Re: Folger Prusa i3 Kit from ebay December 31, 2014 10:47PM |
Newtoprinting
jrcaster
Make sure you have all of the relevent files in the directory before you compile to arduino. Looks like you are missing the files that it is looking for.
Can I try your marlin zip
Re: Folger Prusa i3 Kit from ebay January 01, 2015 03:02AM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 03:25AM |
Mine is set to the voltages recommended in the new Folger tech manual. .35 .50 .35 .35 I believe. Are your bearing holders on the tray tight? Or the belt in line?Quote
HairLikeFrodo
I'm just wondering what you guys have your vref pots on your stepper drivers set at. Mine are the standard .35v and .45v for the Y axis. I'm still getting that strange diagonal pattern.
Re: Folger Prusa i3 Kit from ebay January 01, 2015 08:31AM |
parksie
Newtoprinting
jrcaster
Try other peoples Marlin verison isn't really going to help. The issue you are getting is either a C ompiler issue, or you are missing the source files .cpp from the Marlin Zip. Can you please confrim if you have EVER had a a succesfull compile with Arduino IDE and Marlin Firmware?
Re: Folger Prusa i3 Kit from ebay January 01, 2015 11:30AM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 12:50PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 01:12PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 01:18PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 04:27PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 04:32PM |
bengele
Hoping that someone who is better at electronics can verify what I am going to do. I am trying to follow Tom's Guide on setting up auto bed leveling
3D printing guides: Setting up auto bed tramming leveling tilt compensation!
I am going to just use the open terminals on the power supply to get 12v input and ground. It looks to me like the pin closest to the edge of the ramps board is where I need to hook up the output.
Does that look right? I would prefer not to fry anything.
Re: Folger Prusa i3 Kit from ebay January 01, 2015 05:12PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 06:13PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 07:35PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 09:51PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 11:35PM |
Re: Folger Prusa i3 Kit from ebay January 01, 2015 11:46PM |
Re: Folger Prusa i3 Kit from ebay January 02, 2015 12:07AM |
mikez104
That's cool czmorris!. Can you show a pic of how you have that all mounted? My printer is doing well but i'd like to go with dual extruders also but am not sure how to go about that. I've had very little problems with mine since I swapped the bed out with the aluminum one. Hell, I only tweeked the bed height once since I installed it. I use to have to set it almost every print.
Re: Folger Prusa i3 Kit from ebay January 02, 2015 06:41AM |
Re: Folger Prusa i3 Kit from ebay January 02, 2015 04:27PM |
Re: Folger Prusa i3 Kit from ebay January 02, 2015 07:20PM |
Algag
Hello all, really sorry if this has already been asked, but this thread is huge and I'm new here. My folger prusa just arrived, and whenever I started building the frame, two of the holes seemed to be too small, and I also seemed to be missing two nuts/screws. Are we supposed to use the M3 nuts when you attach the "top supports" (the funny shaped things that connect the main frame and the large vertical supports)? If we weren't that would solve both of my problems. The video shows SOMETHING going in there but I don't know what else it would be. Thanks in advance!
Re: Folger Prusa i3 Kit from ebay January 02, 2015 07:41PM |
Re: Folger Prusa i3 Kit from ebay January 02, 2015 09:11PM |
czmorris
mikez104
Sure, I will take a few photos and post tomorrow afternoon when I get a chance.
Basically right now it is the standard mount that comes with the kit but using longer screws connecting to only one stepper motor of the pair. I reprinted all of my parts from the kit in ABS rather than PLA. I plan on making a new x-carriage mount which is a bit more beefy eventually but this seems to be working well for now. Currently I lose about a half inch in build area in the x direction.
I haven't had any issues with my bed so far after replacing the Y-axis bearing holders. It does sag just slightly in the middle when I do not have the perfboard clipped in place but this generally isn't an issue for prints and doesn't seem to affect the print surface temp very much. Current repeatability is very good.
My main purpose for upgrading to dual extruders is to be able to use dissolving HIPS as support material for really complex prints. I have some HIPS and solvent on the way to give that a shot. It also adds the benefit of being able to use a different filament for infill material.
Re: Folger Prusa i3 Kit from ebay January 02, 2015 10:19PM |
Jamus
So my next issue has been with the extruder. After some swapping and tinkering it turned out to be a bad stepper controller, good thing they provide an extra. After swapping that out I have movement of filament. Now my problem is that it's backwards. I hit extrude in pronterface and it reverses, I hit reverse and it extrudes. Is there a way to invert the direction in pronterface or would it be in marlin? I suspect it would be in the portion of marlin I have below but wanted to ask the experts. My best guess is change INVERT E0 to TRUE. Am I right?
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
That was it, got it spitting out plastic.
Re: Folger Prusa i3 Kit from ebay January 03, 2015 12:27AM |
czmorris
czmorris
mikez104
Pictures can be found here.
Re: Folger Prusa i3 Kit from ebay January 03, 2015 04:00PM |
Re: Folger Prusa i3 Kit from ebay January 05, 2015 10:56AM |
Re: Folger Prusa i3 Kit from ebay January 05, 2015 08:31PM |
Re: Folger Prusa i3 Kit from ebay January 05, 2015 11:13PM |
dooms101
[attachment 40104 2014-09-1123.56.14.jpg]
Final pictures of a spiral vase I printed. I think I need to lower my z-axis endstop just slightly, the adhesion of the first or second layer to the rest of the print isn't that great. Other than that, I'd say this printer rocks!
This print took about 3 hours to complete, I wonder if I could speed it up a bit. I'm not sure how long a 'better' printer could do it in...
Next, I'll be desining a spool holder, I'll put the link up here so others with this kit (or any Prusa i3) can build one too.
Re: Folger Prusa i3 Kit from ebay January 05, 2015 11:49PM |
bengele
Re: Folger Prusa i3 Kit from ebay January 05, 2015 11:55PM |
bengele
bengele
In case anyone else finds is attempting to do the same thing wiring it up this way worked.
Does anyone have any tips on unloading the filament? I reverse the extruder but most of the time the melted end of the plastic gets caught in the gear and I have to take it apart to get it out.
