several times before I made the adjustments. I also sped up the max_feed_rate in marlin to 150, 150, 3, 25 which made the print crazy fast. I'm also using a 0.152mm layer height which is giving really really smooth prints.
Now that I'm convinced that it works I'm going to design a shroud that will replace the nylon spacers I used as well as avoiding the need to tape everything. I'll also redirect the vented air as right now it blows down on the print and causes a little bit of warping.
Here's a better angle of the extruder that shows how things are now spaced out:
[attachment 41861 2014-10-1322.03.56-1.jpg]
Re: Folger Prusa i3 Kit from ebay December 20, 2014 12:22AM |
Re: Folger Prusa i3 Kit from ebay December 20, 2014 02:18AM |
Re: Folger Prusa i3 Kit from ebay December 20, 2014 10:22AM |
cliferton1
Ok been at it tonight. I tried the numbers you had posted (79.84, 80,3836.93,101) as a start and the cube was x=19.84mm,y=19.79mm, z 19.62mm. so im still a little off there. How should I go about correcting this?
trying to test print some stuff. im having trouble with the part coming off during print. I was using painters tape. now I wiped it with alchaol and have the bed at 80*c. so far this z vibration bushing is printing ok at the moment, but it is stringing a little bit im using pla and am up to 220*c. just trying diff temps ........just came off crap. the center the center hole is kinda globby. I was trying to do a .1 layer model. gonna try 1 more time tonight with same settings as the as I did the cube it looked great just a little off in size with .2 layers.
when I draw and save a stl in autodesk inventor and load it it is tiny and I have to scale up. in pronter... it was scaled down 1000. in repiter host I am not sure of the scale. parts I download import fine. I am drawing the parts 1/1 scale and in metric mode. I would try a different cad software, but I use it everyday for work and am very familiar with it. any insite on that?
louspinuso
For question 2, try this [reprap.org]. I've been using a 20mm hollow cube to calibrate and this formula:
new_e_steps = old_e_steps * (20 / distance_actually_moved)
Re: Folger Prusa i3 Kit from ebay December 20, 2014 10:43AM |
Re: Folger Prusa i3 Kit from ebay December 20, 2014 07:05PM |
Re: Folger Prusa i3 Kit from ebay December 20, 2014 07:56PM |
konto89
Watch this video [youtu.be] . I have the same display did what the guy said and it worked!
Re: Folger Prusa i3 Kit from ebay December 20, 2014 09:18PM |
Re: Folger Prusa i3 Kit from ebay December 20, 2014 10:29PM |
Re: Folger Prusa i3 Kit from ebay December 21, 2014 06:40AM |
Re: Folger Prusa i3 Kit from ebay December 21, 2014 03:53PM |
BayAreaRepRap
konto89
did you use the folger tech firmware in the google drive? I can't get it to work with that by doing what he did in the video. I've uncommented reprap_discount and added the U8glib.h to the library folder and Sketch->import library to my current arduino sketch, save it and upload and nothing comes up on the screen.
Did you mess with anything else?
Re: Folger Prusa i3 Kit from ebay December 21, 2014 06:33PM |
Re: Folger Prusa i3 Kit from ebay December 21, 2014 06:42PM |
vonnieda
Hi all,
I put together a GitHub Wiki with many of the commonly referenced resources from this thread. I often find myself trying to find something in this thread and it's not much fun to dig through 29 pages to get it
The Wiki is publicly editable, so if you'd like to please feel free to add on and improve it!
[github.com]
Jason
Re: Folger Prusa i3 Kit from ebay December 21, 2014 11:53PM |
Re: Folger Prusa i3 Kit from ebay December 22, 2014 01:49AM |
Re: Folger Prusa i3 Kit from ebay December 22, 2014 11:08AM |
jrcaster
As far as the range to use on the multimeter, it should have either a 2 or 4 volt range.
Re: Folger Prusa i3 Kit from ebay December 22, 2014 11:48AM |
vonnieda
Hi all,
I put together a GitHub Wiki with many of the commonly referenced resources from this thread. I often find myself trying to find something in this thread and it's not much fun to dig through 29 pages to get it smiling smiley
[github.com]
Re: Folger Prusa i3 Kit from ebay December 22, 2014 01:56PM |
BayAreaRepRap
konto89
Re: Folger Prusa i3 Kit from ebay December 22, 2014 02:09PM |
KeyserSoze3d
BayAreaRepRap
konto89
I am having the same problem I used working folgertech firmware with and without changing the #define_reprap_dsicount_smart_controller to #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
I downloaded a new marlin, still nothing.
Re: Folger Prusa i3 Kit from ebay December 22, 2014 04:50PM |
konto89
KeyserSoze3d
BayAreaRepRap
konto89
Did you check the wires? Maybe you putted them the wrong way?
