Re: Folger Prusa i3 Kit from ebay May 28, 2015 08:16PM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 05:30AM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 09:25AM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 09:30AM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 09:54AM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 10:41AM |
slanwar
only 205C on your hotend? I use 245 for the first layer then goes down to 240 but never tried with lower temperatures.
Re: Folger Prusa i3 Kit from ebay May 29, 2015 01:01PM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 04:56PM |
krwynn
Follow this step by step and it will work. At least it did for me first try. Not sure how much you have changed in you configuration.h file so you may want to start with a fresh copy. Oh and cover the exposed pins on the LCD with Kapton or electrical tape so you dont accidently short something out.
3D printing guides - Setting up a LCD and SD card controller panel
Re: Folger Prusa i3 Kit from ebay May 29, 2015 05:54PM |
Vanbot
krwynn
I followed this guide to the letter with my Folger LCD and couldn't get it to work.
Re: Folger Prusa i3 Kit from ebay May 29, 2015 07:59PM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 08:37PM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 09:45PM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 10:23PM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 10:38PM |
Re: Folger Prusa i3 Kit from ebay May 29, 2015 11:19PM |
Re: Folger Prusa i3 Kit from ebay May 30, 2015 01:54PM |
Re: Folger Prusa i3 Kit from ebay May 30, 2015 01:57PM |
Re: Folger Prusa i3 Kit from ebay May 30, 2015 02:50PM |
slanwar
Same here, tried the video and doesn't work, on top of that my heatbed doesn't go over 94C after updated with the new Marlin, I may missed something so anybody with a configuration.h I can use?
Re: Folger Prusa i3 Kit from ebay May 30, 2015 02:57PM |
Apple-
Is there any reason my heated bed takes forever to heat up? Like, it physically feels like it gets hot very fast, but the readings take forever to go up.
Possibly a misplaced thermistor I assume.
Re: Folger Prusa i3 Kit from ebay May 30, 2015 03:12PM |
Re: Folger Prusa i3 Kit from ebay May 30, 2015 03:55PM |
Apple-
Re: Folger Prusa i3 Kit from ebay May 30, 2015 04:06PM |
slanwar
I'm going to change the config file like you said to see if works, i replaced the original wires to 14 gauge including the ones from the power supply to Ramps board. Where I can get the thermal paste?
Re: Folger Prusa i3 Kit from ebay May 30, 2015 04:48PM |
Re: Folger Prusa i3 Kit from ebay May 30, 2015 05:14PM |
Re: Folger Prusa i3 Kit from ebay May 30, 2015 05:56PM |
Re: Folger Prusa i3 Kit from ebay May 30, 2015 06:20PM |
slanwar
Okay another problem the temperature was set at 110 then after the first layer goes to 105 except keeps going up to 112-114, to remove the plastic i just printout I had to use a small torch on the back of the glass.
Re: Folger Prusa i3 Kit from ebay May 31, 2015 06:19PM |
Re: Folger Prusa i3 Kit from ebay June 01, 2015 10:16AM |
SRM
DriftyDave
SRM
yesterday I finally assembled and calibrated my Prusa i3, but after installation of Repetier-host, in Manual Control section I see no temp slider for heatbed. all other settings are ok. does anyone can tell me what I missed. thanks
My first thought is to check the bed thermistor and make sure it is connected to the RAMPS properly. Also test to see if the thermistor is functional.
[www.learningaboutelectronics.com]
thanks a lot. simply turned the connector and it appeared immediately. I even tried to print my first thing ever and it is awesome, of course it isn't perfect but I'm impressed. there were couple of issues I noticed during print.
cracking sound in the extruder sometimes when it was printing long solid lines. it was like filament slip a little and lines has a gaps.
x-axis motor was hotter than the others
Re: Folger Prusa i3 Kit from ebay June 01, 2015 01:32PM |
Re: Folger Prusa i3 Kit from ebay June 01, 2015 03:23PM |
Nargousias
Had my printer since last November... Still reading this thread.... and re-reading......
