Re: Folger Prusa i3 Kit from ebay April 17, 2015 06:35PM |
Vanbot
flippydip
So i got my printer printing, just an issue with the extruder. It seems like it can't fully catch the filament, it misses it thus making a loud noise as if it is skipping. Because of this the filament doesn't come out smoothly.
Could someone please help!
Thank You
I took my extruder apart to see how the filament is supposed to feed into the drive wheels.First are you feeding it into the hole on the top that is directly over the hot end? On mine, looking at the top of the extruder its the hole on the right.
When I feed filament into mine, I hold the filament so that it is curling down and the lower tip ends up pointing to the right. That seems to make sure it goes between the drive wheel and idler. It took a while for mine to feed in properly and it was sort of clicking until it did.
Re: Folger Prusa i3 Kit from ebay April 17, 2015 06:40PM |
Re: Folger Prusa i3 Kit from ebay April 17, 2015 07:10PM |
Re: Folger Prusa i3 Kit from ebay April 18, 2015 09:11AM |
Re: Folger Prusa i3 Kit from ebay April 18, 2015 12:46PM |
Re: Folger Prusa i3 Kit from ebay April 18, 2015 01:33PM |
Re: Folger Prusa i3 Kit from ebay April 18, 2015 05:12PM |
Re: Folger Prusa i3 Kit from ebay April 18, 2015 10:19PM |
flippydip
Yes i am feeding it to the one on the right. I also took it apart to see how it works. Best way i can describe it is that the motor isn't catching the filament consistently, like it slips so the filament doesn't come out right. It is also coming out very thick .
Re: Folger Prusa i3 Kit from ebay April 19, 2015 01:12PM |
DriftyDave
flippydip
I ran into terrible skipping as well. My solution was to turn the extruder temp up until the skipping stopped. Still occasionally get a skip and will replace this extruder soon.
Speaking of replacements, what have people printed that has improved their Folger Tech? I have been looking for an x carrage that runs on 4 bearings instead of the 3. I also need a new extruder. I've only found one option that uses the same v bearing. Just needs a spring. Printing it now along with new Z & X endstop mounts.
Re: Folger Prusa i3 Kit from ebay April 19, 2015 01:23PM |
Vanbot
The one instant improvement I'd like to make it to the extruder. It's a pain to thread in new filament. Does anyone know of a design that works with the existing hot end to allow easier filament changes?
Re: Folger Prusa i3 Kit from ebay April 19, 2015 02:20PM |
krwynn
Vanbot
This one is great. Have had zero problems since installing it. Love it actually.
Extruder for FolgerTech Prusa i3 (v-groove bearing and flat feeder)
Here is mine installed:
I also used this tape 10M 13mm Width PTFE Coated Fiberglass Fabric With Silicone Adhesive Tape to wrap the hot end block which also helped a great deal.
Re: Folger Prusa i3 Kit from ebay April 19, 2015 02:28PM |
Re: Folger Prusa i3 Kit from ebay April 19, 2015 02:32PM |
krwynn
Vanbot
How do you find that tape helps?
Keeps the heat concentrated on the heat end block. Also seems to keep heat from migrating up and also keeps the fan from blowing on the heat block.
Re: Folger Prusa i3 Kit from ebay April 19, 2015 02:36PM |
Vanbot
krwynn
Vanbot
How does that manifest itself in the printing? I've just started getting mine to print so I'm not at the point yet where I'm able to diagnose problems.
Re: Folger Prusa i3 Kit from ebay April 19, 2015 11:32PM |
Re: Folger Prusa i3 Kit from ebay April 19, 2015 11:53PM |
Re: Folger Prusa i3 Kit from ebay April 20, 2015 12:30AM |
Re: Folger Prusa i3 Kit from ebay April 20, 2015 12:45AM |
Re: Folger Prusa i3 Kit from ebay April 20, 2015 07:33PM |
The whole carriage vibrates more then I'd like it too, especially when i put a belt tensioner on. Was thinking a fourth bearing might help it run smoother.Quote
Vanbot
What was your reasoning behind adding another bearing?
Do you have a link? This sounds like something I could use!Quote
thanks78
I did change the Y belt bracket as well to a clamping one, no zip ties, so munch nicer.
Re: Folger Prusa i3 Kit from ebay April 20, 2015 07:59PM |
DriftyDave
Vanbot
thanks78
Re: Folger Prusa i3 Kit from ebay April 20, 2015 09:04PM |
Vanbot
DriftyDave
Vanbot
thanks78
Mine vibrates badly too. Sounds like a buckets of screws rattling around. But it seems to move nice and smoothly. I have heard differing opinions on whether the linear bearings require grease. Some say no and some say to pack them with grease.
I wonder if printed bearings would be quieter.
Re: Folger Prusa i3 Kit from ebay April 20, 2015 11:08PM |
enzo1027
Vanbot
DriftyDave
Vanbot
thanks78
Just got my set of these in today Poly Linear Bearings, and can't wait to try them out. They are linear bearings that have a frelon (some sort of delrin derivative) lining in them. They are self lubricating and have no moving parts. I'm hoping these should all but eliminate the noise! I'll let you guys know tomorrow how they work!
Re: Folger Prusa i3 Kit from ebay April 21, 2015 01:18AM |
enzo1027
Re: Folger Prusa i3 Kit from ebay April 21, 2015 01:29AM |
Re: Folger Prusa i3 Kit from ebay April 21, 2015 02:01AM |
thanks78
This is the Y belt holder I used. I did not use the captive nut, just the standard with lock nuts. [www.thingiverse.com]. Belt is still nice and tight after lots of printing.
Are there any advantages to using a geared extruder? Like the wades and alike. My stepper gets quite warm on long prints. I was thinking not having it attached right to the hotend would help. Anyone have thoughts either way. Thanks.
-Tom
Re: Folger Prusa i3 Kit from ebay April 21, 2015 02:08AM |
Re: Folger Prusa i3 Kit from ebay April 21, 2015 08:28AM |
Re: Folger Prusa i3 Kit from ebay April 21, 2015 09:39AM |
Re: Folger Prusa i3 Kit from ebay April 21, 2015 02:05PM |
Vanbot
enzo1027
Vanbot
DriftyDave
Vanbot
thanks78
Nice! Can't wait to hear how they work.
Steveroy
What was the cost of them??
Steve
Re: Folger Prusa i3 Kit from ebay April 21, 2015 02:24PM |
enzo1027
Vanbot
enzo1027
Vanbot
DriftyDave
Vanbot
thanks78
They are INCREDIBLY quiet! I made a short Youtube video so you could take a listen for yourself. Poly Bushing Video Clip
I hit a bit of a snag unfortunately. Like an ass, I failed to look at the dimensions for the bearings. These are slightly larger than an LM8UU. However, they will work fine for my bed, and I'm in the process as we speak of designing a new extruder carriage to fit them. It will also have a better belt gripping system. I should have the carriage done today and printed out tonight.
Steveroy
Steve
They were $16 a pop through McMaster. A little pricey, but well worth it when compared to the junk ones we get with the kit, imho.
