Re: Folger Prusa i3 Kit from ebay March 11, 2015 11:58PM |
Re: Folger Prusa i3 Kit from ebay March 12, 2015 09:05AM |
55rebel
bcollins12,
What I can see right off in the second picture, is that the heat sink is - more than likely - shorting the soldered pins on your X axis stepper driver....would correct pronto. Remove that heat sink and reposition it more centered, being careful not to make contact with any other soldered pins on that little circuit board Hopefully there is no damage done to the driver and/or board.
Re: Folger Prusa i3 Kit from ebay March 12, 2015 11:11AM |
Ok I will definitely correct this, but after much trial & error last night, I discovered that I have a defective thermistor on the extruder. Apparently marlin has a safety feature which prevents any motor movements or bed heating when the extruder thermistor isn't functioning. I disabled the thermistor in the config.h file and then I could move the motors manually in any direction AND heat the bed and move the extruder stepper. So I ordered a 10 pk from amazon last night they said it will be here Tomorrow, and hopefully that will fix it! But the only thing I couldn't figure out was the thermistor always read 0 deg C but when I hit it with a torch it would increase as if it was working,,,,Quote
55rebel
bcollins12,
Re: Folger Prusa i3 Kit from ebay March 12, 2015 11:43AM |
Awesome, thanks!Quote
thefugitive87
MindRealm created this:
[www.thingiverse.com]
Which helps with filament changes and fixing jams.
Re: Folger Prusa i3 Kit from ebay March 12, 2015 04:22PM |
bcollins12
55rebel
bcollins12,
Re: Folger Prusa i3 Kit from ebay March 13, 2015 07:56AM |
that1guy
Hey all! So I'm still having waving problems in my prints (see [forums.reprap.org]) and pic:
wavy print pic
I've followed all the advice I've recieved to try and fix this, but nothing has had any affect.
I've tried:
- Replaced acrylic Y axis sled with an alluminium seld
- Cleaned out the hot end
- New hot end
- New fillament
- New stepper motor
- A whole new extruder assembly from Folger (stepper motor, hot-end, fan,etc)
I thought for sure the last one would have fixed the problem but theEXACT
same output is happening: waves in the print for both axis (elimates x or y motors as it happens on the Y axis when the X motor isn't running, and vice-versa).
It's gotta be software right? I've calibrated the DEFAULT_AXIS_STEPS_PER_UNIT setting for the extruder (currently 101). I'm printing ABS @ 225 extruder and 95 hotbed. The bed is absolutely perfectly level and am printing 0.2mm height. I have tried an initial height of both .3 and .2mm (no difference). I've even upped my vref thinking it wasn't enough.. no change.
It may be my imagination, but I could swear I hear a high pitched noise that pulses at the same rate the waves occur as it's printed.
The only upside to all of this is that now I have two extruders and, as soon as I get it printing right, I can setup for dual extrusion.
Any thoughts would be greatly appreciated!!
Re: Folger Prusa i3 Kit from ebay March 13, 2015 02:43PM |
locutus_40
that1guy
wavy print pic
I've tried:
- New hot end
- New fillament
- New stepper motor
look at your jerk settings.. or it could be something loose on one of your axis..it looks more mechanical than software..
Re: Folger Prusa i3 Kit from ebay March 14, 2015 12:23AM |
Re: Folger Prusa i3 Kit from ebay March 14, 2015 06:56AM |
quigs
Hey everyone. I am new to 3d printing with kits and im having an issue with my folger tech prusa i3.. I posted this up in my own thread but its not getting much attention. I cannot get my extruder to function with the controls in Repetier. Everything else works great though. The extruder gets up to temp, all my end stops work, all the motors work. I tried swapping the extruder motor to the x axis and it responds when I tell X to move. Dry run is off, and the extruder is at 230 degress C when I tried to load the filament. Everything appears to be plugged in correctly. I believe it is an issue with the files I got from Folger Techs Google file. Can anyone help me shed light on this? I am eager to start printing
Re: Folger Prusa i3 Kit from ebay March 14, 2015 08:27AM |
Re: Folger Prusa i3 Kit from ebay March 14, 2015 10:00PM |
Re: Folger Prusa i3 Kit from ebay March 15, 2015 01:30AM |
Re: Folger Prusa i3 Kit from ebay March 15, 2015 12:55PM |
b))
b))
b))
b))
b))
b))
b))
b))|
Re: Folger Prusa i3 Kit from ebay March 15, 2015 01:09PM |
Re: Folger Prusa i3 Kit from ebay March 15, 2015 06:30PM |
Re: Folger Prusa i3 Kit from ebay March 16, 2015 05:50AM |
Re: Folger Prusa i3 Kit from ebay March 16, 2015 10:56AM |
Zavashier
I printed 1.5% larger on the Y axis and 0,5% on the X axis. No matter for small parts, but not on large ones. Also small holes was allways a bit oval. Appreciate my settings allow me to print close to perfection 0.3mm thin walls, so it can't be extruder's calibration. When I changed for proper dimension idler pulleys, the values cames down to a 0.3% on each axis. I guess it's now as precise as it can be.
