Re: Folger Prusa i3 Kit from ebay May 14, 2015 09:49PM |
CyBer
Hey everyone, I am currently assembling a folger tech prusa kit and when I tried to manually extrude 50 cm of plastic to test the extruder, the motor seems to pull the filament in a little and then pull it out a little and it never grabs purchase of the filament or extrudes any. I was wondering if anyone knows how to fix this?
Re: Folger Prusa i3 Kit from ebay May 14, 2015 10:03PM |
Re: Folger Prusa i3 Kit from ebay May 15, 2015 12:06AM |
CyBer
Re: Folger Prusa i3 Kit from ebay May 15, 2015 12:16AM |
Re: Folger Prusa i3 Kit from ebay May 15, 2015 07:59AM |
Re: Folger Prusa i3 Kit from ebay May 15, 2015 02:02PM |
Re: Folger Prusa i3 Kit from ebay May 15, 2015 02:23PM |
Re: Folger Prusa i3 Kit from ebay May 16, 2015 12:14PM |
Re: Folger Prusa i3 Kit from ebay May 16, 2015 06:38PM |
hockey9999
Definitely let me know how it works out. I'm curious to see if you get accurate temps with the infrared thermometer, after changing to 1.
Re: Folger Prusa i3 Kit from ebay May 16, 2015 11:32PM |
Dnixon123
I just got the rev B kit and I'm having trouble with the end stop on the y axis. There are no bearing holders for the switch to contact like in the rev A kit. I can't seem to figure out a way to mount them, how did you guys do it?
Re: Folger Prusa i3 Kit from ebay May 17, 2015 02:36AM |
Dnixon123
Re: Folger Prusa i3 Kit from ebay May 17, 2015 09:46AM |
Re: Folger Prusa i3 Kit from ebay May 18, 2015 01:50PM |
Dnixon123
Re: Folger Prusa i3 Kit from ebay May 18, 2015 05:02PM |
Re: Folger Prusa i3 Kit from ebay May 19, 2015 03:19PM |
krwynn
Holy smokes. Thanks for this. Bed heats up in half the time. Went from 8 minutes to 4.
Re: Folger Prusa i3 Kit from ebay May 19, 2015 03:29PM |
Re: Folger Prusa i3 Kit from ebay May 19, 2015 03:32PM |
DriftyDave
I have a quick question I'm hoping someone knows the answer too. When a print finishes on my printer the x carriage homes, then the z homes, then y homes. For a tall print the head can crash into the print with this procedure. Does anyone know how to make the z axis home last so the head drops into the home position last instead of the x axis hitting printed pieces as y homes?
Re: Folger Prusa i3 Kit from ebay May 20, 2015 02:05AM |
Re: Folger Prusa i3 Kit from ebay May 20, 2015 10:17AM |
SRM
yesterday I finally assembled and calibrated my Prusa i3, but after installation of Repetier-host, in Manual Control section I see no temp slider for heatbed. all other settings are ok. does anyone can tell me what I missed. thanks
Re: Folger Prusa i3 Kit from ebay May 20, 2015 11:27PM |
Re: Folger Prusa i3 Kit from ebay May 20, 2015 11:39PM |
Don't rush it, and take your time! You've found this thread, so you've already got an incredible source of info on this build. If you get stuck, check this thread and youtube, otherwise just ask a question and we'd be more than glad to help you out.Quote
Apple-
I'm supposed to be getting this kit in the mail tomorrow and I have to say i'm quite excited!
I'm completely new to 3D printing but i'm a quick learner and I don't think I will have too many issues getting it up and going.
Since i'm a noob is there any advice from people who have bought this kit to lend me?
Any initial tips or anything for the building process or setup?
Anything would help!
Re: Folger Prusa i3 Kit from ebay May 20, 2015 11:42PM |
Apple-
Re: Folger Prusa i3 Kit from ebay May 21, 2015 02:45PM |
DriftyDave
SRM
My first thought is to check the bed thermistor and make sure it is connected to the RAMPS properly. Also test to see if the thermistor is functional.
[www.learningaboutelectronics.com]
Re: Folger Prusa i3 Kit from ebay May 21, 2015 02:48PM |
Re: Folger Prusa i3 Kit from ebay May 21, 2015 04:47PM |
Re: Folger Prusa i3 Kit from ebay May 21, 2015 07:07PM |
Re: Folger Prusa i3 Kit from ebay May 21, 2015 07:10PM |
Re: Folger Prusa i3 Kit from ebay May 21, 2015 07:45PM |
Re: Folger Prusa i3 Kit from ebay May 21, 2015 07:54PM |
Apple-
Should I use the supplied version of Marlin?
I do plan to set up an auto-leveling bed as one of my first projects, and I heard you have to upgrade your firmware before doing that. Is that true or should I just use what is supplied in the google drive?
Re: Folger Prusa i3 Kit from ebay May 22, 2015 09:28PM |
