Re: Folger Prusa i3 Kit from ebay October 03, 2014 06:22PM |
czmorris
Haha! I forgot those photos were there. Yes it is a Yorkie (Allie). My wifes dog.
I haven't noticed the extruder motor getting hot but I also haven't had any issues yet with jams. On my other printer the only time I have had an issue with that is using cheap filament that wasn't very uniform.
My biggest issue with the prusa is a bit of layer separation. At the moment I am running a test using my folding light box as a temporary enclosure to see if it helps at all.
I moved my nuts up to expose the heat break on my extruder, but i dont think that will be enough...|
Re: Folger Prusa i3 Kit from ebay October 03, 2014 11:51PM |
Re: Folger Prusa i3 Kit from ebay October 04, 2014 12:49AM |
I will try your suggestions of checking the diameter of the ABS, i think part of the issue may be that
Re: Folger Prusa i3 Kit from ebay October 04, 2014 01:54AM |
Re: Folger Prusa i3 Kit from ebay October 04, 2014 08:12AM |
Re: Folger Prusa i3 Kit from ebay October 04, 2014 08:41PM |
Re: Folger Prusa i3 Kit from ebay October 05, 2014 12:03AM |
here are the photos:
in abs! I hope it works...|
Re: Folger Prusa i3 Kit from ebay October 05, 2014 12:37AM |
Re: Folger Prusa i3 Kit from ebay October 05, 2014 12:43AM |
that should do it...|
Re: Folger Prusa i3 Kit from ebay October 05, 2014 07:30AM |
czmorris
I modeled up and printed a filament spool holder and guide last night and so far it seems to be working pretty well. I designed it vertical in order to reduce the risk to the acrylic on this kit which seems to be fragile.
I uploaded the models to Thingiverse if anyone else wants to use it or edit it.
Spool Holder
Filament Guide
DSC_0673 by czmorris, on Flickr
Re: Folger Prusa i3 Kit from ebay October 05, 2014 07:46AM |
Re: Folger Prusa i3 Kit from ebay October 05, 2014 07:51AM |
Re: Folger Prusa i3 Kit from ebay October 05, 2014 10:21AM |
nosetinker
Hello guys,
I recently bought this kit on ebay and almost done building it (mainly thanks to your messages in this thread). One question that is unclear to me is how do you solder wires to the heatbed. I have R1 Dual Power Heatbed and there are 2 groups of pads I can solder on. One has 3 pads and I guess those are for power and the other group has 2 pads and those go for thermistor, I suppose. But it's unclear to me to which of three pads should I solder power wires? Can you help me with this, guys?
Re: Folger Prusa i3 Kit from ebay October 05, 2014 11:29AM |
czmorris
nosetinker
Hello guys,
To go with what Waltermixx said about the bed wiring. Don't forgot to provide strain relief to the wires coming from the bed. The wires near the solder joints may eventually break due to bed motion over time.
Re: Folger Prusa i3 Kit from ebay October 07, 2014 01:17AM |
Re: Folger Prusa i3 Kit from ebay October 07, 2014 05:19AM |
Re: Folger Prusa i3 Kit from ebay October 07, 2014 08:57AM |
Re: Folger Prusa i3 Kit from ebay October 09, 2014 12:30AM |
Re: Folger Prusa i3 Kit from ebay October 09, 2014 08:32AM |
for the price it's definately worth it.
added control
Re: Folger Prusa i3 Kit from ebay October 11, 2014 12:51AM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 01:12AM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 07:54AM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 12:47PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 01:33PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 02:20PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 06:31PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 07:35PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 07:44PM |
Re: Folger Prusa i3 Kit from ebay October 11, 2014 09:10PM |
Waltermixx
Dooms101 good to see you online again
love to see a post of your printer in action printing the skull, and of course once it's done
Cheers.
Re: Folger Prusa i3 Kit from ebay October 11, 2014 09:16PM |
wheeeee. I looked at the cura code again and realized it actually says in the comments for the 15 mm move that it is to lower the bed. So could it be a problem with my cura setup??