Re: Folger Prusa i3 Kit from ebay March 16, 2015 04:32PM |
Re: Folger Prusa i3 Kit from ebay March 16, 2015 05:25PM |
Re: Folger Prusa i3 Kit from ebay March 17, 2015 04:30AM |
Re: Folger Prusa i3 Kit from ebay March 17, 2015 08:32AM |
Zavashier
Read this. When you adjust the steps per mn values, you introduce more problematic errors. Why ? Because what you did to adjust your values, ils to print a part, a 20x20mm cube for example, and you adjust your steps per millimeter to get a perfect 20x20mm cube, right ? But if you print a 10x10mm our a 100x100mm cube, it won't be right this time, because your adjustment cannot work for any other measurment. It's mathematical and simple as that.
So adjusting the steps per millimeter values sounds simpler, but it's just wrong.
Re: Folger Prusa i3 Kit from ebay March 17, 2015 01:57PM |
Re: Folger Prusa i3 Kit from ebay March 17, 2015 02:17PM |
widespreaddeadhead
Anyone had troubles with getting a replacement part from FolgerTech? One of my endstops doesn't work, and I haven't gotten a reply email in a few weeks... I'm sending another today, just wondering what anyone else's experience with this is.
Re: Folger Prusa i3 Kit from ebay March 17, 2015 02:39PM |
You don't get it. I will explain it into other words. If your're mathematician and you don't understand that, there's nothing more I can do.Quote
louspinuso
Zavashier
It may have been 20+ years since my college days where I minored in math, but I'm pretty sure that's not how it works. Steps per mm means just that, for each millimeter. If it takes 50 steps to go 1 millimeter, then it takes 500 to go 10 millimeters. That doesn't even take any of my college math to figure out, that was probably covered in middle school or earlier. If you need 80 steps per millimeter when you print a 20 millimeter cube on the x axis, then based on the math you will need 1600 steps to print the x axis of that cube. Based on that same math you will need 800 steps to move 10 millimeters in the x direction and 8000 to move 100 millimeters.
Not only do I know that this is right because the math is right but also because I've gone through several kilo's of filament in the last 4 months with very accurate prints and extremely tight tolerances. I just printed a holder for a 4.3 inch diagonal screen for a raspberry pi project I'm working on and the screen fit perfectly and can be held in with friction because the tolerances of my prints are so tight. And the dimensions of that opening were not 20mmx20mm. The only times I have had trouble with this printer, to be honest, is when I've changed my bed height because I had to replace the y axis carriage holders, which took me some time to dial in the perfect z height again, and when I was printing with the folger tech black ABS that I started with, which seems to just have all sorts of problems. Other than that I've had lots of perfect prints and a few wonky prints, which were mostly due to my own learning curve.
So going back to your original comment, adjusting steps per millimeter values not only is simpler, but it's also not wrong. It's not any more wrong than making new idler pulleys to fit within your expected range of movements.
Re: Folger Prusa i3 Kit from ebay March 17, 2015 04:38PM |
Re: Folger Prusa i3 Kit from ebay March 17, 2015 10:21PM |
Re: Folger Prusa i3 Kit from ebay March 18, 2015 06:12AM |
Re: Folger Prusa i3 Kit from ebay March 18, 2015 10:07AM |
Re: Folger Prusa i3 Kit from ebay March 18, 2015 01:17PM |
pabloevaristo
thanks, the connections are ok. Measured 1.7 Ohms for the bed.
So you're telling me that for getting 110V I'll need to change the power supply?
(have you checked this kind of beds?)
For the lcd, the #define are the way it's supposed, but nothing...
Re: Folger Prusa i3 Kit from ebay March 18, 2015 03:04PM |
Newtoprinting
pabloevaristo
did you install u8glib watch toms guide on how to install full graphic smart controller.
(well, blue)
