Re: Folger Prusa i3 Kit from ebay May 22, 2015 11:43PM |
Apple-
For my X carriage, on the part when I have to insert the threaded rods into the stepper motors, it's very bowed out. I've made sure that the rods are as far as in as they can be. Anyone else have this problem?
[imgur.com]
Photos for clarification^
Re: Folger Prusa i3 Kit from ebay May 23, 2015 12:20AM |
krwynn
Looks like you have everything upside down. Nut traps and x-carriage for sure are. They don't need to be in all the way. Also, if you would have watched the videos I suggested, particularly part 17 you'd see how it should look at this point.
Apple-
[imgur.com]
Re: Folger Prusa i3 Kit from ebay May 23, 2015 05:42PM |
Re: Folger Prusa i3 Kit from ebay May 23, 2015 05:49PM |
bmfcamaro
Hello,
It appears that my green power terminal on my RAMPS board has melted. I made sure that all of the screws were tight on the wires and the wires were not tinned. Any ideas as to why this happened? I did happen to read about some of the cheaper RAMPS boards use low amp connectors. Does anyone know where I can order a better power terminal to solder on as I have now removed the old melted one?
Thank you
Re: Folger Prusa i3 Kit from ebay May 23, 2015 05:52PM |
krwynn
Only thing that would do that is a bad connection creating heat. ALL parts are listed here with a link to a vendor: http://reprap.org/wiki/RAMPS_1.4
bmfcamaro
Hello,
Thank you
Re: Folger Prusa i3 Kit from ebay May 23, 2015 10:25PM |
Re: Folger Prusa i3 Kit from ebay May 24, 2015 12:14AM |
Re: Folger Prusa i3 Kit from ebay May 24, 2015 08:54PM |
Re: Folger Prusa i3 Kit from ebay May 25, 2015 01:07AM |
hi, regarding heat bed, I had a similar problem, my was solved by simple turn of the connector on the RAMPS and it appeared immediately without restart of RHQuote
shepp
Hello all, I am new to 3d printing and bought and assembled the i3 prusa kit (revb) . A few problems that I need help with, one is the heat bed doesn't show up on repetier host. So not sure if it even works, and two is I bought a full graphics controller that lights up but doesn't do anything else. I've tried different versions of marlin and nothing works for the controller. I think I need a line by line configure h of marlin to get that working. Trying to tackle one problem at a time. Any help would be really great, thanks
Re: Folger Prusa i3 Kit from ebay May 25, 2015 01:11AM |
in this case I would solder the wires directly to RAMPSQuote
bmfcamaro
Thank you. I cant imagine the screws backing out enough to cause that, but I guess it could happen. Any ideas for an alternative hookup? Something more secure, maybe actual soldered connectors?
krwynn
bmfcamaro
Hello,
Thank you
Re: Folger Prusa i3 Kit from ebay May 25, 2015 10:11AM |
Re: Folger Prusa i3 Kit from ebay May 25, 2015 05:39PM |
Dnixon123
I'm having some serious trouble getting the printer homing configured. It's only the x-axis that I'm really having problems with. I followed the build and configuration instructions from Folger Tech so I have my x end stop to the right and I have my marlin and repetier host set how they recommended. Without changing anything, the x-carriage slides to the left but doesn't stop at the end stop. I've tried messing with both marlin and repetier but nothing seems to work. I've been able to reverse which way the extruder moves but that's about it. If someone could try and help me or send me their configuration file, if they have a similar setup, that would really help. I've tried everything I can think of and I'm getting really frustrated.
Re: Folger Prusa i3 Kit from ebay May 25, 2015 06:17PM |
Re: Folger Prusa i3 Kit from ebay May 25, 2015 08:32PM |
Vanbot
Dnixon123
I had the same problem with my Folger build. Their manual has some errors in it. Try moving the X end stop plug onto the set of end stop pins on RAMPS that is second from the bottom. The Folger manual says to use the bottom-most pins but that position is for a Min end stop. Because Folger puts their X end stop on the right side of the printer it is actually functioning as a Max end stop so you need to bump that connector up one slot to the Max pins on RAMPS.
Re: Folger Prusa i3 Kit from ebay May 25, 2015 08:49PM |
Dnixon123
Vanbot
I've tried that but I get the same results. Nothing I do seems to get it right. The x-axis just doesn't respond to the end stop being hit. I tried switching out the end stop with ones I know work but I get the same result. I might just try to switch the end stop to the min side but I don't want to have to redo all my wiring and I really want to figure out what's going on in the software after working on it for so long.
Re: Folger Prusa i3 Kit from ebay May 25, 2015 09:24PM |
Dnixon123
Vanbot
Dnixon123
Re: Folger Prusa i3 Kit from ebay May 26, 2015 12:17PM |
Re: Folger Prusa i3 Kit from ebay May 26, 2015 12:20PM |
Re: Folger Prusa i3 Kit from ebay May 26, 2015 01:13PM |
SteveRoy
Dnixon123
Vanbot
You need to send the printer M119 codes to see test the status of the endstops and troubleshoot this. What does an M119 give you when the switches are normal, what does it give you when they are closed?
Steve
Re: Folger Prusa i3 Kit from ebay May 26, 2015 04:00PM |
Re: Folger Prusa i3 Kit from ebay May 26, 2015 07:40PM |
Re: Folger Prusa i3 Kit from ebay May 26, 2015 10:33PM |
Re: Folger Prusa i3 Kit from ebay May 26, 2015 11:14PM |
Re: Folger Prusa i3 Kit from ebay May 27, 2015 02:40PM |
Re: Folger Prusa i3 Kit from ebay May 27, 2015 07:03PM |
shepp
I am still having problems with the full lcd controller being recognized. It turns on but all I get is a blue screen with no controls, need help with this. I have so much to print for my quads thats its ridiculous.
Re: Folger Prusa i3 Kit from ebay May 27, 2015 08:21PM |
Re: Folger Prusa i3 Kit from ebay May 27, 2015 08:30PM |
shepp
I have a little bit, but need the proper con h settings, I be tried a lot of different things in config only to get a blue screen
Re: Folger Prusa i3 Kit from ebay May 27, 2015 10:21PM |
Re: Folger Prusa i3 Kit from ebay May 27, 2015 11:44PM |
shepp
I did that and the screen lightened a bit and it started beeping at me. WAs wondering if anybody had a config with all the good settings. Getting very frustrated with this.
Re: Folger Prusa i3 Kit from ebay May 28, 2015 10:28AM |
LCD not working here neither.... I tried a lot of things, (including the Thomas video...).....Quote
krwynn
Follow this step by step and it will work. At least it did for me first try. Not sure how much you have changed in you configuration.h file so you may want to start with a fresh copy. Oh and cover the exposed pins on the LCD with Kapton or electrical tape so you dont accidently short something out.
3D printing guides - Setting up a LCD and SD card controller panel
shepp
