Re: Folger Prusa i3 Kit from ebay March 03, 2015 04:18PM |
Badkitty
i printed a 20mm calibration cube on mine today. All sides came in at 19.96 - 20.05 mm. my Hot end is loose and spins/wiggles a little when i touch it. Last night i took it apart to get my filament out (change color and it wouldn't feed) i tried to tighten the hot end, but it just kept spinning, so i left it. As i watch it print i don't see it wiggle at all, even when at max axis and the cords put a little tension on it. So i'm happy for now.
Next is getting finer prints. Maybe new hot end and smaller.
Re: Folger Prusa i3 Kit from ebay March 04, 2015 10:54PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 01:08PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 01:27PM |
goboatmen
Hey guys, I bought this kit a few months ago, it's my first 3D printer so it's been a hell of a ride
I haven't been able to get the heatbed working whatsoever though.
Repetier doesn't even acknowledge I have a heated print bed
How have you guys wired it?
Re: Folger Prusa i3 Kit from ebay March 05, 2015 01:39PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 01:46PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 01:49PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 02:32PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 03:43PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 03:46PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 04:16PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 04:35PM |
Re: Folger Prusa i3 Kit from ebay March 05, 2015 10:40PM |
Re: Folger Prusa i3 Kit from ebay March 08, 2015 08:12PM |
Re: Folger Prusa i3 Kit from ebay March 09, 2015 09:58AM |
goboatmen
It still doesn't work
what should my configuration.h look like with regards to this?
Re: Folger Prusa i3 Kit from ebay March 10, 2015 04:02PM |
Re: Folger Prusa i3 Kit from ebay March 10, 2015 04:34PM |
bcollins12
I just finished mine, but the larger Y-axis stepper motor is not working. It's vibrating like its trying to step but it will not spin. I took it apart to see if any debris was in the rotor, it was clean. The only thing I can think of is the Vref pot. to adjust, is it possible thats why its just vibrating instead of fully stepping?
Re: Folger Prusa i3 Kit from ebay March 10, 2015 04:44PM |
Re: Folger Prusa i3 Kit from ebay March 10, 2015 10:31PM |
Re: Folger Prusa i3 Kit from ebay March 10, 2015 10:53PM |
that1guy
Zavashier
The waves comes from a mecanical issue. What you have already changed could not help. Something's oscilating at regular intervals. Are your Z threaded rods straight ? Are your belts perfectly aligned ? Have you got some play somewhere ?
I'm not convinced it is a belt issue. For it to the belts, both the x and y axis belts would have to both have the same problem AND have that oscillation synced together to make the waves. if you look at the picture, you'll notice the wave doesn't change frequency as it turns the corner. The print is of a calibration angle and each edge is aligned to an axis. This means that as it's printing in one direction, the other motor/belt is not moving. The only part that is constantly moving is the extruder motor. This also explains why the pattern wraps around corners perfectly.
Everything is nice and tight and the waves are in the skirt and first layer, so that rules out the z motor/rods. Im not ruling out mechanical problems, but belts are aligned, bolts are tight, bed is level. Any other ideas?
Re: Folger Prusa i3 Kit from ebay March 11, 2015 09:24AM |
bcollins12
I figured out the motor issue, but now I believe I'm having software problems. I checked the config.h file and made sure the board type is 33 ramps 1.3/1.4 but in repetier I can home the axis but cannot control the motors freely, they simply find the stops then done. I tried sprinter firmware with ponterface and it actually can turn the heating bed on (repetier cannot) and the extruder can be turned on, but no motor controlling, it only moves when I press the home buttons in both programs. Any help would be appreciated.
Re: Folger Prusa i3 Kit from ebay March 11, 2015 10:54AM |
Re: Folger Prusa i3 Kit from ebay March 11, 2015 11:34AM |
goboatmen
Anyone else have a lot of issues with the extruder jamming? My printer works fine except for that. Whenever I try a long print it inevitably fails halfway through
Re: Folger Prusa i3 Kit from ebay March 11, 2015 12:00PM |
bcollins12
The motor issue was actually the 3 jumpers underneath the Y axis ramps board. I bought this printer almost fully assembled from a guy who gave up on it, probably not much electronics experience. Luckily the jumpers were in the spare parts box he gave me. But like I said, this appears to be a software issue because the motors only go one way and I cannot control the components manually in repetier. Also the heat bed thermistor works but I cannot get the extruder thermistor to work, not sure if I have to select the right one in the config.h file. I think I might have an older folger kit actually because mine looks slightly different than their current kit. Maybe I have a different board? Although I doubt it, I currently have the Mega 2560. I will try the new code and get back.
Re: Folger Prusa i3 Kit from ebay March 11, 2015 12:03PM |
widespreaddeadhead
goboatmen
I only had problems when I would change filament. Everytime I retracted it would jam. Eventually someone mentioned it might be retracting too fast, so I slowed it down to 1mm and out it popped!
Re: Folger Prusa i3 Kit from ebay March 11, 2015 12:07PM |
goboatmen
Re: Folger Prusa i3 Kit from ebay March 11, 2015 02:01PM |
Re: Folger Prusa i3 Kit from ebay March 11, 2015 08:28PM |
Re: Folger Prusa i3 Kit from ebay March 11, 2015 09:38PM |
