Re: Folger Prusa i3 Kit from ebay April 05, 2015 01:11AM |
maybe you are running the extruder reverse, that what happened to me the first time, the clicks were because it was retracting filament. Try to reverse the stepper's wireQuote
DriftyDave
donkahones: Thanks for the info! Got the whole thing together today! All the motors move correctly, everything heats up and I was able to level the bed for the first, of many, times.
Only issue so far is the extruder just clicks when trying to fed filament... Gonna have to search around on that one. Any advice would be appreciated. ;D
Re: Folger Prusa i3 Kit from ebay April 05, 2015 10:58AM |
Re: Folger Prusa i3 Kit from ebay April 05, 2015 11:32AM |
Re: Folger Prusa i3 Kit from ebay April 05, 2015 12:26PM |
choopi
choopi
Ok, my Folger I3 printer is built. Everything work good, except a few things.... When I test my motors, x,y and z they move only one way, the other way it tell me that I'm at the stop but I'm not.
For example, I move x axix (-x) and it move left and if I move left(+x) it give me code:
''echo:endstops hit: Y:-1.40
echo:endstops hit: X:-1.56
echo:endstops hit: X:-1.55''
but I'm not at the endstop...
It's the same on the Y and Z
Any idea what is wrong?
Ok, now my x and z are working good! Now my new snag! My Y only move one way... If I move y+ it goes towards the front and if I hit the -y it goes towards the front also.
Re: Folger Prusa i3 Kit from ebay April 05, 2015 12:44PM |
Re: Folger Prusa i3 Kit from ebay April 05, 2015 01:17PM |
55rebel
choopi
Anybody ever experince the y going only one direction? I plug my y motor in the x and it was working fine. I don't know where to look next?
This only happens to me when I fail to home any one of my axes--but not always....strange.
Re: Folger Prusa i3 Kit from ebay April 05, 2015 07:06PM |
Re: Folger Prusa i3 Kit from ebay April 05, 2015 11:29PM |
Re: Folger Prusa i3 Kit from ebay April 06, 2015 05:27AM |
choopi
I made video that demo my problem, maybe this could help... As mentioned before my y axis move only one direction.
[www.youtube.com]
Re: Folger Prusa i3 Kit from ebay April 06, 2015 10:48AM |
Re: Folger Prusa i3 Kit from ebay April 06, 2015 11:15AM |
Re: Folger Prusa i3 Kit from ebay April 06, 2015 05:46PM |
Re: Folger Prusa i3 Kit from ebay April 06, 2015 07:09PM |
#include "U8glib.h" #ifndef CONFIGURATION_H #define CONFIGURATION_H .... .... ....
Arduino: 1.6.3 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from Marlin.h:22:0,
from cardreader.cpp:1:
Configuration.h:1:20: fatal error: U8glib.h: No such file or directory
#include "U8glib.h"
compilation terminated.
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Build options changed, rebuilding all
Using library LiquidCrystal in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10603 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Mark\AppData\Local\Temp\build1070758060582676053.tmp\cardreader.cpp -o C:\Users\Mark\AppData\Local\Temp\build1070758060582676053.tmp\cardreader.cpp.o
In file included from C:\Users\Mark\AppData\Local\Temp\build1070758060582676053.tmp\Marlin.h:22:0,
from C:\Users\Mark\AppData\Local\Temp\build1070758060582676053.tmp\cardreader.cpp:1:
C:\Users\Mark\AppData\Local\Temp\build1070758060582676053.tmp\Configuration.h:1:20: fatal error: U8glib.h: No such file or directory
#include "U8glib.h"
Error compiling.
Re: Folger Prusa i3 Kit from ebay April 06, 2015 08:42PM |
Re: Folger Prusa i3 Kit from ebay April 06, 2015 10:39PM |
Re: Folger Prusa i3 Kit from ebay April 06, 2015 10:50PM |
Re: Folger Prusa i3 Kit from ebay April 06, 2015 10:53PM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 10:01AM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 10:49AM |
DriftyDave
I'm pretty positive it was going the correct direction. When I went forward it would pop repeatedly. When I went in reverse the filament backed right out. There were teeth marks deep into the filament. I'm going to play with it on teh bearing side tonight and see what I can do. I been thinking on how I can increase the gap between the gear and bearing by just a hair.
I am using .2mm for each layer.
Re: Folger Prusa i3 Kit from ebay April 07, 2015 01:34PM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 01:43PM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 03:35PM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 04:40PM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 05:43PM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 06:50PM |
Re: Folger Prusa i3 Kit from ebay April 07, 2015 09:34PM |
I've printed all my upgrades in red pla so I can see whats stock and whats upgraded. Only black parts left are the four black corners and the Y motor mount. Thing is that you need a printer to print the upgrades. It's a learning experience so you wont know what to print until you have an issue you need to solve. If you are assembling the printer tonight then make note of the pic I posted a few posts up that shows how you should secure your belts. (Don't follow what folger tech says to do)|
Re: Folger Prusa i3 Kit from ebay April 08, 2015 10:53AM |
krwynn
What are the chances of getting a good picture?
Re: Folger Prusa i3 Kit from ebay April 08, 2015 06:27PM |
Re: Folger Prusa i3 Kit from ebay April 08, 2015 06:41PM |
DriftyDave
I pulled the hot end apart. Cleaned out all the ABS bits that were in there. Tried swapping the bearing over to the left side and upping the vref to .45v. Still clicking... Everything seems fine until the filament gets into the nozzle. I'm wondering if its clogged up in there. I'm gonna take it apart again and see if I can clean it out.
Re: Folger Prusa i3 Kit from ebay April 08, 2015 07:12PM |
