Re: Folger Prusa i3 Kit from ebay September 15, 2014 10:54PM |
Re: Folger Prusa i3 Kit from ebay September 15, 2014 11:49PM |
Re: Folger Prusa i3 Kit from ebay September 16, 2014 12:52AM |
Re: Folger Prusa i3 Kit from ebay September 16, 2014 01:11AM |
Re: Folger Prusa i3 Kit from ebay September 17, 2014 01:11AM |
Re: Folger Prusa i3 Kit from ebay September 17, 2014 07:58AM |
Re: Folger Prusa i3 Kit from ebay September 17, 2014 09:13AM |
but I'm sure i will get through it.
Re: Folger Prusa i3 Kit from ebay September 17, 2014 09:44AM |
Re: Folger Prusa i3 Kit from ebay September 17, 2014 10:35AM |
Re: Folger Prusa i3 Kit from ebay September 18, 2014 09:01AM |
Re: Folger Prusa i3 Kit from ebay September 18, 2014 11:12AM |
Re: Folger Prusa i3 Kit from ebay September 18, 2014 11:56AM |
I suspect it will be pretty warm in there... I was wondering if you had a chance to finalize your settings (configuration file) in Marlin? I would be curious to see how you have it all configured... and to be totally truthful it would help me a great deal with mine when I do get brave enough to power it on. I decided to put my prusa on a 1/2" piece of plywood, (18" X 20" a bit wider than neccessary so I have room for the lcd display that will be mounted on the plywood as well...) The cost for the plywood at home depot was $7.39 for a 24" x 24" piece which they cut down for me for free... i printed these clips at work to hold the printer in place without bending the rods: |
Re: Folger Prusa i3 Kit from ebay September 18, 2014 12:37PM |
Waltermixx
Wow that's a great looking enclosure. I bet it's very effective.I suspect it will be pretty warm in there... I was wondering if you had a chance to finalize your settings (configuration file) in Marlin? I would be curious to see how you have it all configured... and to be totally truthful it would help me a great deal with mine when I do get brave enough to power it on. I decided to put my prusa on a 1/2" piece of plywood, (18" X 20" a bit wider than neccessary so I have room for the lcd display that will be mounted on the plywood as well...) The cost for the plywood at home depot was $7.39 for a 24" x 24" piece which they cut down for me for free...
Re: Folger Prusa i3 Kit from ebay September 18, 2014 05:01PM |
Re: Folger Prusa i3 Kit from ebay September 18, 2014 10:56PM |
czmorris
@Dooms101, Great idea for the enclosure. Do you have any pictures of your "messy" prints? It would be interesting to take a look at them.
Are you guys all considering (or using) Repetier Host as your host software? I am planning on trying that first when I get everything setup with this printer. My current printer uses custom software which is easy to use (so nice for my wife who doesn't care for the details) but lacks advanced settings for challenging prints.
If I determine I like the Folger printer I am highly considering buying a program called Simplify 3D which so far looks like it has some very impressive features and reviews. The ability to have different zones within a single print which can use different print settings looks very interesting.
Re: Folger Prusa i3 Kit from ebay September 18, 2014 10:59PM |
Re: Folger Prusa i3 Kit from ebay September 18, 2014 11:24PM |
. So I'm almost done with my build. I've drilled some holes in the acrylic to guide wires, add zip ties, and to keep things neat. I wanted to wait and get some nice mesh wire wrap like Dooms101 has, but i was getting impatient... so I used zip ties to keep things together and tight... when I can, I will wrap the cables so it looks better, although it does not look too bad now.
Re: Folger Prusa i3 Kit from ebay September 19, 2014 09:29AM |
Re: Folger Prusa i3 Kit from ebay September 19, 2014 09:39AM |
Re: Folger Prusa i3 Kit from ebay September 19, 2014 10:29AM |
Re: Folger Prusa i3 Kit from ebay September 19, 2014 10:48AM |
Waltermixx
Your print looks great! very sharp.![]()
I think I will flip my plugs. within each pair, does it matter if it's Red, Grey or Grey Red? from the top, yours are Green, Yellow, Red Grey, when I flip my plug, mine will be Green, Yellow,Grey, Red, will that matter?
Hope I'm not being a pain...
Also I can see the polarity of the fan connector, looks like (+) Red is closer to the back of the unit (heat bed connection)
Re: Folger Prusa i3 Kit from ebay September 19, 2014 10:50AM |
Waltermixx
Thanks for the files, and the link. So I'm almost done with my build. I've drilled some holes in the acrylic to guide wires, add zip ties, and to keep things neat. I wanted to wait and get some nice mesh wire wrap like Dooms101 has, but i was getting impatient... so I used zip ties to keep things together and tight... when I can, I will wrap the cables so it looks better, although it does not look too bad now.
I'm hoping this weekend to plug it in and program the arduino mega
here is my Prusa i3 pictures folder: [www.flickr.com]
Re: Folger Prusa i3 Kit from ebay September 19, 2014 03:46PM |
Everything is assembled and wired. I decided i would not reverse the stepper plugs at this point, as it will be a good for me to study the Configuration.h file so I can reverse it from there... plus it's all zip tied nice and neat. I will post a few more pictures, and then the real fun begins... I have my digital multimeter so I can adjust the ref voltage for the stepper drivers.
Re: Folger Prusa i3 Kit from ebay September 20, 2014 12:44AM |
either way here is a picture of it up and running.|
Re: Folger Prusa i3 Kit from ebay September 20, 2014 12:57AM |
Re: Folger Prusa i3 Kit from ebay September 20, 2014 01:07AM |
Re: Folger Prusa i3 Kit from ebay September 20, 2014 01:21AM |
Re: Folger Prusa i3 Kit from ebay September 20, 2014 12:18PM |
Re: Folger Prusa i3 Kit from ebay September 20, 2014 12:38PM |
Re: Folger Prusa i3 Kit from ebay September 20, 2014 03:09PM |
