Re: Folger Prusa i3 Kit from ebay March 19, 2015 12:45PM |
Zavashier
IMPORTANT NOTE
I wondered why there were a noticeable difference between X and Z dimentions to my prints. Then I found where it comes from, and fixed it.
You definitely want to change the printed pulleys provided by Folger because they are ways too big. Some explanations : The Folger's printed pulleys have a contact diameter of 15.8mm, let's say 16mm. The pitch diameter of a 20 tooth GT2 pulley is (Pitch x Number of teeth) / Pi = (2*20)/Pi = 12,73mm. So they're definitely wrong. BUT, the pulley's pitch diameter differs of an idler pulley contact diameter. Because the tooth lay inside the pulley, and must have enough space on the idler pulley for the same belt pitch diameter. You need to remove the tooth eight plus the PLD of the pitch diameter to get the right diameter. So the GT2 belt's PLD is 0.254mm and the tooth eight is 0.75mm. You need to substact those two times for the diameter, so the formula is Pitch diameter - ((PLD+Tooth height)*2) = 12.73 - ((0.254+0.75)*2) = 10.72mm So you'd rather use the bearing alone, you're more closer ! You need to print a 10.72mm idler pulley if you've got a nozzle thin enough (0.3 or less) and/or buy a 694ZZ bearing mounted with M4 bolt and nut, and accept a 0.27mm error, which is tangently no big deal.
5mm of error on the diameter of the idler pulleys... Just a tiny gap !
Re: Folger Prusa i3 Kit from ebay March 19, 2015 12:51PM |
Re: Folger Prusa i3 Kit from ebay March 19, 2015 02:53PM |
Of course it affects if the system is not parallel. As far the pulleys form a triangle with the bet attachment, the travel is not equal to the travel around the driving pulley. That was the problem on my printer. See attached picture. If you still desagree, I don't want to argue. Ask an engineer you trust.Quote
TheLost
Wait.. what?
Are you talking about the X & Y idler pulleys? (the only 'printed pulleys' included in the kit).. cuz.. the size of the idler pulley has no affect on speed/travel distance of the X or Y carriage.
Re: Folger Prusa i3 Kit from ebay March 19, 2015 04:19PM |
Zavashier
TheLost
Wait.. what?
Re: Folger Prusa i3 Kit from ebay March 19, 2015 04:26PM |
Re: Folger Prusa i3 Kit from ebay March 19, 2015 05:03PM |
TheLost
Zavashier
TheLost
Wait.. what?
Not arguing.. Just curious.. (i took physics and mechanical engineering in college).
How does the idler pulley size change the distance the belt travels? (answer.. it cant)
[www.prusaprinters.org]
(i don't see an input for idler pulley size)
For the record... I've ran the stock Folger pulleys (Y & X) since i got the kit and my prints are dead-on-accurate. I could put a 50mm pulley on my X Idler and as long as my firmware settings are accurate for my motor/belt/gear ratios it will have no affect.
Again... not arguing.. just want to make sure we are not speeding wrong information.
Re: Folger Prusa i3 Kit from ebay March 19, 2015 06:55PM |
Re: Folger Prusa i3 Kit from ebay March 19, 2015 09:28PM |
Re: Folger Prusa i3 Kit from ebay March 20, 2015 10:26AM |
Re: Folger Prusa i3 Kit from ebay March 20, 2015 12:22PM |
louspinuso
TheLost
Zavashier
TheLost
Wait.. what?
While I don't always (almost never) agree with Zav about calibration and measurements, in this case the problem exists, but ONLY if your belt along the top of the pulley, top of the gear and where it mounts to the y plate (or the x plate depending on what we're discussing) are not in a perfectly straight line (therefore making a triangle). what this does is change teh speed at which your bed will move from one end of the bed to the other simply because in a triangle, where the base is always the same shortening one side will lengthen the other side in a ratio that is not 1:1 and will therefore affect teh speed and distance that the peak of that triangle moves. As long as that is a perfectly straight line, then it won't affect the distance moved at all.
Again, as long as the belt is perfectly straight from pulley to gear through where it mounts to either the y axis sled or the extruder body, pulling the belt one way or the other will result in an equally straight and linear motion.
Although, to further complicate matters, the very small angle that you may be experiencing on your belt may be so small that the differences on the outer edges of your bed may not be that important to you.
Re: Folger Prusa i3 Kit from ebay March 20, 2015 01:24PM |
TheLost
I understand all of that.. however..
1) The path of the X carriage is defined by the two parallel 8mm rods... A straight line.
2) The belt is a fixed size.
If you move the belt by hand 20mm.. the X carriage will ride horizontally along the fixed rods 20mm.
Having the left 'pivot point' (idler pulley) higher then the attachment point on the X carriage can affect speed and the max distance the X carriage can move.. but it won't affect how far it will travel. (because movement is in a straight line.. not up a triangle)
Again.. not trying to argue.. just trying to grasp what your saying.
Re: Folger Prusa i3 Kit from ebay March 21, 2015 03:40PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 04:03PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 04:08PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 04:11PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 04:16PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 04:19PM |
krwynn
Thanks, but kind of hard to use that without a working printer to print it lol. I like the idea though. Might be able to rig something up to make what I have work like that in the meantime.
Re: Folger Prusa i3 Kit from ebay March 21, 2015 04:28PM |
louspinuso
krwynn
Not really that big of a problem. I had an older style end stop mount and couldn't get that mounted so I just held the end stop switch in place till the print started so that the printer could home and then put it down and let it just print. It won't look for the end stop once it starts printing.
Re: Folger Prusa i3 Kit from ebay March 21, 2015 05:10PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 09:45PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 10:54PM |
Re: Folger Prusa i3 Kit from ebay March 21, 2015 11:20PM |
Re: Folger Prusa i3 Kit from ebay March 22, 2015 09:18AM |
Re: Folger Prusa i3 Kit from ebay March 22, 2015 06:14PM |
Re: Folger Prusa i3 Kit from ebay March 22, 2015 06:33PM |
hi, I have the same bed model; i attached a picture. look how I put the switch. I hope it helpsQuote
Ecky
Y Axis Micro Switch Position:
I have the model without the bearing supports on the bed frame, the bearing sit in holes in the acrylic frame, and I am unable to find a place for the switch to be able to touch the bearing or pretty well anything that makes sense.. How have you guys solved the problem???
Thanks
Re: Folger Prusa i3 Kit from ebay March 22, 2015 08:35PM |
Re: Folger Prusa i3 Kit from ebay March 22, 2015 08:51PM |
Re: Folger Prusa i3 Kit from ebay March 22, 2015 10:38PM |
Re: Folger Prusa i3 Kit from ebay March 22, 2015 11:00PM |
Re: Folger Prusa i3 Kit from ebay March 23, 2015 12:06PM |
